Go Back   Airstream Forums > Airstream Community Forums > Full-Timing, Winter Living & Workamping
Old 11-30-2009, 10:03 PM   #21
99Limited34's Avatar
1999 34' Limited
Darien , Wisconsin
We take a 23'' LCD with us and just wrap it in a towel and out it on the front couch. Never have had a problem with it..
1999 Airstream 34' Limited (The Cottage)
2008 F-350 Diesel
WBCCI # 4106
Steve & Jan
99Limited34 is offline   Reply With Quote
Old 12-01-2009, 06:05 AM   #22
holland , Michigan
22 inch lcd mounted to the metal folding door for older tv appiications. I place it backside down on the carpet, streetside,when traveling still hooked up to all the connections. That way it can never fall and the screen is not rubbing against anything. It has the 4 rubber mounts and set up is less than 10 seconds.
i would never travel with it on the wall. O, a new best horrible road. I40 through Oklahoma City. I mean this is the worst stretch yet. I was down to 40 mph.
safari 28 is offline   Reply With Quote
Old 12-01-2009, 07:17 AM   #23
Sky
Classic 30
Sky's Avatar
Sum Wear , Ohio
Ours sets on the floor, against the couch (trailer front), in the box it shipped in.
It rests nicely in its Styrofoam cradle. It can't fall or slide forward when I hit the
breaks. Box goes in closet after tv is setup.
"Only dull people are brilliant at breakfast" - Oscar Wilde
2500HD DMax............30' Classic
Sky is offline   Reply With Quote
Old 12-01-2009, 07:42 AM   #24
Cstar's Avatar
2006 28' Safari SE
Columbus , Ohio
Images: 20
A second vote for I40 in OKC
I wasn't going to comment on this thread since there were so many in agreement, our 32" travels on the bed (thick comforter), but the I40 comment really rang true. We came through there last September and could not believe how bad the roads were!
Corky
Cstar is offline   Reply With Quote
Old 12-01-2009, 11:09 AM   #25
Mexray's Avatar
1978 28' Ambassador
Morada , California
we used to store our 22" LCD on one of the beds also...but I was concerned about all the wear on the three plugs into the TV, from hooking and unhooking at each stop...
We don't use a wall mount, so I drilled two holes in the TV's pedestal base and through the cabinet up front where we always set the TV...this is right up front, close to the fwd windows, and so the road 'bounce' is much less of a issue...we do however, place two small foam pillows between the TV and the cabinet surface to keep the TV from doing any 'rocking' motion on it's pedestal while we're underway - and all those plugs get to stay in place...
Ray & Pat; Morada, CA
Old 12-01-2009, 11:36 AM   #26
_
the o.p. has a 32 inch tele, brand/model UNKNOWN.
these can be significantly heavier than most of the telez sold with rvs.
the weight may range from 10-30 kgs depending on model.
the o.p also has a 34 foot trayla! which means the back bed is WAY more subject to movement UP/down and sidewayz...
i would not carry a large tv in ANY position (even in the box) at the back of a 34...
although using the box/packing/upright is a GOOD idea, someplace forward inside.
while many of us do transports these gizmos horizontally,
NONE of the manufacturers ship or store them in ANY position other than UPRIGHT.
the o.p. might want to contact tech support and ask the manufacturer...
or post more details.
cheers
2air'
Old 12-02-2009, 09:26 AM   #27
More than one rivet loose
thecatsandi's Avatar
Los Alamos , New Mexico
Originally Posted by garry View Post
We travel with LCD TV face down on the bed so far no problems.
Hit the brakes hard and it will end up in the hallway. I used to travel with my computer on the bed. I had some one cut me off and brake right in front of me. The computer end up against the couch up front. It traveled on the couch from then on.
Michelle TAC MT-0
Sarah, Snowball
Old 06-29-2010, 05:28 AM   #28
MaxAB's Avatar
1977 31' Sovereign
1985 25' Sovereign
South Central Rockies... , "...'Stream'n the Dream" thru the USA
Bulkhead mounted 24"-er...
We use a wall-mounted rig for our 12VDC flat screen. It swivels around to enable us to view from either the center bunks or from the goucho...
For on road mode: I've got a bungie cord that holds the screen securely to the bulkhead. If you look closely in the attached foto, you'll see the bungie cord diagonally across the screen...
Name:	AS Interior Main Cabin looking Aft.jpg
Art - W0ABX
High Desert Country of the Rockies
'85 Sovereign 25'er
WBCCI: 2197; AIR #: 36503; TAC #: NM-5
MaxAB is offline   Reply With Quote
Old 06-29-2010, 05:50 AM   #29
katzklaw's Avatar
Hayward , WI - land of beer and cheese
Send a message via AIM to katzklaw Send a message via Yahoo to katzklaw
i have a fun situation in that the TV we bought (28" sanyo flatscreen) was wider than any straight wall we have in the place! our solution was to set it at a comfortable viewing angle on a shelf that hubby built. i put a few screws through the base into the shelf to hold it in place, and to keep it from vibrating back and forth and possibly damaging the connection between the TV and the base, i have 2 eye-hooks, one at the bottom, one at the top, and i strap a bungie cord diagonally across before we hit the road.
4000ish miles so far and still workin fine!
allroadslead2home.wordpress.com
katzklaw is offline   Reply With Quote
19' CCD owners with LCD TVs that you mounted ericwarren Audio, Video & TV 19 11-28-2011 06:10 PM
Flat Panel TVs MikeF Audio, Video & TV 113 05-20-2010 06:05 AM
Flat screen TVs and cold weather Antique Pedaler Winterizing, Storage, Carports & Covers 5 10-10-2009 06:16 PM
Changing TVs and switching wd hitch arms to new TV WyoRacerX Hitches, Couplers & Balls 3 06-16-2008 07:34 AM
06 versus 07 Diesel TVs Streamer1 Tow Vehicles 24 11-22-2006 06:38 AM
