Old 01-10-2010, 09:34 PM   #1
vancouverG's Avatar
1975 31' Sovereign
fairbanks , Alaska
Electric heaters
i'm living in my airstream in vancouver, WA this winter.
my furnace works fine, but i'd like to get a small electric heater to help out(1500watt or so)
they always say not to use those types of heaters on an extension cord, so i guess i'm just wondering if there are any issues using one in a 35 year old trailer with 35 year old wires.
anyone have any input??
thanks, G
vancouverG is offline   Reply With Quote
Old 01-10-2010, 09:42 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Have used this model for over 10 years, works very well.World Marketing of America B-6A1 1500W Original Disc Heater
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
ďItís a crooked piece of time that we live inÖ.Ē
John Prine
Old 01-10-2010, 09:44 PM   #3
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
I have used ceramic heaters and oil filled in my 79 unit with no problems.
They sure help on cutting the propane usage.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 01-10-2010, 10:23 PM   #4
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, Oil Filled.
Name:	img_0242 (large).jpg
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 01-10-2010, 11:26 PM   #5
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
The extension cord bit may be about if there is a motor (fan) in your heater, the voltage at the end of your cord might become too low for the fan motor. Most motors like full voltage and 60 cycle.
I admit to being powerless over housecleaning and social niceities
Airforums 22655 and now, WBCCI 22655
NevadaGeo
NevadaGeo is offline   Reply With Quote
Old 01-11-2010, 04:06 AM   #6
richinny's Avatar
2011 34' Classic
the cord must be rated for the heater's power consumption. the longer the cord, the heavier wire you will need. you also need to check the trailer power cord ends.
we still need an opinion on the old wiring possible deterioration. anyone?
Ricky
Old 01-11-2010, 08:07 AM   #7
We use a Pelonis, electric ceramic with fan, from Camping World. Keeps propane use to a minimum.
rtaylor537 is offline   Reply With Quote
Old 01-11-2010, 11:30 AM   #8
The Polishing Guru
zinbar's Avatar
Riverside , California
Just make sure the Amps aren't too much on the heater also. they may be small but they can pull a lot of electricity. Stay Warm!
Riverside, CA
zinbar is offline   Reply With Quote
Old 01-11-2010, 12:41 PM   #9
DFK
DFK's Avatar
35 years from 2010 means your Airstream is a 1965 model or there abouts. I have a 1967 Caravel and have had no trouble with the wiring. That being said, things I would check are the amperage of the circuit breaker protecting the branch circuit of the outlet you will be using and what other electrical devices are or could be on that same circuit. I would also check the type of wiring. If it is aluminum like the wiring in my 67, then there is a possibility of corrosion occuring at the terminals where the wire is connects to the wall plug. Corrosion can result in an increase in the resistance between the wire and the terminal which, if severe enough can lead to the wire overheating where it connects to the outlet. In wood frame homes the overheating problem has lead to house fires. I would inspect the terminal connections to check for corrosion. The corrosion issue is less of a problem if the circuit operates significantly below it rated capacity. However, a 1500 watt load on a 120 v circuit can draw around 12 amps, which would be a significant amount of the capacity of a 15 amp circuit but less so of 20 amp circuit.
DFK is offline   Reply With Quote
Old 01-11-2010, 01:17 PM   #10
DFK
DFK's Avatar
Oops. My math skills clearly need some work. 35 years from 2010 is 75 not 65. I think by 1975 Airstream was no longer using aluminum wiring so the aluminum wiring issues would not apply.
Old 01-11-2010, 04:48 PM   #11
1980 31' Excella II
Drummond Island , Michigan
We use a 1500w ceramic in our '80 Excella without problems. Aluminum wiring even if your trailer has it is really not an issue if it was installed correctly in the first place. If you have been using a microwave, toaster or hair dryer in your rig you should not have a problem because a small electic heater draws about the same amount of current. If you need an extension cord please read the label and get a 12 Gauge cord, the one's that say "for appliance use" generally are the heavy guage.
Ahzmyrah is offline   Reply With Quote
Old 01-11-2010, 07:51 PM   #12
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Extension cord usage is still good advice, if you have cut some of the new extension cords you will find minimum wire is used and they have eliminated the ul seal on a lot of them. Buy a heater with high and low power setting, usually they are 750 and 1500 watts, most wiring can handle the 750 watts as long as water heater, all the lights, refrigerator, microwave, tv's and especially A/C strip heater isn't on at the same time. Good idea to have a voltage meter plugged in to watch system.
Old 01-11-2010, 09:07 PM   #13
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Iíve been running two this winter during an interior remodel. One is a ceramic disc and the other is a cheepie wire-wound from Menards. I can manage 60f. when itís 15f. outside. One is on a short room air extension cord.
I have 30 amp at home and donít have any voltage drop issues until the 500 watt work lights need to be turned on. The í72 has copper wiring and the cords and outlets are cool to the touch. (I burned an outlet up on my í67 with AL wiring.)
So far, so good. I think you'll be OK too.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 01-12-2010, 11:36 AM   #14
vancouverG's Avatar
1975 31' Sovereign
fairbanks , Alaska
thank you thank you
thanks so much for all the replies..
electrical, heater, winter living
No LP - All Electric, is it realistic? J.air.doe Electrical - Systems, Generators, Batteries & Solar 40 02-07-2015 05:40 AM
Adding Electric Heater to Atwood ElliotA Water Heaters, Filters & Pumps 4 05-19-2013 01:53 AM
Am I Stupid? Water heater gas and ELECTRIC THEPILL Off Topic Forum 25 10-21-2011 05:08 PM
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 7 02-01-2011 03:07 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
