Old 11-13-2018, 06:00 PM   #1
2019 22' Sport
Quartzsite , Arizona
Some Interior Lights Not Working...
Howdy,
2019 Sport 22FB the two ceiling lights won't work.
All others do just fine as well as other 12V that should.....
No breakers flipped....
Worked before.....
Clues?
Rounder44
Rounder44 is offline   Reply With Quote
Old 11-13-2018, 06:26 PM   #2
Full time Airstreamer
SCOTTinNJ's Avatar
2014 30' FB FC Bunk
Anywhere , USA Living.Somewhere.Yonder
I had a similar issue and it turned out that a connection behind a switch had worked it's way loose. Tightened it back on and all is well. Maybe check behind the switch.
@living.somewhere.yonder | Instagram
SCOTTinNJ is offline   Reply With Quote
Old 11-13-2018, 06:48 PM   #3
2019 22' Sport
I'll check but it hasn't moved and inch... nothing has changed...
R44
Some of my 12volt is working but some not. b1gflip Electrical - Systems, Generators, Batteries & Solar 4 03-13-2018 08:35 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 11:04 AM
Front interior light not working, middle and rear working? jonnyo Lights - Interior & Exterior 4 04-03-2016 10:16 PM
1976 Argosy 28 Brake lights, turn signals, running lights not working!!! Argosy1976 Batteries, Univolts, Converters & Inverters 6 06-22-2012 06:20 AM
Some lights not working + need help installing track idaramin Interior Restoration Forum 6 05-14-2012 03:31 PM
