Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living
Old 03-10-2008, 11:31 AM   #1
GolfStream
Cornucopia of useless inf
GolfStream's Avatar
Profile:  2006 19' International CCD
Miami Shores , Florida
Southern Folk Chime in on BTU!
I'm considering upgfrading my 2006 19 foot Bambi for a 2007 28 foot International (I figure if I'm going bigger, I'm going for it.) I have found two units and the only difference is the BTU's on the A/C. Does the 15000 BTU a/c cool down a 28 foot international all that much faster / more efficiently over a 13500 btu unit??
I LIVE IN SOUTH FLORIDA. GOOD AC IS A MUST FOR FOUR TO SIX MONTHS EACH YEAR.
thanks!
Javier
Currently Mobile Homeless in Florida
Permanently
Miami Shores, FL
1968 Imperial Crown Convertible
2007 Ford F-150 Supercab tow monster.
WBCCI #1868
GolfStream is offline   Reply With Quote
Old 03-10-2008, 11:41 AM   #2
Bambi_Bandit
Bambi_Bandit's Avatar
Profile:  2008 27' International CCD FB
Go with 15000K
I also went from a 19' Bambi to a 28', only to have the 28' with a 13.5K struggle in Texas heat. You really notice it struggle in full sun, no shade... I only had the main awning on the 28'.
My current 27FB (only 1 inch longer then the 28 I had) has the 15K. I like it much better.....
It is more efficent to cool after traveling in the hot summer humid day than the 13.5 was. The 15K seems to be able to get ahead of the curve from a dead summer heat (sitting or traveling all day in the sun), but the 13.5 could never get enough "oomph"...
Kevin & Prim Li
Bandit the Siberian Husky & "G" the Min-Pin
2008 27FB Intl CCD Customized by Airstream & David Tidmore @ Roger Williams Airstream
2005 Ford Excursion Diesel 4x4
WBCCI # 11809
AIR # 6155
2nd love - 2006 28' Safari LS
1st love - 2004 19' CCD Bambi
Bambi_Bandit is offline   Reply With Quote
Old 03-10-2008, 11:43 AM   #3
Fyrzowt
Fyrzowt's Avatar
Profile:  2000 25' Safari
Templeton , California
Images: 8
I don't live in the south, but...
My wife is from Houston and I've spent some time there. My personal view would be to go big on the A/C just like you did on the trailer. It's easier to do it now than wish you did it later.
From what others who own larger trailers in the South have posted, bigger is better when it comes to A/C.
Dave
Fyrzowt is offline   Reply With Quote
Old 03-10-2008, 12:55 PM   #4
jcanavera
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Go for the 15K unit. I had a 27 foot Safari in which the 13.5K unit in my opinion was undersized for the hot Missouri summers. I made sure to get the optional 15K unit when I ordered my 30' Classic.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.
'03 GMC Savana 2500
'08 Vespa GTS 250
jcanavera is online now   Reply With Quote
Old 03-10-2008, 08:11 PM   #5
REDNAX
Aluminum Vintage Kin
Profile:  Corpus Christi , Texas
No such as thing as too much A/C capacity when the sun hits that metal. It really pays to find a space with afternoon shade.
2004 2WD Dodge CTD Ram 2500 longbed 6-spd/3.73; Leer topper; 7,400#; 140,000 miles.
19 city/22 mpg solo (62 mph/1850 rpm)
1983 Silver Streak 3411 Supreme; 7,320# w/ Hensley Arrow (TW: 980#/13%)
http://www.tompatterson.com/Silverst...1983/19831.php
Rig is 15,700#; 15 mpg at 62 mph
REDNAX is offline   Reply With Quote
Old 03-10-2008, 08:20 PM   #6
2airishuman
2airishuman's Avatar
Profile:
hi golf...
the primary differences between the 13.5 and 15k units are condenser/cooling coil sizes and a a slightly bigger squirrel cage fan...
oh, and price.
they are within 2 lbs of each other and have basically the same electrical specs and mechanicals.
on long days of cooling and dehumidifying the 10% more btu should be significant.
IF the only improvement is 10% less running time, that's enough, because these things are noisy.
the 15k does fine in my 34 but i often close the bedroom and bath area off just to reduce the work load in mid day heat...
IF you go much bigger than 28 ft, consider 2 ac units for south florida summers.
cheers
2air'
all of the true things that i am about to tell you are shameless lies. l.b.johnson
Old 03-10-2008, 09:05 PM   #7
HiHoAgRV
Profile:  1977 29' Ambassador
Brandon , Mississippi
Images: 26
Tub of BTU's
As a pal in the airconditioning business says-
You need enought B.T.U.'s to cool a B.U.T. the size of a T.U.B.
Hi Ho Silver RV!
Vernon, Sarah, Mac the Border Collie and-
'Epiphany' the 29' Airstream
Old 03-10-2008, 09:06 PM   #8
elolson
elolson's Avatar
Profile:  2000 34' Excella
Tucson , Arizona
For the bigger units (34') with no shade, even 15k is not enough. To get even remotely less that a heat pit you will have to close off the front from the back and install a second until in the bedroom where the fantastic fan is and then close off the front as you switch between them to keep under the 30amp limit, or install a 50amp $$ervice.
Go with as much BTU as you can, if you are stuck in the sun in the summer (Globe,AZ in a parking lot for two weeks in July '07 with 116 deg) then you need professional AC, not this amateur garbage.
So to answer your question, you will never regret the 15k choice if you live where it can get hot and sunny.
elolson is offline   Reply With Quote
Old 03-10-2008, 09:15 PM   #9
Sugarfoot
Sugarfoot's Avatar
Profile:  1960 24' Tradewind
Southeastern Area , Tennessee
Ditto . . .
Go with 15K. You'll thank yourself for choosing so wisely.
• • • Aluminocentricity • • •
Sugarfoot is offline   Reply With Quote
Old 03-10-2008, 11:03 PM   #10
ROBERTSUNRUS
ROBERTSUNRUS's Avatar
Profile:  2005 25' Safari
Lakewood , California
Images: 18
Hi, while you have a choice, go for the 15K unit. You can always turn it down if it gets too cool inside, but you can't turn the smaller unit any higher than it's max if it's not cool enough. Or, it's cheaper to pay the extra $$$$ now than to pay for an upgrade later. $$$$$$$$$$$$$$
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 03-11-2008, 05:02 AM   #11
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
all over , Fulltiming
Images: 58
15K, no question. In this case, size does matter. Way back when, I even put a 15K on our 20' trailer.
Change is inevitable, except from a vending machine
AIR#2611
Old 03-11-2008, 07:23 AM   #12
Midamrail
Midamrail's Avatar
Profile:  1971 31' Sovereign
2008 25' Classic
1949 22' Liner
Villa Ridge , Missouri
We have a 13.5K in our vintage 31-footer (which, given the narrower body, is more similar to the interior space of the trailer you're considering), and it can not keep up when it's anything more than 80 degrees. But the 15K in our 25-footer is outstanding, and we won't have anything but from now on, even though our Yamaha 2400 generator won't run it by itself.
Ben & Molly (but Ben never types, so it's always Molly )
Midamrail is offline   Reply With Quote
Old 08-07-2008, 08:36 AM   #13
bookman
bookman's Avatar
Profile:  1970 27' Overlander
youngstown , Florida
Do you really want to SWEAT a few bucks from now on????
bookman is offline   Reply With Quote
Old 08-16-2008, 03:31 PM   #14
REDNAX
15K units are great, but still not enough if temps and humidity are high, when one has a long trailer (and no shade).
I've been thinking that my best route would be to install two 13.5's if I ever want to start using this trailer in the summer, and not have to drive 1,000 miles to a cooler climate.
Can't say I'll actually do it, but I have seen two 34' A/S trailers from Texas with two roof A/C units.
Got my Carrier 15K BTU installed chuman70 Furnaces, Heaters, Fireplaces & Air Conditioning 2 06-22-2007 06:07 AM
new folk to this brickplant Member Introductions 4 03-10-2007 08:57 PM
11,000 BTU AC and Honda EU2000 RangerJay Airstream Trailer Forums 34 10-03-2005 07:35 AM
15k BTU A/C unit info Silvertwinkie Furnaces, Heaters, Fireplaces & Air Conditioning 0 09-21-2003 02:17 PM
btu of a/c unit Mikie 1969 Overlander 7 05-11-2003 12:43 PM
