Old 10-08-2018, 11:00 PM   #1
Raminc's Avatar
Wasilla , Alaska
New to solar and winter is coming
HELP!! I'm in the process of preparing the Safari 23 for its first Alaskan winter. Before I disconnect the batteries how should I go about stopping the flow of energy from the solar panels to the batteries?
Thanks in advance
Raminc is offline   Reply With Quote
Old 10-08-2018, 11:31 PM   #2
2015 30' Classic
Pleasanton , California
Should I assume that you have a factory solar installation? If so, I would try to locate the solar controller and disconnect the yellow wire coming from the positive terminal of your panels to the controller. This will prevent the solar controller from trying to charge the 12 V buss if your panels are exposed to light.
Al, K6IV
2015 30' Classic, "Chez Nu"
2014 RAM 2500 w/Cummins Diesel
ProPride Hitch, 400 W Solar
alano is offline   Reply With Quote
Old 10-08-2018, 11:50 PM   #3
Raminc's Avatar
Wasilla , Alaska
Yes these are factory installed I will follow this advice when I get a chance. Hopefully tomorrow thanks.
Old 10-14-2018, 10:40 AM   #4
2016 25' International
Deerfield , Massachusetts
You really should have a cutoff switch installed between the panels and the solar controller. Easy to do.
thiel is offline   Reply With Quote
Old 10-14-2018, 10:52 AM   #5
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
Thanks in advance
If you are leaving batteries in the trailer, the solar will act as a trickle charger keeping the batteries topped off thus from freezing.
Mattirs is offline   Reply With Quote
Old 11-06-2018, 03:32 PM   #6
2018 30' Classic
Jacksonville , Florida
…….or just cover the panels.
Overstreet is offline   Reply With Quote
Old 11-06-2018, 03:37 PM   #7
Half a Rivet Short
Carlisle , Pennsylvania
Hi
With factory solar, there is a fuse in the positive wire coming from the panels. If you want to disable solar, just pull that fuse. It's not at all clear *why* you would need to do that ....
Old 11-06-2018, 05:43 PM   #8
2007 22' International CCD
Personally, it's nice to have cutoff switches in the wiring from stuff that generates current, solar panels are not that dangerous, but batteries can be a real flash burn hazard inside a tin can...just sayin'
Old 11-07-2018, 09:32 AM   #9
Half a Rivet Short
Hi
Generally that's why we have fuses ....
Old 11-07-2018, 10:53 AM   #10
True, fuses sort of work, but are not that convenient for maintenance shut-downs.
When I have my fingers in the hardware, I much prefer a positive disconnect that I don't have to crawl under the couch to get at. A nice Blue Sea Systems M-series disconnect switch is a twist of the wrist away from rendering a circuit safe. Then it gets a warning sign and a piece of duct tape to make it darn hard to "helpfully" turn it back on...
One on the battery positive, the other on the hot side of the solar panels would be the minimum, IMHO. A similar switch on the inverter input, assuming I had one..
"Tag-out, Lock-out" procedures have saved my butt too many times working on shipboard systems and big 440 volt three phase-powered industrial systems--it's not just a good habit, it's heavily enforced by OSHA...and trust me, those folks are NO fun to deal with when something or someone screws up!
Personally, I figure being alive and undamaged is way superior to the alternatives...
Old 11-08-2018, 08:13 AM   #11
Half a Rivet Short
Hi
First off, given the voltages involved, (this *is* a 12V system) the odds of electrocution are pretty slim ( = worry more about getting hit by space debris). Putting 440V into the same category as 12V is more than just a stretch.
Old 11-08-2018, 08:32 AM   #12
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thanks in advance
So...your going to disconnect/remove the batteries for Winter storage? (good idea where you are)
Just insulate the battery cables, the solar current won't go anywhere. Just as the charge current from the converter doesn't when plugged in with batteries removed.
Disclaimer...at times my comprehension does not match the intent of the written word.
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Winter is coming... k9jackie Sprinter and B-van Forum 18 10-22-2015 07:35 PM
Winter Visitor Coming to Florida Anyway? Mary Burris Full-Timing, Winter Living & Workamping 2 11-28-2012 08:16 PM
Winter is coming to Texas...LOL THEPILL Our Community 15 11-24-2010 10:35 AM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 11:00 AM
The Airstreams are Coming!! The Airstreams are Coming!! j54mark Airstream "In the News" 7 07-07-2005 08:06 AM
