Old 11-01-2015, 02:43 PM   #1
2011 27 FB International
Vancouver , British Columbia
Top suggestions for winter living
Circumstances are leading us to remain in the Vancouver BC area possibly through the entire winter. Our plan originally was to get ourselves far south in the next couple weeks and travel for the next couple years following the nice weather, so I haven't really thought about winter living. We are full time at this point, having prepared to leave, sold the condo, etc. So now I am starting winter prep research, and thought I'd ask about top suggestions. The only real winter prep we have is a heated water hose.
Fortunately Vancouver rarely freezes, rarely snows, but it can happen. I'm hoping el nino keeps it mild. It does however rain a lot.
I normally keep the grey tank open, should I get in the practice of closing it?
We keep vents open but I wonder about humidity still.
Trying to figure out a combo of electric heat and furnace, would like the furnace at lower temps to keep the tanks heated. It seems the electric heater could keep the temp high enough to prevent the furnace turning on.
I'm sure there are lots of suggestions and approaches throughout the forum, but was wondering if there is a sticky thread for top suggestions, best practices, etc.
mixedpuppy is offline   Reply With Quote
Old 11-01-2015, 02:44 PM   #2
Of course, the first thread I see after posting is a sticky "Winter Modifications". Face/Palm. /me goes to read.
Old 11-05-2015, 01:03 PM   #3
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Do not make it a habit to always leave your gray valve open. You need the quick flow of the gray water to wash out the sediment in the tank; that sediment will also clog the blade of the valve. I learned this the hard way - I was camped with full hookups for 3 months and had left the gray valve open on my previous AS ('94 LY moho). I had to have the valve replaced. As well, the gray water is used as part of the flushing of the waste.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 11-05-2015, 06:19 PM   #4
Nomad518's Avatar
2001 25' Safari
Vancouver , Washington
An electric space heater should keep things comfy on all but the coldest nights. Leave your propane fueled furnace for use only when things get really cold. Your biggest concern might be condensation inside your windows. Keeping a roof vent cracked open slightly will enable warm moist air to escape, but you'll also lose some heat. Position your space heater where it does the most good. Also, if you can insert some additional insulation behind the galley and bath sink cabinets, and any other out of sight areas, it will help in keeping out the cold. If you're planning to stay in one spot and you can put an insulated skirt around the underside that helps too. There are some good threads here from others who have done this in very cold environments with good results
Nomad518 is offline   Reply With Quote
Old 11-06-2015, 12:36 AM   #5
@blkmagikca my typical pattern is to close the grey tank a day or so before I need to dump the blank tank (usually I dump it at half to 3/4 full), do extra cleaning/etc., it is usually nearly full. That is roughly every 7 days. Do you think sediment becomes an issue at that point?
Old 11-06-2015, 04:52 AM   #6
Huh?
Ultradog's Avatar
1975 27' Overlander
Twin Cities , Minnesota
Images: 8
When I lived in a cabover camper in Anchorage for 3 years I bought some 3/4" pink Styrofoam insulation and added that inside all the closets, cupboards and hidden places.
Measure closely and cut with a sharp utility knife. Then you can friction fit the pieces so they don't fall out. It made a huge improvement in comfort level and decreased propane usage.
Ultradog is offline   Reply With Quote
Old 11-06-2015, 10:41 AM   #7
2015 25' Flying Cloud
Apollo Beach , Florida
Food for thought. I'm not an electrician but talking to a RV repair man in Georgia recently I was told never to use an electric space heater in my Airstream. He said the amp draw on those heaters may heat and melt the wiring in the trailer and that he had many calls where this had happened. I've never used one but had thought about buying one to save on propane use. ?? Anyone care to comment on their use?
Guyel is offline   Reply With Quote
Old 11-06-2015, 11:10 AM   #8
Lily&Me's Avatar
Normal , Illinois
Have used one for 13 years, and never had a problem.
To the OP, and anyone else traveling or camping in the cold......micro fleece, micro fleece, micro fleece.
Keeps you warm and toasty, and Cuddl Duds at WalMart are very inexpensive.
Wear them during the day, sleep in them, whatever....if you don't like to be cold, they are the best.
Maggie
Old 11-06-2015, 11:42 AM   #9
2005 19' Safari
GLENDALE , AZ
We use a "Vornado" space heater on LOW only; very quiet and only draws about 800 Watts on LOW. (HIGH uses 1,600 Watts.)
In above freezing weather, it will maintain 68 to 72 degrees overnight; but it takes a long time to warm up our 19' Bambi when used alone.
When entering the cold Bambi, we use the air conditioner heater strip or propane furnace to quickly warm up the inside. Then, those are switched OFF, and the Vornado is turned on with HIGH/LOW temperature switch set to LOW and HIGH/AUTO fan switch set to HIGH. Vornado thermostat is set to about 2.5 (range = 1 to 7).
Very comfortable and quiet!
Our Vornado looks similar to this, but they no longer make the model we have:
http://www.amazon.com/Vornado-Vortex.../dp/B000GLHVZA
Note: I have no association with Vornado or Amazon.com other than being a satisfied customer of both. Above link is for reference purposes only.
Phoenix is online now   Reply With Quote
Old 11-06-2015, 11:57 AM   #10
Arcticfox's Avatar
2013 28' Flying Cloud
Central , Canada
The good news is winter does not effect the lower mainland much and when it does its for a sort period of time.
The first thing I would do is go down to your local hardware store and buy an insulated tarp. Then cut it into strips wide enough to go from the bottom of the trailer to the ground. One tarp should give you enough material to create skirting for the complete trailer. The advantage of creating an insulated skirt is it will help to keep you floors and tanks warm. Further these insulated fabric panels can be just rolled up when you want to move or when warm weather arrives again. Once skirted, you can even place a small heater under your trailer if you want. As It will make a huge difference to the warmth inside the trailer and you plumbing and tanks.
Next I would cut a piece of SM insulation and put it into your sky light. This will help your heat loss in that area.
Next go to your local hardware store and buy enough clear sheet plastic to cut inserts for each of your windows. While your there also buy enough bubble wrap to cut panels for each window. Now you want to install the bubble wrap against the inside of the window glass and then the sheet plastic after that to hold the bubble wrap in place. The reason for buddies wrap plastic sheeting is it has insulation value but still allows light into the trailer. This of course compared to something like SM that does bit let much light through it. If you cut the sheet plastic and bubble wrap correctly you will end up with thermal window without much effort.
Hope this helps
Cheers
Doug
Trying to use my camera to create memories - not photographs!
Arcticfox is offline   Reply With Quote
Old 11-06-2015, 12:01 PM   #11
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I keep both my valves (waste & wash) closed except for when I do the actual dump and flush.
VE3JDZ
AIR 12148
Old 11-06-2015, 12:03 PM   #12
2014 30' Flying Cloud
Milton , Ontario
I have a new Flying Cloud cloud out of Canada and the receptacle wiring is #14 CU2, or copper 2 wire 14 gauge. The circuit is protected by one GFIC in the toilet area. This is the wiring that is used mostly in houses for 15 amp circuits. I have checked the wiring for surface heat after running our Noma ceramic tower heater all night and no problem. Some trailers may not be wired as per code or added to by an inexperienced owner. This may be where these scary stories come from.
happy trails
Norrie
Norrie46 is offline   Reply With Quote
Old 11-06-2015, 12:08 PM   #13
Arcticfox's Avatar
Central , Canada
happy trails
Norrie
We have the same situation with our 28' 2013 FC that we purchased out of Seattle. So my guess it this wiring is now standard in both Canada and USA models.
Cheers
Doug
Old 11-06-2015, 12:08 PM   #14
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
I have a small "ceramic" heater which does a good job of keeping the AS warm & cozy. However, since we boondock, electricity to use the ceramic heater isn't always available (or is not as cost efficient) - so we have a Procom blueflame heater as well. I have never had any issues relating to the gauge of the shore-power wiring.
VE3JDZ
AIR 12148
Living in 34' AS Fulltime - Living My Parent's Dream.... bugnot1 Member Introductions 14 12-21-2010 08:40 AM
full-time winter living problems, questions by college girl (freezing temps, furnace) icedcacti Winter Living 30 08-24-2010 08:07 AM
Winter Living Rubyslipper Winter Living 98 06-23-2007 04:49 PM
Winter Living? bhsl8 Winter Living 9 01-22-2006 05:18 PM
Winter living in a Airstream davidh Member Introductions 5 01-22-2006 09:42 AM
