Old 01-13-2015, 07:51 PM   #1
Roaring Fork Valley , Colorado
Plugging in to a house
So I am living in my airstream...I'm currently living in an RV park but I have an opportunity to park on a friend's property. She's willing to let me hook into her house. So sewer and water are easy...but what about electric?? Any thoughts or experiences with this? Constantly tripping breakers?
Thanks!
gcasson is offline   Reply With Quote
Old 01-13-2015, 08:07 PM   #2
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
You need 30 amp if you plan on using an elec heater or a/c; 20 amp will not support a/c ( it will support one 1500 watt heater).
Cochese is offline   Reply With Quote
Old 01-13-2015, 08:10 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Greetings from the Florida Panhandle
Welcome to the Forums. We're glad to have you with us.
As to your question, you would be best to install a dedicated 30 amp RV outlet at the house. You can try working off of 15 and 20 amp household outlets, but will most likely encounter electrical problems.
I would suggest having a licensed electrician do the 30 amp installation. It will probably cost in the vicinity of $500.
Brian
SuEllyn & Brian McCabe
Old 01-13-2015, 08:10 PM   #4
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Btw, if you have an electrician friend, you might be able to get them to add a 30 amp rv outlet pretty reasonable , it shouldn't cost too much regardless .
Old 01-13-2015, 08:38 PM   #5
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, we spent several weeks in a friend's driveway and it worked good for us. Sewer was quite a distance but I made it work. Water was no problem. And we had a 20 amp outlet that only tripped when using our air conditioner and the micro-wave at the same time. [re-set the breaker and all is well]
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-13-2015, 08:43 PM   #6
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
For sure, a dedicated 30 Amp, or if you have a desire for lots of electricity usage simultaneously i.e., hair dryer, A/C, microwave, etc. a 50 Amp might be good if you have an AS with 50 Amp input (two A/C units.)
But, they all cost money...
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 01-13-2015, 08:45 PM   #7
withidl's Avatar
2002 31' Classic
Houston , Texas
I keep my 31' 2002 ASCL parked in my back yard hooked up to a 20 amp receptacle. This is done by using an adapter which is a dual male into the 20 amp female receptacle with a 30 amp female on the opposite side (adapter can be sourced from most RV suppliers). This adapter allows for 2 times the contact area of the male/female contacts which reduces resistance and thus heat.
The wiring I use is a #2 gauge copper of which I happened to have 150 feet laying around. I used it all instead of shortening it, but because of its thickness (~ the diameter of your little finger) there is essentially no voltage drop to the 30 amp umbilical of the Airstream.
With this set up I have no trouble running the air conditioner and the converter. While running, my voltage never drops below 119 volts and the connections stay cool.
Bottom line is use a large surface area adapter connector at the receptacle and a very large cable and you will have all 20 amps and good voltage available. It's probably cheaper than the electrician.
withidl is offline   Reply With Quote
Old 01-13-2015, 08:46 PM   #8
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
I hate reiterate on the power source....what looks like a 30 amp service in the house IS NOT> That is a 22v outlet probable used for an electric drier. DON'T try it. A 30 AMP RV outlet is a different animal.
Old 01-13-2015, 08:48 PM   #9
2007 22' International CCD
The parts are cheap, but the knowledge to do it right is what you pay for.
Note: if you hire an electrician be very clear its a 30 amp 115 volt single phase connection. Others on the forum have had major issues when an RV 30 amp outlet was hooked to 220 volt incorrectly. Beware of electricians unfamiliar with what you need.
Me, I know what I'm doing and did it myself...just be careful.
KE4GNK/AE
Old 01-13-2015, 08:50 PM   #10
2005 19' Safari
GLENDALE , AZ
Bought this outlet box at home improvement store:
Shop Eaton 30-Amp Overhead or Underground Temporary Power Panel at Lowes.com
Neighbor's friend's son is an electrician; paid him $75 to install it on a Saturday. He had conduit and wires, but I had to buy a 30 amp breaker, which I think was about $15.
IMPORTANT NOTES:
1. Make sure electrician knows that THE RV OUTLET IS 110 VOLTS, NOT 220 VOLTS.
2. BEFORE YOU PLUG YOUR AIRSTREAM'S SHORE POWER CORD INTO THE NEW OUTLET, make sure to have the electrician test the newly installed 110 volt 30 amp RV outlet with a voltmeter and a 110 volt outlet tester.
Can you guess? Yes, ours was wired wrong.
110 volt outlet tester: GE 3 Prong Receptacle Tester - Walmart.com
Old 01-13-2015, 08:58 PM   #11
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
For temporary, it depends on your friend's home's setup. The 'best' solution is a 'dedicated' line. It will provide the safest, most usable setup.
I installed my own 50 AMP outlet... it is handy because I can also use it to power my welding machine now... isn't that great!!!???? Ok, I thought it was kewl...
Anyway, in most areas it is now necessary to have a LICENSED ELECTRICIAN install the circuit... In some areas, you may also have to pay for a government official to "oversee" that it is installed properly... isn't that NICE...
That-a-way you will be able to have any issues with the circuit 'covered' by the homeowner insurance in case of an 'issue'.... better play the game....er, protect your friend.
Now, presuming your AS is a 30 AMP, the same holds true. Get it done properly.
If, however, all the above doesn't fit, all you 'need' is enough power to keep your Converter powered... and enough propane to keep you warm... don't expect to run a space heater with a 10 amp.. and perhaps even a 15 amp circuit... "can" you.. perhaps, depending upon many factors... but, why risk your friend's courtesy or damage to anyone's property.. even 'accidental', of course...
Good luck!
Peace and Blessings..
Channing
WBCCI# 30676
Old 01-13-2015, 09:01 PM   #12
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Oh.. a separate note.. take action to ensure your cord is protected from rain, damage, etc..
Channing
WBCCI# 30676
Old 01-14-2015, 05:47 AM   #13
Thanks so much for all the responses!! I was hoping to not have to install a dedicated 30 amp breaker...and it sounds like it's at least worth a try to run it off the 20 amp system first.
Thanks once again for the help!
Gavin
Old 01-14-2015, 05:56 AM   #14
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
X2
Been my experience also.
Plugging in At Home henw Electrical - Systems, Generators, Batteries & Solar 65 11-30-2015 10:28 AM
20 Amp GFI breaker blows when plugging in New IOTA Converter Tartimisi Batteries, Univolts, Converters & Inverters 7 05-03-2013 03:07 PM
Plugging holes on the A frame Tino643 General Repair Forum 2 04-10-2013 07:37 PM
Blowing Fuses When Plugging Into Shore Power 1hank1 Electrical - Systems, Generators, Batteries & Solar 1 04-24-2012 08:29 PM
Lights quit working after plugging cell phone charger into cigarette lighter hagnik Lights - Interior & Exterior 6 06-20-2011 09:57 AM
