11-16-2018, 07:45 PM
Churubusco
, Indiana
Condensation running down to floor
So yesterday I noticed some dampness on the floor below our wrap around windows, with evidence of a bead running down from the window. I noticed a lot of condensation on the metal windows trim, is it reasonable to get enough condensation that it runs down the walls, or should I assume this window is leaking? (Never leaked before, but we just had the first ice storm of the season which could contribute)
These windows are always behind curtains, so they wouldn't be getting much airflow to carry the condensation away
In your experience, does reflectex and sealing up with plastic help with condensation, or just trap water further?
11-16-2018, 08:01 PM
1994 34' Excella
Warren
, Manitoba
Th only way to remove the condensation is to have air moving past it and out a vent. The dual pane windows that were used on some of the older models with the "winter" package helped, but not a lot. Are you living in the trailer, or using for a short period of time. I have found on house windows, a piece of styrofoam about 2 inches tall, across the bottom of the window helped to stop some of the condensation. If you have curtains closed it will stop air movement and you will have lot of water to clean up.
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
11-16-2018, 08:05 PM
2002 30' Classic S/O
Fleming Island
The best way to manage condensation is with air flow. Crack a window or two, or a roof vent. A dehumidifier helps too. I use a thermo-electric cooler dehumidifier. It doesn't trap a lot of water but seems to help with condensation on the windows.
The windows and frames (and interior skin, for that matter) will be cold enough to condense moisture from cooking, showers, and breath. Insulation, per se, won't help but if whatever you put in the windows keeps the moist air off the glass, that's a good thing.
Al
You cannot reason someone out of a position they have not been reasoned into"
11-17-2018, 06:30 AM
Churubusco
, Indiana
Thanks for the replies
Given how leaky this old 83 motorhome already is, cracking a vent definitely isn't the answer at the moment, ill freeze to death, lol
Sounds like you both agree lack of airflow over the windows is probably the biggest part of the problem, I'll try insulating and plastic wrapping, if that doesn't help maybe some small 12V fans back there
1983 Airstream 310 Class A Motorhome
-Rob
11-17-2018, 09:44 AM
2017 28' International
Jim Falls
, Wisconsin
The main reason for condensation is lack of air exchange. For example in many homes in the winter there is moisture on the windows. The fallacy is the windows are bad. Wrong!! The fact is the humidity inside the house is too high! Thus in modern homes the need for air exchangers. My house has an air exchanger. As soon as I see water on the windows I turn it on. Within a few hours the moisture is gone.
What has to happen is you need to bring the humidity within the AS down. It probably should only be about 30% inside the cabin. Otherwise you will get condensation. This is the reason AS’s are not made to live in during the winter.
My suggestion is to get a dehumidifier and run it night and day. Turn the fans on in the shower and bathroom. Also turn on exhaust fan over the stove. You don’t need to crack a window. That won’t help. Also you might need to limit showering and cooking within the trailer. These add moisture to the air, and the AS is a pretty small space.
11-17-2018, 10:16 AM
Silver Star
1970 23' Safari
Victoria
, British Columbia
I was in the window business for over forty years and in our west coast climate the biggest complaint was condensation. I was called to come look at a trailer several years back as the owner had bad condensation problem and wanted to know if we could build some storm windows or?? to help him.
Unfortunately because of the curves etc it wasn't possible to do that for him without spending more than the trailer was worth. My answer to him at the time was .......I have a solution but it will cost you about $1000 ..... he asked what?? .... I said get on the ferry ...get off and turn south and head to the states and don't stop until you hit warm weather !! and dont come back until it warms up here!!
We both had a laugh ...
I told him unfortunately RV's aren't built for living in the cold . You are also probably getting some condensation in the walls that you cant see as well.
As a minimum I would definitely get a dehumidifier and run it constantly .... your cooking ...breathing ...washing etc is all causing humidity to build up. Using your exhaust fans is good but I dont think you'll ever reduce the humidity enough in such a small space with such extreme cold .............. its only November too !!
Propane is heat heat too.
Good luck.
11-17-2018, 11:10 AM
Fleming Island
In my opinion, you don't want air exchange over the windows, you want to stop it. The humid air has the water in it. When it passes over the cold windows/trim the moisture condenses. More air flow will make the problem worse. As others have said, you need to lower the humidity with air exchange or a dehumidifier. The moisture in the inside air is going to condense somewhere, if not on the windows, then somewhere else.
Al
11-17-2018, 11:18 AM
Silver Star
1970 23' Safari
Victoria
, British Columbia
sorry ,,,,Propane is wet heat ....also watch out for black mold ...very scary if it dries and you breathe in.
11-17-2018, 11:42 AM
2017 30' Flying Cloud
Astoria
, Oregon
We have spent last winter on the Oregon Coast. We used electric heat, had three small dehumidifiers running all the time and wiped all the windows dry every morning. Limit showering and cooking. No matter what you do you will still have moisture on the windows on really wet and cold days. Our solution this winter? We are now in Arizona. Problem solved. I was not going to do another winter on the coast!
11-17-2018, 12:45 PM
Fleming Island
Water (along with carbon dioxide and carbon monoxide) is a combustion product of propane, yes, but the combustion chamber is sealed from the inside. Inside air passes through a heat exchanger. The propane flame and combustion products are on the other side. The furnace simply heats inside air with whatever moisture is in it, but does not add moisture.
Al
11-17-2018, 12:58 PM
Churubusco
, Indiana
Catalytic heaters are wet heat, furnace shouldn't be I wouldn't think
Hopefully the woodstove I'm about to install will help with humidity, if not a dehumidifier will be next!
Nomadic ability to move South when we want is the goal, but for now we're stuck in thr Midwest and will make the best of it!
-Rob
11-17-2018, 01:03 PM
1988 32.5' Airstream 325
WhereIam
, Left Coast Proud
We run a little electric heater full time during cold-snaps here in Texas, haven’t seen any condensation.
11-17-2018, 02:06 PM
2017 27' Flying Cloud
Box Elder
, SD
Originally Posted by 3wd67rg
We run a little electric heater full time during cold-snaps here in Texas, havent seen any condensation.
We are plagued with condensation problems now and then, especially during the colder days.
We bought a small eva dry dehumidifier that helped somewhat.
What really helped was when we started using an electric space heater.
Larry
11-17-2018, 02:38 PM
1987 34.5' Airstream 345
Auckland
, New Zealand
Captain Tolly's Creeping Crack Cure
and how its saved my 345's life
Hi M18,
I can only talk about my findings regarding these motorhome leaks so what happened to mine was my clear coat had degraded as it does, so I did a job off stripping it, up to that point I had leakes that as we know would come in from who knows where as we all know about how water migrates along ribs ect.
As we use this particular machine as a design office with hot running computer servers plus people going about their work. Well winter water collection was part off everyone's job description, till we spent 2 hours on our knees and on ladders with this little white bottle with its long proboscis dropping its watery solution and watching it wick its way around each and every rivit head. I would say in time 5 to 10 secounds per rivit. Where the solution disapesred you'd do it again till that clear watery solution stayed without seaping inside.
Now... every one off our rivits creates its own bowl in the alloy skin which was infact a collection bowl for water whenever it rained or heavy dew.
The interior you could say was getting compromised from allways being damp till as my label says =NOW NO MORE good old Captain Tolly, Marine shops or maybe RV shops.
Hole stack off towels on rotate otherwise.
All the best.
Rus
11-17-2018, 04:32 PM
2015 30' Classic
Decatur
we open the bathroom vents, seems to stop most of the condensation
11-17-2018, 10:48 PM
Silver Star
1970 23' Safari
Victoria
, British Columbia
Al
yes of course the furnace is sealed ...I wasn't thinking .... you still would get a small amount from cooking.
11-17-2018, 11:37 PM
2007 22' International CCD
Corona
A lot of moisture is given off just by human breathing and perspiration.
11-21-2018, 11:01 AM
Sioux Falls
, South Dakota
Air movement is caused by a difference in temperature. Warm air rises, cool air falls. Warm air can hold more moisture than cool air. If you can have a vent open in the roof and another near the floor, ideally at opposite ends of the coach, you can reduce the humidity in the coach. Running a vent fan when cooking, showering, or even washing the dishes will help.
Jo Ann is cooking noodles right now. The vent fan is running and a kitchen window is open. The bathroom vent stays open all the time.
David Lininger, kb0zke
AIR 54240
Heartland mpg 181 (sold)
1993 Foretravel U300 (sold)
2022 Grand Design Reflection 315RLTS
11-25-2018, 09:28 AM
Dan and Lynda
2012 28' International
Bremerton
Keep the vent open
When we are in our unit ('12 28' International) we keep both the shower and lavatory vent open weather the fans are on or not. It provides a vent and it has greatly reduced the amount of condensation in the trailer when we are in it in the winter.
11-25-2018, 10:13 AM
lancing
, Tennessee
Something like the mr. heater ventless propane heaters will add moisture to the air.
An electric heater is a dry heat.
For winter perhaps running an electric heater instead of a dehumidifier would work.
Condensation, rot, potential mold, and me not having good cheap answers for those is part of why I dream of full timing but don't know if I want to deal with fulltiming.
