Old 02-04-2019, 10:08 AM   #1
2019 22' Sport
Quartzsite , Arizona
How Efficient IS a Honda EU2000i Generator?
Howdy!
Came to the obvious conclusion an inverter will not provide the juice I need. I've set up a small shop in my Sport 22FB for making jewelry. Downsized and simplified almost everything but need to run a small exhaust/fume fan and a micromotor that may be sensitive to surges at 50/60 Hz, 250 Input Watts.
A larger polishing motor out side and occasional rock saws etc.
The Honda EU2000i Generator is as much as I'd like to spend.
Does if provide "clean" electricity or is a surge protector to be factored in cost?
R44
Rounder44 is offline   Reply With Quote
Old 02-04-2019, 10:55 AM   #2
Long Island , New York
Do you need to run the air conditioner? If not, the Yamaha 1000 running on propane is a nice little unit IMO.
https://www.motorsnorkel.com/ef1000i...generator.html
You will need the propane conversion kit.
If you need to run the AC consider the new Honda 2200 plus Easy Start IMO:
https://www.amazon.com/Honda-2200-Wa.../dp/B079YF1HF6
Propane conversion:
https://www.amazon.com/Hutch-Mountai.../dp/B07BHBLFN4
https://genconnexdirect.net/honda_pr...htm#xl_EU2000i
Good luck,
Peter
Honda EU2000I Generator and EU2000I Companion Mldun Airstream Classifieds 0 03-29-2018 11:51 AM
Portable Generator Sound Levels: One Honda EU2000i vs. Two Paralleled Honda EU2000i AndyPenny Generators & Solar Power 19 06-05-2017 04:04 PM
Honda Generator EU2000i Theft Deterrent Bracket z8 hm Generators & Solar Power 1 02-17-2012 05:47 PM
Honda EU2000i Generator Pricing Jan.2005 markparker22 Generators & Solar Power 12 11-23-2005 07:49 AM
Honda EU2000i generator dhe9 Generators & Solar Power 4 04-12-2005 07:33 PM
