Old 10-29-2016, 08:55 AM   #1
SkatiePower's Avatar
beecher , Illinois
Our 1991 34' Classic Renovation
Hello,
I wanted to start a thread about the Airstream renovation my wife and I are working on. We will be full-timing in Northern Illinois with our beagle, so our modifications will be geared toward keeping the Airstream warm in the winter. Here is where we are at so far.
Bringing it home.
It was mostly gutted when we got it. Starting to remove the walls the next day. It took forever to figure out how to remove the top center piece. Apparently it is supposed to slide out, but we had to pull down on it and pull it out.
Hot water heater had a leak. We plan to replace with tankless anyway, but the floor was destroyed.
Another source of water damage. PO had a tire blow out that took out a section of belly pan.
More water leakage. Both of the inner wheel wells had holes in them. We will be patching them with SeamerMate and aluminum.
Removing the subfloor. We used a hole saw, but didn't think to use a template like others have, which probably would've been easier.
The PO's wiring for the brakes... This will be removed and done properly with solder and heatshrink.
Front half of belly pan off.
One broken outrigger Haven't decided its fate yet.
I will try to take more pictures of the process from hear on out.
SkatiePower is offline   Reply With Quote
Old 11-05-2017, 06:44 AM   #2
Dreamnsilver's Avatar
1988 32' Excella
maumelle , Arkansas
Beautiful exterior!
Dreamnsilver is offline   Reply With Quote
Hello all, Our 'Valentine' is the love of our life, and fast becoming our 24/7 addict errol108 Member Introductions 2 09-12-2016 10:45 PM
1965 Safari: MayBelle, our renovation doctor2xFour Interior Restoration Forum 1 06-16-2015 10:50 AM
1991 Airstream renovation woodmon8 General Interior Topics 0 03-21-2015 04:45 PM
Our Shack :: 1991 Airstream Excello HowieE Airstream Registry Discussions 0 05-04-2012 06:17 PM
New 1991 Land Yacht (our first RV!) foxtail1 Land Yacht/Legacy Motorhomes 8 11-12-2011 09:27 AM
