Old 02-03-2010, 03:25 PM   #15
1972 Travelux Princess 25
Cobourg , Ontario
Are you thinking of the extension cord connecting your trailer to power? They are much heavier than a typical extension cord and present no problem.
They are concerned about connecting a 1500W heater to a dollar store cord which is way too small. Such a cord could heat up. If some papers or a a blanket fell on the hot cord it could eventually start a fire.
In your case you should not need a cord of any kind inside the trailer and the one outside is plenty heavy duty.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 02-03-2010, 06:25 PM   #16
Unless it is really cold, we run our Pelonious electric heater at half speed, 750 watts. We aren't worried about the wiring in our 2004 Safari but the heater at 1500 watts is quite hot to the touch. If the temps are in the 50's, half speed on the electric heater keeps the trailer warm enough so the furnace rarely goes on. If temps are below freezing, we run the heater at full power and make sure there is nothing flamable around the electric heater.
handn is offline   Reply With Quote
Old 02-10-2010, 08:30 PM   #17
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Electrical Codes prohibit any type of extension cord inside your home for resistance heaters. The current draw on electric heaters (and other electrical appliances with resistance elements like toasters, coffee pots) is too high for most home-type extension cords. The high current draw can soften and melt the insulation and create dangerous fire hazard in your home or RV.
Every rule has an exception, and many people survive unsafe things. Increase your chances of survival through safe practices.
Living the Dream
Jim Cocke,
International President
WBCCI Wally Byam Airstream Club
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 02-11-2010, 10:20 AM   #18
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by vancouverG View Post
they always say not to use those types of heaters on an extension cord, so i guess i'm just wondering if there are any issues using one in a 35 year old trailer with 35 year old wires.
Well, if your trailer wiring has any problems that should find them.
Old 02-12-2010, 07:32 AM   #19
Cobourg , Ontario
I don't think you would have any occasion to use an extension cord inside a trailer. I think they must have been asking about the cord connecting the trailer to power.
That cord is a special heavy duty one, well up to the job of powering an electric heater. An air conditioner draws way more power than a heater. Not to mention all the other electrical appliances you might use. The electrical system has plenty of capacity for a heater.
Old 02-15-2010, 05:39 AM   #20
Fuil-Timers
Images: 38
Ganaraska,
We were rallying this past week and saw folks running 50' 14-3 extension cords as extensions beyond their 30' 10-3 power cord. But they monitor for voltage drop and we encouraged them not to pull AC for fridge, space heater, microwave, etc.
Good observation about the short cord distances inside the trailer, and I like your answer.
in Okeechobee, FL
Living the Dream
Jim Cocke,
dreamstreamr.com
Old 06-18-2010, 07:04 AM   #21
Alvinsolar's Avatar
Sydney , NS
Re:input
Hi,
To my conscience, u need to switch to eco home heaters as they consume less power and they saves your money too...
eco home assessments
Alvinsolar is offline   Reply With Quote
electrical, heater, winter living
No LP - All Electric, is it realistic? J.air.doe Electrical - Systems, Generators, Batteries & Solar 40 02-07-2015 05:40 AM
Adding Electric Heater to Atwood ElliotA Water Heaters, Filters & Pumps 4 05-19-2013 01:53 AM
Am I Stupid? Water heater gas and ELECTRIC THEPILL Off Topic Forum 25 10-21-2011 05:08 PM
Electric Horn wiring diagram on a 345 John H. Classic Motorhomes 7 02-01-2011 03:07 PM
New Electric Service - YAY!!! or Life is Better When Everything WORKS!!! bugnot1 Winter Living 6 01-23-2011 10:32 PM
