Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living
Old 01-05-2009, 08:56 PM   #15
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
We love having the Bambi next to the garage under the Bambi port...with it's dedicated 30 amp shore line, cable and even dump capabilities into our sewer line via the clean-out (and about 20' of dump hose)... It makes a great get-away, extra frig and cooking facilities when needed (like Thanksgiving or Christmas) and it's so much less hassle when getting ready for a trip... Do it if you can swing it!
TB & Greg...and Cockers Annie & Sadie
AirForums #21900 . WBCCI F
our Corners Unit #3954
Décor Site: AZBambi Décors
TBRich is online now   Reply With Quote
Old 01-10-2009, 01:18 PM   #16
Profile:  1994 34' Excella
Wytheville , Virginia
Home Huckup
If you live in the city I can't be much help on the sewer hookup. here in VA i have the perfect setup in my back yard (septic tank).
Sewer--The septic tank as used here has two concrete hatches on the top. I made a hatch with a short 4 in. dia.. section of plastic pipe through the hatch. Then replaced the original with the new one and ran 4in. pipe in a ditch to where I wanted my dump station about 4 ft. away from the hook up on the A/S. Built a concrete box around the end of the pipe that has a threaded fitting for a plug at the dump end. Didn't put a trap in, did set the drop at 1 in in four feet. (&^%& won't flow up hill.)
Electricity---Ran a dedicated 30 A circuit at the same time I built the dump station. Put a 30 A "camper box " on a pole next to the dump station. Buried the electric and T V in the ditch with the pipe.
Water--- the out side hose bib on the garage is about 30 ft. away.
All the material came from Lowe's
Vita est breves
jerrold
jerrold is offline   Reply With Quote
hook up, hookup, how to build rv pad
Internet / Satellite Hookups wtmark Computers, Internet & Satellite 58 01-21-2008 08:02 PM
Considerations when buying an Airstream mello mike Buyer Guidelines 42 09-05-2007 12:49 PM
Cable TV Hookups Devoman Electrical - Systems, Generators, Batteries & Solar 7 03-20-2006 12:11 PM
Setting up hookups at home rluhr Winterizing, Storage, Carports & Covers 26 05-10-2005 06:11 AM
Route Considerations - International in Vermont overlander64 On The Road... 6 06-22-2003 08:15 PM
