Old 01-17-2015, 10:48 AM   #43
cameront120's Avatar
1972 25' Tradewind
Don't confuse perimeter drain/storm water cleanouts for a sewer cleanout. They aren't the same thing.
North Vancouver, BC
Old 01-17-2015, 10:55 AM   #44
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, when we had our new house built, I told the contractor several times to make sure that my 30 amp outlet was 120 volt, not 240. I tested it before plugging my trailer into it. If the electrician can read, the box that the receptacle comes in says 30 amp / 120 volts. And the part it's self says 30 amp / 120 volt.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-17-2015, 03:04 PM   #45
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Some may not read the label. Because they think they know what it is. Because it looks similar to a 240 volt outlet. They wire it that way.
Old 01-17-2015, 09:08 PM   #46
2007 22' International CCD
In my experience, when you hear a plumber or an electrician tell you "I've got 30 years experience, don't tell me how you want to do X", fire them immediately.
Every time I've heard that, I've spent A ton of time and money fixing what they screwed up. Like all the frozen pipes that burst in my house because the plumber did not put a shutoff and drain for the hose connections. Or the time the 'experienced' electricians mixed up the phase and neutral on a huge power panel at work.
I get nervous when they don't listen or read the directions on the box the hardware came in....
KE4GNK/AE
rmkrum is online now   Reply With Quote
Old 01-17-2015, 09:20 PM   #47
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Years of experience???
Could be one year of experience 30 times.
Old 01-17-2015, 09:31 PM   #48
Salem , Oregon
Images: 18
Hi, we had that discussion at work, way back in the 70's. And the come back line was, "Thirty years of experience means nothing if you have been doing it wrong all of that time."
2005 Safari 25-B
Old 01-17-2015, 10:33 PM   #49
Yup. It's still true.
You may or may not be amazed at how often the '30 years of experience' phrase signals 30 years of bad moves...
I've gotten into some real knock-down drag out arguments over basic engineering concepts like wire size versus circuit breaker size. It's just amazing how hard it is to get folks to understand simple stuff.
KE4GNK/AE
Old 01-18-2015, 05:12 AM   #50
Gainesville , Florida
Agree with Robersunrus. I worked at a car dealership and at the morning sales meeting the owner was telling the salesman that he had been in the business of selling cars for thirty years. One of the salesmen spoke as a spokesman for the staff and told him maybe he was doing it wrong. After they were all fired we had technicians and parts people working the sales lot until new salesmen were hired. It was fun. Peace, jim
Old 01-18-2015, 10:40 AM   #51
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
To Rolland:
Thanks for your clear and concise directions, especially the testing with a meter.....always good before using, IMO
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 01-19-2015, 08:55 AM   #52
Airjeep
Airjeep's Avatar
2012 27' FB Eddie Bauer
Zurich , Ontario
One should also consider using a ground fault circuit interrupter for any circuit used out doors. It is code in some areas.
One time when unplugging a block heater on a drizzle day, got a shock!
At home all outdoor circuits are on ground fault circuit.
Cheers, John
Airjeep is offline   Reply With Quote
Old 01-19-2015, 09:35 AM   #53
dznf0g's Avatar
Oswego , Illinois
Someone in the know correct me...I don't think 30 amp RV circuits are GFI...even if they are outdoors.
-Rich-
Old 01-19-2015, 11:49 AM   #54
Typically they are not. Code does not require it, my AS has GFI on wet area outlets internally. An extra GFI on the RV outlet would potentially cause false tripping.
Should plug in RV cable with breaker off to prevent shock or arcing at the plug. Then flip breaker on. Breaker off first when unplugging, then disconnect.
Of course, the careful person either has a smart surge protector in the AS or tests the RV outlet with a meter or tester first.
KE4GNK/AE
Plugging in At Home henw Electrical - Systems, Generators, Batteries & Solar 65 11-30-2015 10:28 AM
20 Amp GFI breaker blows when plugging in New IOTA Converter Tartimisi Batteries, Univolts, Converters & Inverters 7 05-03-2013 03:07 PM
Plugging holes on the A frame Tino643 General Repair Forum 2 04-10-2013 07:37 PM
Blowing Fuses When Plugging Into Shore Power 1hank1 Electrical - Systems, Generators, Batteries & Solar 1 04-24-2012 08:29 PM
Lights quit working after plugging cell phone charger into cigarette lighter hagnik Lights - Interior & Exterior 6 06-20-2011 09:57 AM
