Originally Posted by Zeppelinium ..Do you have copper or PEX? I'm just curious about the plumbingin the newer Airstreams...Zep |
the water pipes are pex,
but the joints and connecting pieces are copper.
the small connecting sections attached 2 the fixtures are also copper.
______________________
Originally Posted by chrispy1 The large sewer pipe that leads from tank to just before flexible pipe connection point has some kind of wire leading to it. This wire is out of site unless you are on the ground inspecting the exposed pipes.
Anyone know what this wire is? some kind of heating wire? Is there a switch to activate it? |
hi chrispy...
most likely THAT wire is running 2 an rj11 ? connecter for the black tank sensor.
on some models the black tank sensor is located IN the last bit of 3 inch black pipe just BEFORE the main tank valve...
and on the models plumbed this way the sewer pipes are VERY low to the ground
and need attention when parking so as 2 NOT drag or bust them...
http://www.airforums.com/forums/384557-post153.html
a picture WOULD help the curious here, but
there is a schematic for this in your owners manual.
the "cult" of bunkhouse owners hang out here....
Safari 30 bunkhouse owners club!
and love to sort out the itty bitty bits that are part of this model.
join in with them and u will get LOTS of good help related to the bunkhouse.
cheers
2air'
