Old 04-16-2014, 09:46 PM   #15
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
A cast iron tub way behind the axles = sway, no matter the tongue weight.
What would a cast iron tub weigh? 400 to 600 lbs?
Shifted forward rather close to the axles a might work if a person would be very very careful with all other aft weight.
Old 04-16-2014, 11:20 PM   #16
Columbus , Ohio
It weighs 290 without water or me in it. I kept the hand shower to shower in it most the time, that way less water use. Took out walls and hoping the weight will be ok! Trying her this weel. Fingers crossed everbody. There will be updates!
Merrily merrily merrily merrily life is but a dream- so live it it!
ousl01 is offline   Reply With Quote
Old 04-17-2014, 04:58 AM   #17
hissilver's Avatar
2018 25' International
Van Wert , Ohio
Ousl01
I noticed your from Columbus....so I thought I would invite you to a NOVA Rally at Hadocy Airsteam beginning on Thursday May 1 through Sunday. We will be camping right on the lot with our Airstreams and I am certain you will be able to pick up some tips and advice. Hope to see you there.
Hissilver
hissilver is offline   Reply With Quote
New Airstreamer : 1980 Excella II gitrokr Member Introductions 1 09-16-2011 11:36 AM
Airstreamer Greetings martian Member Introductions 9 05-16-2011 11:11 PM
New Airstreamer Big Project Zog Member Introductions 5 03-12-2011 11:04 AM
New Airstreamer from Florida LomedIvrit Member Introductions 14 03-09-2011 10:09 PM
New Airstreamer from KY KYAirstream Member Introductions 3 03-04-2011 07:50 AM
