Old 01-06-2010, 11:25 AM   #57
Lyle & Margie
2008 28' International CCD
Lakeside , California
Honda advertises the Handi will run a 13.5k AC without any problems. You can check the noise specs, my experience is that it's quite.
BAB BMRZ is offline   Reply With Quote
Old 01-06-2010, 11:36 AM   #58
Lyle & Margie
oops.... quiet
Old 01-06-2010, 11:38 AM   #59
2009 25' SS International
Pasadena , California
Originally Posted by BarnacleBill View Post
I am guessing by your sig "flmgrip" that you could check with someone in the electrical department about the watts amps and volts stuff. Did I guess correctly? I am a retired and recovering DP
All the posts here are very helpful. New batteries cant hurt. We have a Catalytic heater as well as the furnace, but if will not keep the tanks from freezing as wahoonc said.
yep, but i don't talk to them electricians
flmgrip is offline   Reply With Quote
Old 01-06-2010, 11:44 AM   #60
the honda handi is 57db-65db, where the ef2400 is 53db-58db...
being quiet and tri-fuel is important to me...
Old 01-11-2010, 04:59 PM   #61
i had the batteries/charger/solar tested and they all checked out ok... i guess i have to just get a geny for those cold boondockin nites... i think i'm gonna go for the Ef2400 trifuel... seems to be the best choice for my needs
thanks for all who have contributed to this
Old 02-25-2010, 06:20 PM   #62
1972 Travelux Princess 25
Cobourg , Ontario
1) You need a generator
2) Sulfated batteries can be rejuvinated with EDTA. Deep cycle or RV batteries respond well to this treatment because they have thicker plates than standard car batteries.
EDTA RESTORES SULFATED BATTERIES
3) If you use a resistor to reduce power to a 12 volt device you save nothing. The resistor burns electricity to reduce power. Touch the resistor, it will become warm when you run your fan.
4) Be cautious with any non vented fuel burning heater even a catalytic heater. Leave a window open for fresh air when it is on especially when sleeping.
"Coleman catalytic heaters are an ideal, and safe, method of heating a small cabin, tent or fish house when the temperatures drop uncomfortably low. Using a 16-ounce canister of propane in combination with the heater's built-in platinum catalyst provides cost-effective, flameless, long-lasting heat without fear of dangerous carbon monoxide buildup in the enclosure. For convenience, some models come equipped with an electronic ignition for flameless startup, and some also include a small fan (battery operated) for heat distribution. Note that regardless of manufacturer's specifications, it is always important to have a source of fresh incoming air, at least six square inches, anytime a heater of any type is used in an enclosed space."
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 06-15-2010, 06:35 PM   #63
Cobourg , Ontario
Originally Posted by flmgrip View Post
Thanks guys, Ray... Great post!
Just got back from checking them up, I filled them a little higher than I read now here. Maybe half way to the top - between the ring and top... I hope it'll be ok, the voltmeter said 12.4 volts...
I did fill almost 3/8 of a gallon into the batteries... A few holes were lower than others... We shall see what will happen, I will take the baby out for a little x-mas trip...
The reason I didn't check the water till now was that the guy who installed the solar told me I'll be suprized how well the batteries and the waterlevel of them will hold up...
Lesson learned !
Well.... you WERE surprised just not in the good way.
Always tied to shore power carpetbob Batteries, Univolts, Converters & Inverters 3 11-13-2009 09:08 AM
Power surging from shore power in my Excella 500? NVDeputy Lights - Interior & Exterior 4 10-09-2009 11:52 AM
Shore Power Again The Flintstones Batteries, Univolts, Converters & Inverters 13 10-09-2007 07:18 PM
Shore power and battery power problems jfremstad Electrical - Systems, Generators, Batteries & Solar 5 05-03-2007 08:23 AM
Power w/o batt. just shore... crazylev On The Road... 8 11-12-2004 04:14 PM
