Old 01-12-2018, 01:38 PM   #1
Sioux Falls , South Dakota
How would we have fared?
A year ago we thought we had our Foretravel sold and were looking for an Airstream and truck. Well, that didn't happen, and we're still full-timing in the Foretravel and thinking about the Airstream.
We spent two weeks over Christmas and New Year's near our children, which coincided with a couple of nights of below zero temps and a couple of days of single digit highs. We used a fair amount of propane, and some electric heaters were also running. We had no problems - no frozen pipes, hot water for showers, etc.
How would we have fared in an Airstream?
David Lininger, kb0zke
TAC SD-6
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (for sale)
kb0zke is offline   Reply With Quote
Old 01-12-2018, 02:39 PM   #2
2018 30' Classic
Butler , Pennsylvania
Having spent the past three weeks in Northern Virginia during this cold snap, I can say a 2018 Classic with an Alde heating system would do just fine. I had a temperature low of 0.0 degrees F. The only issue I had was a 90 degree brass fitting where the city water connection when into the trailer. I mounted a 90 degree fitting and attached a heated water line. The fitting froze, but fortunately I had a full fresh water tank which got me through until I was able to thaw out the fitting. No broken water lines or damage of any sort.
I have since modified the brass fitting with insulation and heat tape. I am expecting some more cold weather this weekend. I'll update with any problems.
RussRamz is offline   Reply With Quote
Old 01-12-2018, 03:18 PM   #3
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
If it is going to be significantly below freezing, disconnect the city water.
2012 Dodge Durango Hemi/AWD
Old 01-12-2018, 04:28 PM   #4
The only time a hose is connected is when something is flowing through it. We use the fresh water tank until it needs filling, then dump black and gray and fill. Hoses are then put away until the next time they are needed.
TAC SD-6
AIR 54240
Old 01-12-2018, 06:12 PM   #5
Overkill Pundit
GMFL's Avatar
2014 23' International
Dadeville , Alabama
We have done just fine
Cold weather camping. Good to go
Old 01-12-2018, 06:35 PM   #6
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
We do the same. Works well for us.
Sub zero is pretty cold! We've used our 1992, 29' Classic in sub-freezing temperatures several times. Depending on the temperature and the duration of the cold snap the dump valves on our trailer will freeze. We've never had the contents of the fresh, black or gray tank freeze but we've not been in freezing conditions for more than a few days. We make sure to use the propane furnace because there are two hot-air supplies that dump warm air into the belly pan to minimize the possibility of freezing. We supplement the furnace with two small electric, ceramic heaters.
Lucius and Danielle
1992 29' Excella Classic
2005 Chevrolet Suburban K2500 8.1L
2018 GMC Sierra K1500 SLT, 6.2L, Max Trailering
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 01-12-2018, 07:01 PM   #7
2018 30' Classic
I'm living full time. I don't want to disconnect each time there is a forecast for freezing weather. Frankly, there isn't need if proper precautions are taken. This Spring I'll heat wrap all lines close to the skin for full time connections. Much of the praise must be given to the Alde system. It is outstanding.
The tank heaters worked like a champ. With some minor modifications, this rig is able to handle Arctic temps.
Old 01-13-2018, 04:03 PM   #8
St Paul , MN
I would not have liked the cold air seeping in the Airstream windows - especially with the wrap around - the motorhome probably has double pane and Airstreams do not - that would make a big difference to me with below zero temps. Also, floors are cold...brr.
We have camped in 14 degree with 30 mph winds and thatís as cold as I want to ever be in the Airstream.
Seemore2006 is offline   Reply With Quote
Old 01-13-2018, 04:25 PM   #9
1989 34.5' Airstream 345
Ebro , Fla Panhandle
No double panes in my 345 motor home , just lots of very leaky single pane windows with large weep holes at the bottom. All now covered by a clear plastic film installed with sticky back tape. This makes a big improvement!
Could be well installed with a second pair of hands in getting stretched out well when attaching to the tape.
I have heat tape on the dump valves, and a drop light under the bed where the fresh water tank and lots of the plumbing lives.
Also leave cabinets open so the space heaters can warm them.
Cheers Richard
tevake is offline   Reply With Quote
Old 01-13-2018, 05:16 PM   #10
belen , New Mexico
As in winter
My last AS was a 79 ambassador with Alaska package ( double pane and extra insulation) I was able to keep it comfy with an old school ceramic heater.
alantbird is offline   Reply With Quote
Old 01-13-2018, 07:11 PM   #11
Double pane windows didn't arrive in Foretravels until several years after our coach was built. We did leave the doors open under the sinks. FWIW, a thermometer sitting on a shelf by the exterior wall showed 50* but when moved to the center of the bed jumped up to 60.
From what I've read here, it sounds like we would have been fine. Yes, with the smaller tanks in an Airstream we would have had to hook up, dump and fill more often than we did, but that would be true no matter what the temperature is.
Thanks for the reassurance.
TAC SD-6
AIR 54240
An Airstream Motorhomer Would Never Do This.....Would They? Fly at Night Airstream Motorhome Forums 11 12-09-2012 11:38 AM
Would you chance it? What would happen? Becky B. Repairing/Replacing Floor &/or Frame 6 03-05-2010 10:06 PM
Who would have thought they would steal my.... Kenyon On The Road... 30 10-21-2007 05:45 PM
anyone have some aluminum roof vents they would like to part with? john hd Roof Vents, Skylights & Fans 9 09-06-2006 07:40 PM
What would you have done? azflycaster Airstream Trailer Forums 19 11-29-2005 05:42 PM
