Old 03-03-2015, 02:59 PM   #1
2014 25' FB Eddie Bauer
Knoxville , Tennessee
Generator Size
We are getting ready to purchase a generator. I am leaning toward Yamaha brand. I cannot decide between the 1000 or 2000. We are only using it to charge the batteries. We are not interested in running AC, convection oven, etc...
Any input appreciated!
Jfed is offline   Reply With Quote
Old 03-03-2015, 03:07 PM   #2
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
I think the 2k units are the "sweet spot" in price vs. performance vs. portability. They're not that much heavier than the 1k generators, I think they're a bit quieter, you get 2x the current for about 1.2x the price. I realize you're not worried about this now, but if you change your mind later and want to run the AC, you can add a second unit in parallel.
David
DKB_SATX is online now   Reply With Quote
Old 03-03-2015, 03:57 PM   #3
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I like the 2K units also. We have 2 2K Hondas, but end up using just one most of the time. The 1K is kind of limiting.
Brian
SuEllyn & Brian McCabe
Old 03-03-2015, 04:04 PM   #4
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
2K is the way ....
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Old 03-03-2015, 04:49 PM   #5
HowieE's Avatar
Princeton , New Jersey
Images: 12
2K offers reserve capacity at the expense of using more fuel.
If you truly are only going to use it for batteries the 1K will work.
Now for the problem. Depending on how you hook the generator up you may run into a problem when the frig goes to electric. If you plug the trailer 110 line into generator the frig will go to electric and you will be charging through the convertor. The combination may reach the limit of the generator.
I wanted Nachos for lunch one day while on the road. Started the 1K generator and all was will till the microwave kicked in. I had failed to set the frig to gas and turn the convertor off.
2004 Excursion 4x4
Awning size; wheel lug nut size jaygoree 2011 - 2015 International 0 02-19-2015 04:18 PM
What size TT have the same size awnings LI Pets Awnings 11 07-19-2014 01:04 PM
Plug size and ball size for '66 Safari 22'? Jezibels Hitches, Couplers & Balls 3 08-13-2009 06:59 AM
Twin Size Size Over59 Upholstery, Blinds, Walls & Interior Finishes 5 08-20-2004 10:18 AM
help! what size generator?? tjj's63 Our Community 5 08-20-2003 07:33 PM
