Old 01-10-2011, 06:42 PM   #15
AirEPotter's Avatar
2011 27 FB International
Lubbock , Texas
Originally Posted by pmclemore
I'm kinda with Azflycaster on this. But - Jeez - please don't let us just do things randomly. If you don't know what you are plugging into, let's don't plug into it.
Give us a chance to help before trouble begins to cost.
Pat
It's called a mistake. Fresh water intake and sewer flush are two inches apart. I was distracted and hooked into wrong one. My fault obviously.
AirEPotter is offline   Reply With Quote
Old 01-10-2011, 06:45 PM   #16
_
Originally Posted by pmclemore View Post
I'm kinda with...
there is NO reason to run pressurized air into the btf...
the line goes UP and then DOWN to tank level.
so water drains OUT of the line naturally if the head isn't obstructed,
or the check valve plugged.
the line is butyl not pex and not rated to the same pressure as the normal plumbing.
it's also buried in the trailer wall behind cabinetry and not easy to access if it starts leaking.
in fact NOTHING on the black tank side is rated for 'pressure'
so if the vent is obstructed (wasps/turds/paper) ANY pressure is bad.
there are several places that leaks or blown seals could happen with pressure.
_________
while the op probably did no harm since it is new,
the tank heads tend to PLUG up over time.
that means AIR in the line would never reach the tank or tank vent.
so pressurized air (or water) would escape at the check valve or a joint.
neither are good things.
gravity drains the btf lines.
______
the owners manual is reasonably specific,
about HOW and where to blow out lines with compressed air...
the btf line isn't part of that process for good reasons.
cheers
2air'
Old 01-10-2011, 07:05 PM   #17
RichHog's Avatar
1972 25' Tradewind
Houston , Texas
I recently made the mistake of hooking the city water line into the Black Tank Flush line. No I didn't open the dump drain. Went into the kitchen to test water pressure at the sink and something seemed different as I heard water swirling around as I was filling up the black tank. Fortunately I went back outside and caught the mistake before I had water coming out of the toilet. Didn't have these things in the 72 Tradewind to flush out the tank like the 06 Safari.
RichHog is offline   Reply With Quote
Old 01-10-2011, 07:55 PM   #18
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
I hope you tossed that hose after...
I also hope the OP did not use that adapter on the H20 line and blow into the system...yuck!
Nothing like a stomach bug to ruin a good trip.
*Life is Good-Camping all around Continent*
*Good people drink good beer-Hunter S Thompson*
BillTex is offline   Reply With Quote
Old 01-10-2011, 08:01 PM   #19
_
this would have been AWARD worthy...
I recently made the mistake of hooking the city water line into the Black Tank Flush line. No I didn't open the dump drain. ...
good goof! thanks 4 sharing.
there used 2b a thread here, the theme being...
"the monthly dumbA, bonehead screw up award"
and folks would post their goofs, the goofier the better.
eventually some1 would claim the monthly award,
and keep it till a better boneheader was posted.
(sorta like the monthly photo contest, but funnier and more useful)
almost every mistake was a learning point,
from a class we've all taken.
and seldom was ne1 preached 2 about their screw ups.
the solution almost EVERY time was...
"hey don't do that"
the thread vanished in a server upgrade or under protest from a few jack wagons...
it should be REvisited and restarted...
cheers
2air'
Old 01-10-2011, 08:08 PM   #20
AirEPotter's Avatar
Lubbock , Texas
"hey don't do that"
cheers
2air'
This does not make me feel any better!
Old 01-10-2011, 08:12 PM   #21
_
*need a tissue?
cheers
2air'
Old 01-10-2011, 08:13 PM   #22
AirEPotter's Avatar
Lubbock , Texas
need a tissue?
cheers
2air'
Wait till I see if I broke something. Then I'll answer.
Old 01-10-2011, 08:15 PM   #23
_
IF ya want the A-ward,
ya gotta break stuff.
cheers
2air'
Old 01-10-2011, 08:17 PM   #24
AirEPotter's Avatar
Lubbock , Texas
cheers
2air'
I know. I know. :head down
Old 01-10-2011, 08:28 PM   #25
_
or genuflex,
just sayin...
cheers
2air'
Old 01-10-2011, 08:30 PM   #26
AirEPotter's Avatar
Lubbock , Texas
or jenuflex,
just sayin...
cheers
2air'
You lost me. Jenuflex?
Old 01-10-2011, 08:32 PM   #27
_
ah, wiki it, but with a G...
cheers
2air'
Old 01-10-2011, 10:03 PM   #28
Chief Chili Cook
newroswell's Avatar
2010 30' Flying Cloud
Bakersfield , California
AirE, you stick with us and we'll set you straight. You do have a hose spreader, don't you?
newroswell is offline   Reply With Quote
30 amp 240 mistake tcrum Batteries, Univolts, Converters & Inverters 16 09-01-2011 11:05 AM
Rookie from Flagstaff, AZ! Joyfulgirl Member Introductions 6 08-23-2011 07:50 AM
Novice Mistake! Please Help! Hopetoday General Repair Forum 11 08-16-2011 07:39 AM
Rookie from the south safarijohnny Member Introductions 2 06-22-2011 06:15 PM
Can you please tell me... the soon to be rookie. aname4me Full-Timing, Winter Living & Workamping 33 02-01-2011 06:28 PM
