Old 12-24-2018, 08:46 AM   #1
2019 22' Sport
Quartzsite , Arizona
Refilled Propane; Furnace Wont Fire Up...
Howdy,
2019 Sport 22FB
Looks like by refilling propane tank I lost furnace. Actually turned off and removed both as I did so with wrong one first.
Water heater and stove work fine.
Fan goes on for ~15 seconds, then off.
Looks like an Atwood and instructions mention an led light but I can't find any light..... Mention of sail switches as well but I'll be danged if I can find those...
Do I have to remove the access panel out side? The 4 screws to find this?
I'm convinced operator error of some sort as it had been working fine the past week.
Thanks!
Warren
Rounder44 is offline   Reply With Quote
Old 12-24-2018, 08:51 AM   #2
2017 25' Flying Cloud
Lawrenceville , Georgia
Warren does your unit have a heat pump ?
If so try using the HP above freezing and the furnace below freezing.
TANZER099 is offline   Reply With Quote
Old 12-24-2018, 09:06 AM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
How many times have you tried to run it? You may have air in the line
Old 12-24-2018, 09:06 AM   #4
2019 22' Sport
Gosh...
I don't think so.....
The manuals are 90% legalize and warnings and does spell out much....
I'm reading the installation manual as I don't seem to have a user manual which I'm directed to read....
Looks like I need to access the furnace and turn off the valve there or propane tanks and...... it's confusing and may be an initial start up proceddure...so I'm not doing anything quite yet...
Warren
Old 12-24-2018, 09:09 AM   #5
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Your dometic AC should have heat pump option. It will be listed as HP on the thermostat.
Old 12-24-2018, 09:11 AM   #6
2019 22' Sport
6 or 7 time maybe....
Looks like too many times can get a hard lock out requiring a reset I'm not sure how to do..
If I could find that led I could get some sort of diagnoses!
Warren
Old 12-24-2018, 09:14 AM   #7
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Nevermind the Sports have electric heat strips
Old 12-24-2018, 09:15 AM   #8
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Warren
LED will be on the printed circuit board. Access through outside
Old 12-24-2018, 09:20 AM   #9
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
Here you go
ID:	330269   Click image for larger version
Old 12-24-2018, 09:36 AM   #10
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Cycle the store switch then retry the furnace
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 12-24-2018, 10:06 AM   #11
2019 22' Sport
Well I could not find an led but quickly noticed a reset switch and tried that and have heat! Lets see if it lasts!
My panel photo is attached. Perhaps an led behind those wires but I gave the reset a shot first since I saw no light...
Thanks for the help!
Merry Christmas!
Warren
Old 12-24-2018, 10:25 AM   #12
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
Are you on shore power? What does your batteries read? If below 12.2, then the furnace fan will initially come on and then shut off. You need sufficient battery power to run the furnace.
glcmranger is offline   Reply With Quote
Old 12-24-2018, 10:32 AM   #13
Overkill Specialist
GMFL's Avatar
Dadeville , Alabama
LED Locaton.
Old 12-24-2018, 10:51 AM   #14
2019 22' Sport
Shore power!
Batteries 100% though!
Thanks!
I'll note that for later!
W
furnace wont shut off! seismicfish Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-31-2013 06:49 PM
furnace wont run with dust cap on steven2themax Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-01-2011 06:41 AM
FIRE! Electrical Short and Slide-Out Controller Fire rjd Electronics & Connectivity 10 07-24-2009 07:47 AM
furnace wont start matthew NYC Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-15-2009 05:11 PM
FiRe, FiRe, FIRE, in the AiRsTrEaM!!!! TheBigRedTruck On The Road... 41 12-13-2008 10:29 PM
