Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living
Old 09-08-2009, 07:30 AM   #1
chromegnome's Avatar
Profile:  1971 31' Sovereign
Burlington , Ontario
Re-Insulating 71 Sovereign
Hello all. I have a gutted 71 Sovereign on my hands and I am looking for some advice on re-insulating the inside. I am up in Canada and want to be able to use the Airstream in the winter months (daring I know) as a ski cabin. If I were to drill out the rivets on the inside skin to remove the old fiberglass insulation and then maybe spray insulation back in, am I ever going to be able to rivet it back on, or is there an alternative material I could use?
chromegnome is offline   Reply With Quote
Old 09-08-2009, 08:50 AM   #2
Profile:  1971 25' Caravanner
scappoose , Oregon
First of all, welcome to the forums, and congrats on your "new" AS.
This subject is huge, checking in the forum section, with search function, will bring up multiple threads, covering all aspects of insulation in use for AS.
rangebowdrie is offline   Reply With Quote
Old 09-08-2009, 09:24 AM   #3
astewart's Avatar
Profile:  1974 31' Sovereign
Stoney Creek , Ontario
Spay Foam Insulation
As I recall there was a "don't do it" post from Inland RV a while back re: the spray foam insulation. I am not an expert buy check carefuly as it may stiffen things up too much and cause issues for you. The fibreglass has a lot of give so the shell can flex.
Good luck and keep posting. I'm thinking of some winter trips as well but wonder about the water and grey/black systems.
Alex
astewart is offline   Reply With Quote
Old 09-08-2009, 10:43 AM   #4
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
use Prodex
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 09-08-2009, 11:01 AM   #5
Area 63 Productions
Commercial Vendor
Profile:  1963 26' Overlander
1958 22' Flying Cloud
1963 19' Globetrotter
Orange , California
Send a message via Skype™ to Area63
We have used Prodex in several projects, and it has worked quite well, is light weight, esy to install, and won't rot or mildew. It is crucial that there's air space on both sides of the PRodex for a truly efficient R-value. It is also important to seal it tight against the ribs with their adhesive tape, and where pieces of insulation overlap.
Good Luck with your project!
Uwe
www.area63productions.com
Area63 is offline   Reply With Quote
Old 09-21-2009, 11:33 PM   #6
Thanks everyone for your replies. My next question is, has anyone removed any of the inside panels? and how hard are they to re-install? Looking at it, I'm thinking this could get tricky. Thanks again in advance.
Old 09-22-2009, 12:29 AM   #7
Silver Mist
LI Pets's Avatar
Not that hard to re install except the rounded corners may need an extra pair of hands to line them up.
WBCCI
insulation, skin, winter
insulating the aft under bed storage wmarsha Exterior Storage Compartments & Access Doors 3 08-02-2009 05:07 PM
Insulating for winter living RTW Winter Living 0 11-12-2007 05:22 PM
Questions - Re-insulating for Cold Weather BrockLives Winter Living 7 08-31-2007 01:25 PM
Wanting info on insulating iowaargosy Argosy Motorhomes 2 06-25-2007 09:16 PM
73 sovereign joel For Sale & Wanted 0 09-29-2003 08:27 PM
