Old 07-19-2015, 11:32 AM   #29
Overland Adventurer
AtomicNo13's Avatar
2009 34' Panamerica
Telluride , Colorado
Pack in enough clothes in the closet, and compression will keep everything In place!
Old 07-20-2015, 06:38 AM   #30
Keene , New Hampshire
Originally Posted by m.hony View Post
Maybe the reason our clothes stay on the bar is because they are "wedged in and can't go anywhere?
One side is against the wall. One side is against the door.
That would be our situation - packem' in! Thanks...
phowe46 is offline   Reply With Quote
Old 07-20-2015, 06:48 AM   #31
Msmoto's Avatar
2015 30' International
2009 27' FB International
2007 25' Safari
Greensboro , North Carolina
Images: 135
Some of us drive either on horrible roads or way too fast, but I have had clothes fall off all the time until I cut a one inch thick piece of "kayak foam" the closed cell foam used for flotation, and wedge these between the curtain rod and shelf once hangers are in place. This reduces problems to nearly zero, but apparently some of the roads still have bumps enough to even dislodge these.
But, I am actually dropping my trailer tire pressures to 60 psi (16 inch LT tires) which according to Firestone is about correct for my 7300 lbs on four wheels, when hitched to TV.
Maybe tire pressures have more of an influence than I had realized.
Ms Tommie Lauer
Greensboro, NC
2015 Serenity 30 RB / 2008 Dodge Cummins 4 X 4
WBCCI #4165 AIR #31871
Happy trails and Good Luck
AIR #31871 K4MTL
www.fantinesvoice.com
Msmoto is offline   Reply With Quote
Old 07-28-2015, 04:05 PM   #32
CaddyGrn's Avatar
1963 16' Bambi
Yreka , California
I purchased some stainless hangers that have a narrower hook at the end that goes on the closet pole. They are a little more effort to take down, but clothes do not fall off of them. However, with that said, we also have some cheapie plastic hangers and only rarely do things fall off.... only if we are going over very bumpy roads like the San Diego freeway!
Mrs. NorCal Bambi traveling in S Tardis ~ from the Great State of Jefferson!
My blogs: http://yrekahistory.blogspot.com
http://siskiyoucountycamping.blogspot.com
http://campingalongi-5.blogspot.com/
CaddyGrn is offline   Reply With Quote
Old 05-28-2016, 09:21 AM   #33
2015 23' Flying Cloud
Livermore , California
Do these fit over the corrugated bar covering?
Originally Posted by AWCHIEF View Post
These are what works for me. All other hangers I have used fall off.
Amazon.com: Tri-Lynx 1200W Lynx Stay-Put Hanger Set of 6: Automotive
cactusjk is offline   Reply With Quote
Old 06-04-2016, 08:28 AM   #34
Do the Lynx hangers work with the corrugated covering on the closet bars?
Old 06-05-2016, 09:57 PM   #35
Dan and Liz's Avatar
1987 25' Sovereign
Fort Collins , Colorado
I slit a piece of foam pipe insulation and put it over the bar, then secured with duct tape. No worries.
Dan & Liz H
"I'd rather be happy for just one day than miserable for the rest of my life."
Dan and Liz is offline   Reply With Quote
Closet hanging space in an Interstate bugsbunny Sprinter and B-van Forum 18 10-08-2013 04:24 PM
Polishing Clothes rslaymaker Cleaning, Stripping & Polishing 9 08-24-2009 07:18 PM
Clothes hangers that don't fall off amathis50 General Interior Topics 37 04-13-2008 07:53 AM
Clothes Hamper - 1971 Safari Larry71 General Interior Topics 3 11-07-2007 10:30 PM
