15K units are great, but still not enough if temps and humidity are high, when one has a long trailer (and no shade).
I've been thinking that my best route would be to install two 13.5's if I ever want to start using this trailer in the summer, and not have to drive 1,000 miles to a cooler climate.
Can't say I'll actually do it, but I have seen two 34' A/S trailers from Texas with two roof A/C units.
That's not an unusual situation. I've seen quite a few 34's with two AC units. I think it's usually been a situation where there was a 13.5 K unit up front and an 11K unit in the rear.
Jack
Jack Canavera
STL Mo. AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
I wonder how a small duct to the rear of the trailer would work? They do make ducted lower units for RV a/c units, though their definition of "ducted" is not the one I use.
i was thinking the same thing for our 34' with the 13.5 unit. i was thinking of using some sort of 'funnel' like the old under dash mounted A/C vents on cars and some soft tube (about2") that i could run along the ceiling over the sliding door cutouts. the duct facing the rear, only cools the door when it is closed.
Ricky
Ingrid - my unofficial '"World's Oldest Airstreamer"
January 1909 - October 2008 R.I.P.
Plan B would be easiest, simplest, and cheapest, and is what we do:
Get a small floor fan, aim it at the back of the trailer, and turn it on "low".
A $20 fan is a lot cheaper than a second $700+ a/c, plus all the wiring involved, not to mention time and wiring for moving the front one.
Nope, a fan is not enough. Already have a very nice one.
Back when I ordered my Safari, only the Classic line had the 15k unit. I had some level of conversation before I said something to the effect "the 25' Classic is dimensionally the same as the 25' Safari right?"....they said "well yea", and I said "great, then put er in".....then they said "$250 upgrade", "I said just do it."
They did and I have to say, I can hang meat in full sun in 95+ degree outdoor temps.
Today, many of the 25s and larger (and not just the Classics) come with the 15k unit as an option. If you plan on going into high heat areas, don't let anyone tell you it cycles too much, it's overkill, etc. A 15k unit should be standard on any Airstream 25' or larger. 13.5k is good between 19 and 23, and 11k for a 16' would be fine. In your case, don't walk, RUN to the 15k unit. You won't be disappointed.
First of all I'll say that you'll love the 28 ft. In my humble opinion as a rookie Airstreamer it's the best floor plan of the whole line. We have the 28' and we're really glad we got that one.
We upgraded to the 15,000 BTU unit and it's worth it. It does a great job of cooling in the heat of the New Mexico desert.
__________________ Jim & Rod
Two Burmese cats with attitude Philip and Gus
When I was making the same comparison, I got all sorts of dire warnings that the 15,000 Btu unit would not run long enough to dehumidify the air resulting in less comfort than a 13,500 Btu AC. They all came from places like Vermont and Canada. Trust me, the 15K unit will get plenty or runtime! After living this summer with the 15K Carrier AirV, I am considering a 13.5K one. For a second air conditioner. I have a 34’ Excella in full sun in Arkansas. elolson and I have exchanged comments following my upgrade detailed in Yet Another Carrier AirV Installation Thread. And yes elolson, it did eventually reach 105 with 90%+ humidity this summer here in Little Rock. I did not have to completely close off the back, but did consider it a couple of times. I got by with closing the two vents that blow towards the rear and running the vent in the bedroom. Shorts and tank tops too.
There’s a post from Pennsylvania stating what a shame someone added an AC to a great looking vintage unit in Austin: airstream sightings. I’ll admit it would look better without it, but that’s all it would be good for in Austin without an AC. It’s different in the South.
