Old 12-25-2018, 04:30 PM   #29
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
A sail switch is mounted right in front of blowing air. Its purpose is to flip the switch just in case there is sufficient air flow; and, conversely, not to flip the switch just in case of low or no air flow.
A fly in the ointment of many sail switches is that they can fail if they become too dusty; "repair" thus amounts in some cases to blowing them out with compressed air. (In the case of some Suburban furances on older Airstreams, I also note that the manufacturer slightly increased the size of the sail itself.)
Here's a shot of one flavor of the sail switch. You can see the arm that operates via air flow to flip the switch.
Lynn
WBCCI 21043
Old 12-25-2018, 06:22 PM   #30
2015 19' International
Beaverton , Oregon
Tough to say. I have a 2015 19' International and all of the furnace bits are accessible from the outside, once the four screws that secure the outer cover, and maybe two others, are removed. The sail switch is pretty obvious on mine.
The manual could be helpful, too.
http://bryantrv.com/docs2/docs/hflamefurn04.pdf
pg
pgeller is offline   Reply With Quote
Old 12-26-2018, 09:51 AM   #31
2019 22' Sport
Quartzsite , Arizona
Well...
Airstream is taking a LONG week end... No support available....
Anyone know if they're gonna show up this week or are they off through the 1st?
I hope they're nice and warm......
sigh...
W
Rounder44 is offline   Reply With Quote
Old 12-26-2018, 10:02 AM   #32
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Rounder44,
Maybe if you post pic of outside of furnace someone can tell you how to open it up and as mentioned look for code light.
Also do you have the furnace mfgr manual and checked it’s troubleshooting guide ?
Wish I was off this week too.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 12-26-2018, 10:15 AM   #33
2019 22' Sport
Originally Posted by GCinSC2 View Post
Rounder44,
Gary
Thanks!
I got it opened and found the code indicating sail switch etc...
I just don't know how to get at it without yanking the entire furnace out and possibly voiding warranty. It's a 2019 Sport 22FB. 1 week on the road...
The manual is full of warnings and legalize and seriously lacking on details. I'm glad Atwood was able to save a few cents and print a boiler plate manual for all their furnace but useless in a problem situaltion....
Thanks!
W
Old 12-26-2018, 10:42 AM   #34
GCinSC2's Avatar
Can you post Atwood model number for furnace?
Also couldn’t hurt to post pic of furnace with doors open so folks can peak at it and it’s wiring.
Can’t reread all of your posts now but if you tried to turn it on what does it do? Nothing, tries to start but doesn’t fire up etc.
S/OS #001
Old 12-26-2018, 11:25 AM   #35
2019 22' Sport
Not sure of model number but attached the photo again.
Fan goes on, won't fire up, turns off after ~15 seconds. Led light blinks once every 3 seconds.
I attempted to follow the start up instructions but fan shuts off too quick which indicates sail switch or such.
All attempts have left me with "turn off and call dealer" algorithms....
Seems like it could be a simple fix if not camped out and parts available....
W
Old 12-26-2018, 11:44 AM   #36
GCinSC2's Avatar
Ok long shot time.
Power OFF.
Check any possible connections by slight wiggle and push on to seat any wire crimped to spade or other connections. Any that have a screw connection just wiggle and slight tug.
This is a simple POWER OFF connection inspection. And that black can left center with reddish connection might be a capacitor. Caution might be holding a charge.
Gary
S/OS #001
Old 12-28-2018, 09:10 AM   #37
2019 22' Sport
Fixed!!!!
Connection issue! I pulled off the connections again and really worked them and it has fired up constantly!
GREAT RV tech in Quartzsite coached me through the issues. He informed me than in 36 years of RV repair fully HALF of the furnaces he goes to repair fix them selves when by the time he gets them pulled and to his bench!
HALF don't need any more than connections cleaned up!
Very weird if you ask me.....
I'm starting to see the wisdom of a spare board and read a little about the Dinosaur boards that seem to be an upgrade...
The tech also strongly suggested a Blue Flame brand replacement furnace or part of explaining it has a built in thermostat..... Phone connection was poor and we kept getting distracted so not sure exactly about the Blue Flame...
Any other thoughts to put the furnace issues to bed once and for all?
W
Old 12-30-2018, 10:26 AM   #38
Long Island , New York
There is a new thread carrying on this conversation FYI:
http://www.airforums.com/forums/f459...lp-190634.html
Old 12-30-2018, 01:43 PM   #39
Winedog
2014 25' FB International
Walla Walla , Washington
If nothing else works, there is a reset switch on the furnace. The unit must be powered for the switch to work.
winedog is offline   Reply With Quote
Old 12-31-2018, 12:28 AM   #40
Southern , Colorado
It sounds like you are warm for now!
Since this all started when you reconnected your propane bottles, here is a not-unusual happening:
New propane tanks and Acme connectors now (for a decade or two) have a fast-flow close valve. In other words, to prevent a fire should you sever a hose or other downstream connection, the valve senses this and shuts down - sometimes with a minimal flow. This fast flow often comes when you open the tank and fill the unpressurized lines with gas.
The solution to this is to shut off the propane tank completely, then open slowly while the lines fill.
It's always #1 in troubleshooting propane, especially if you have disconnected the tanks.
2010 M-B ML350 Bluetec
2011 Lance 2285 27' TT
mikapen is offline   Reply With Quote
Old 12-31-2018, 05:50 AM   #41
2015 30' Flying Cloud
Port Sanilac , Michigan
Maybe the sail switch
I had same symptoms. Fan for a while then nothing. There is a switch that detects that the fan is working. Called a sail switch. On my unit it is easy to access with the exterior panel removed. It is screwed to the fan housing right in front. Easy to check with a meter if it’s working. In my case I removed the switch, checked it with a meter, it checked ok, then I put it back in and all is well. I think it had stuck in the on position which is a no go for the furnace logic. I ordered a new one and it lives in my tool box as a back up.
pontzdav is offline   Reply With Quote
Old 12-31-2018, 07:07 AM   #42
There is a later thread on this FYI.
furnace wont shut off! seismicfish Furnaces, Heaters, Fireplaces & Air Conditioning 0 08-31-2013 07:49 PM
furnace wont run with dust cap on steven2themax Furnaces, Heaters, Fireplaces & Air Conditioning 3 02-01-2011 07:41 AM
FIRE! Electrical Short and Slide-Out Controller Fire rjd Electronics & Connectivity 10 07-24-2009 08:47 AM
furnace wont start matthew NYC Furnaces, Heaters, Fireplaces & Air Conditioning 5 02-15-2009 06:11 PM
FiRe, FiRe, FIRE, in the AiRsTrEaM!!!! TheBigRedTruck On The Road... 41 12-13-2008 11:29 PM
