Old 02-15-2015, 07:12 PM   #15
jm2
jm2's Avatar
2002 25' Safari
1977 20' Argosy 20
northern valley , new jersey
I believe that you're right, as I do have some recollection of that post, too, but could not find it, myself....
best,
Joseph & Gabrielle
Simplicity is the ultimate sophistication - Leonardo da Vinci.
WBCCI 2087 - AIR 3144 - TAC-NJ2
http://defendwally.org/
jm2 is offline   Reply With Quote
Old 02-15-2015, 07:32 PM   #16
2012 20' Flying Cloud
Bishop , California
I lived for 25 years in Mammoth Lakes, CA which is a major ski resort in the Sierra Nevada Mountains. I would store the Airstream at a lower elevation in the winter because the snow load would be more than almost any RV could hold. When I had the Airstream at my home a few times during snow storms, I would regularly remove snow very carefully from the roof using a strong shop broom while standing on a secure step ladder (not leaning against the side of the vehicle). Make sure your ladder is absolutely secure and will not slip on the snow or ice. I would remove the snow down to about 4-8 inches of the roof line to avoid and scratches. I photographed the roof area during the summer and would review it before doing the removal. You want to be very careful not to drag the broom on the antenna, AC cover, etc and cause possible damage. The big danger you want to really avoid is having the snow turn into an "icecap" which could cause major damage. Good luck
billdunlap is offline   Reply With Quote
Old 02-15-2015, 08:16 PM   #17
1971 31' Sovereign
alta vista , Kansas
I believe the picture you were referring to was here:
http://www.airforums.com/forums/f261...-67532-48.html
Stan
sascher is offline   Reply With Quote
1/2 ton tires- load C to load E John Tires 75 03-20-2009 09:15 AM
Load bearing or not load bearing? Petethefeet Ribs, Skins & Rivets 3 04-27-2008 07:36 AM
Snow Load Navigator Winterizing, Storage, Carports & Covers 54 02-03-2007 02:13 PM
Snow and SNOW.. 53flyingcloud Off Topic Forum 9 01-23-2005 02:32 PM
Snow and a fair amount of it.... Silvertwinkie Our Community 3 03-04-2003 11:12 AM
