I have no experience with tankless water heaters in trailers and don't intend to gain any (just yet) as the Atwood 6 gallon propane model is working well for us at present. My view has been more than a little clouded by my experience with a tankless system we had at home that was, for all intents and purposes, useless. It had been installed new just before I moved in and was a "dual chamber" affair, a two stage process that pre-heated then heated again. It had to have it's own 100amp service but wasn't too expensive to run, at least not initially. The trouble was the flow; it took an age to get the hot water around the house and then, once in the shower it wasn't exactly a powerful stream. Adding just the tiniest bit of cold from the city water (at a better pressure) just wiped out the hot flow. We stuck with it until it broke and, even though it was still under warranty, we canned it in favour of a natural gas powered 50 gallon tank, rented from a local company and that works perfectly. The tankless system had cost $1,500 dollars and every penny was wasted!
In the UK, domestic tankless showers are very common. These run from a 30amp service and, if they have a pump as some do, provide brilliant showers. The whole unit is about 18 inches square and maybe 4 inches deep, so is pretty unobtrusive, even in the smallest bathrooms. Sadly I don't think it'd work in an Airstream because of the power demands, but it's about time we saw a few for the home on the shelves of Lowes or Home Depot.
"You can't tow that with that!"
http://towedhaul.blogspot.com/
Large shiny trailer
Red US made Japanese Minivan
Brake controller with blue flashing numbers
Big lifty bars and chains
2011 Resin Gnome
**New for 2012 - Willow the Crazy Greyhound**
