01-17-2012, 10:31 AM
2012 25' FB Flying Cloud
Lexington
, Kentucky
De-winterizing
I have winterized my new Airstream (for the first time) by draining the tanks, blowing-out the lines with a compressor and adding RV anti-freeze to the fresh water tank and drains (and using the pump to fill the lines). Now we're preparing for a trip to Florida and I'm wondering what I need to do to de-winterize once there. We won't be using the fresh water tank since we'll have hook-ups at all stops. Do I need to do anything other than connect to city water at the campsite and thoroughly flush all lines by opening faucets? Can I just leave the RV antifreeze in the fresh water tank? Any suggestions would be appreciated.
01-17-2012, 10:37 AM
2010 22' Sport
Boise
, Idaho
I'm in the same situation. I've winterized just like you did and am heading from Idaho to Arizona in a couple of weeks. I'll be interested in seeing what info you get. BTW, I'm from Lexington...go Kats!
01-17-2012, 10:50 AM
Well Preserved
Colfax
, North Carolina
First, please DON'T put RV antifreezer into the fresh water tank. It's almost impossible to get it all out, and you will be smelling and tasting it until July. There are kits you can get to put the antifreeze directly into the pump, and just drain the fresh water tank.
Now, if you get one of thses kits, you can open the bypass valves to the water heater, run regular water through the system first, then fill the water heater, and use everything normally. When you're done, you simply buy 2 gallons of RV antifreeze and run it through the system, remembering to bypass the water heater and drain it. It should take about a gallon and a half to Winterize, then dump the remainder down all the drains to displace the water. Empty your holding tanks, and you're finished, and ready for further Winter storage.
Some days, it's just not worth chewing through the restraints.
01-17-2012, 10:55 AM
Refurbished 89 Excella
Sugar Valley
, Georgia
For me, and have probably gone through the drill for at least 10 years......anyway:
As I am driving I open the petcock to drain the RV antifreeze out of the freshwater tank or I do this at home before the trip. I run in perhaps 10 gallons of water, let it drain and then repeat a couple of times.........As I am doing this I hook up the city water line and let each faucet run on hot and cold for awhile. While this is going on, I put the plug back in the hot water tank, open the valve and let it fill..............WA LA..........
No big deal actually, and then if I get back into the cold, I buy another couple of gallons of RV antifreeze and go through the drill in reverse. I dont bother with blowing out the lines as the antifreeze just pushes the clear water out as it goes through the lines......DONT FORGET THE TOILET SPRAYER..........God bless.....Dennis
Dennis & Susan
D&D Farms, Sugar Valley, Ga
Registered Boer goats
01-17-2012, 11:09 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
Just flush the lines when you get to warm weather. I would also take the oportunity to fill the fresh water tank and flush it out also, then drain it again. AS Overlander 63 said, draining the water tank and the hot water heater is sufficient, no pink stuff needed there, And I second the don't forget the toilet. A drop or 2 of water in the valve will do it in if it freezes
Rick Davis 1602 TAC TN-2 K8DOC
PP VAC 2002-03
61 tradewind, 70 Globetrotter
69 Ambassador 64 Overlander
01-17-2012, 11:17 AM
Blue Highways Explorer
King Mountain
If you have a compressor for blowing out the lines then use it to blow out all of the antifreeze before you leave, the same way you blew out all off the water. When you get to a warmer destination, then you can hook up and flush out all of the remaining residue untill it taste fresh. If you had the hot water heater bypassed, don't open it untill you have flushed all of the water lines.
This is the strangest life I've ever known - J. Morrison
2006 Airstream 25FB Safari SE/LE with Hensley
2007 Volkswagen Touareg V10 Turbo Diesel
2011 Ford F150 Lariat Ecoboost V6 Turbo Gasser
01-17-2012, 12:33 PM
1977 27' Overlander
Trotwood
, Ohio
When I winterize First let the galley sink run till the pump drains the fresh water tank. Then I unhook the pump from the tank and with a short peice of plastic hose into the gallon containers of RV antifrezze I pump all the lines full. OF course I passed a step and thats opening all the drains and the Water heater and draining everything. I do put a little AF in the fresh water tank and also in all the drains. IN spring I fill the fresh water tank and open all the fuesets and let the pump drain the fresh water tank again. Then I sanitize the fresh water tank.The pink stuff is all gone. We are good ta go.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
03-24-2012, 01:34 PM
Decatur
Blowing Anti Freeze out of the lines
I winterized our water lines by pumping anti freeze thru them, and now want to remove it. I understand that I can use air pressure to blow them clear, but is there any precaution I should take before clearing the lines with compressed air?
Rod
03-24-2012, 02:30 PM
1994 30' Excella
Mississauga
, Ontario
Yes. Make sure that you don't use too much air pressure. Most compressors give around 120 lb. If all valves and faucets are closed that is what you will pressurize the system to.
Al
Al and Jean
TAC ON-3
03-24-2012, 02:35 PM
1974 Argosy 26
Morrill
, Nebraska
I just hook up the city water and flush everything out. Then fill the fresh water tank and start the pump to push the small amount of anti freeze out of that part of the line. Also flush out the water heater using city water.
03-24-2012, 03:54 PM
1995 30' Excella
Bowie
, Maryland
I wouldn't bother with air pressure for flushing the lines out - just keep running water through them.
1995 Airstream Classic 30' Excella 1000
B190 Owners: The site B190 Enthusiasts is dedicated to the 1989-1999 Airstream B190.
| Thread Tools |
| Display Modes |
