Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living
Old 01-01-2009, 05:24 PM   #1
Profile:  1966 17' Caravel
quilcene , Washington
Condensation issues Underneath the Airstream
A mystery to me why I am finding water at the seams - beneath my 17 foot 1966 restored Caravel - of the aluminum sheeting covering the fiberglass insulation. if i stick my hand in gap between the two i can squeeze water out but the one place i could get my hand in furthwer fiberglass was dry. has anyone had this problem. don't think it is a leak as water not hooked up. and drains not being used. just got this adorable trailer and she is in a small damp valley in washington state. not living in her but spending day time there with windows and door open to vent, little heat use, etc. i suppose there could be some residual water in tank from previous owner but as moisture appearance is intermittent i am nearly sure it is condensation. but have never heard of this have you? a reply most welcome.
bert is offline   Reply With Quote
Old 01-01-2009, 06:14 PM   #2
64TrotterAtl's Avatar
Profile:  1964 19' Globetrotter
Decatur , Georgia
It sounds to me like the water is leaking in between the exterior skin and the interior skin. Especially if there is enough to wring it out. I would check around your vents, fans, etc on the roof to make sure the seals are good. Also check around any other items that puncture the exterior skin. You might want to purchase some trempro635 and paint thinner for clean up. It is hard to tell you what it is really, but this is just my opinion.
64TrotterAtl is offline   Reply With Quote
Old 01-01-2009, 07:11 PM   #3
thanks for the timely reply. i wonder how it can get to the very inside middle of the bottom however.
Old 01-01-2009, 07:19 PM   #4
cameront120's Avatar
Profile:  1972 25' Tradewind
Just drop the belly pan. It's really as simple as drilling out the rivets. This will expose the underside and might allow you to identify where the water is coming from. Do you have any wet spots on the floor? Look closely around the whole perimeter of the trailer to see if there is any dampness. This may also offer clues as to whether a window or other penetration is leaking.
Cameron & the Labradors
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
http://northvancouvermodern.blogspot.com/
Old 01-01-2009, 08:16 PM   #5
the belly pan is ? sorry to sound so clueless but i am. i do have a helper and we will be getting into this or i should say under this when the weather mitigates siomewhat if ever.
Old 01-01-2009, 08:33 PM   #6
Melody Ranch's Avatar
1995 21' Sovereign
1947 22' Liner
Valley View , Texas
Images: 42
try looking at this
My 66 Caravel had a terrible problem with condensaion from the front water tank. I completely insulated it during the rehab. Now no problem.
Another water source down below was the Dometic Refridg. drain. Open the compartment door (on the outside) and see if the drain hose has been routed to the outside of the belly.
Good luck.
Old 01-01-2009, 09:37 PM   #7
thanks for the excellent replies and their alacrity. should it ever stop raining, snowing, freezing, and blowing, i will check the exterior skin/, the perimeter, the water tank, and the fridge drain. this airstream forum is marvelous indeed.
Old 01-01-2009, 10:46 PM   #8
The belly pan is the aluminum skin on the underside of the trailer. You can remove it to expose the chasis and insulation.
Kai & Samm
North Vancouver, BC
Canada
AIR #11529
looking for Airstream, towing issues swifty6 Member Introductions 3 11-22-2007 03:42 PM
LP main pipe underneath LI Pets LP Gas, Piping, Tanks & Regulators 24 09-26-2006 06:35 PM
310 MH underneath rust Andre Baillargeon Airstream Motorhome Forums 2 09-26-2003 03:00 PM
What's this - underneath Stefrobrts Belly Pans & Banana Wraps 6 09-06-2003 02:00 PM
Caulking underneath? Kistler Our Community 2 07-10-2003 08:25 AM
