Old 05-07-2018, 11:08 AM   #1
Newbie!
2018 33' Classic
Hallsville , Texas
Cold Living
Iím a hairs breath from buying a 2018 Classic 33í FB to use as my home away while I work in construction. My only concern is how my Airstream will handle sub freezing and sub-zero temps for extended periods.
minotbill is offline   Reply With Quote
Old 05-07-2018, 12:26 PM   #2
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
Research Further Before Committing
I'm surprised you haven't had a response before this. Airstreams are far from your best choice for sub-freezing climates. Airstreams are typically three season trailers.
Use the search tab in the blue bar, enter "four season" or "freeze" for example, and you can find numerous threads covering the subject. Examples threads -
http://www.airforums.com/forums/f458...em-129839.html
http://www.airforums.com/forums/f312...ng-144014.html
I suggest considering an Arctic Fox model by Northwoods if you expect long term stays in truly winter weather. You can read more about evaluating RV choices for winter here:
https://www.guaranty.com/blog/the-be...ripping-part-1
Sirs Gawain & Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 05-07-2018, 12:32 PM   #3
2002 19' Bambi
Lafayette , California
I agree that Airstreams are not suited for long-term sub-freezing temperatures. We use ours each year in a location that often drops well below freezing at night. It handles that quite well, but we leave when the temperatures stay below freezing during the day. For example, frozen dump valves that stay frozen are no fun. We have heaters on the the valves, but that is more an emergency arrangement than anything else
Tim
Tim A. is offline   Reply With Quote
Old 05-07-2018, 12:49 PM   #4
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Arctic Fox or Nash are better suited for cold and hot weather.
Less expensive than A$ units of comparable size.
More interior space in the same length unit.
I own an A$ and a Nash. Both have advantages. But the Nash is considered a 4 season unit.
Old 05-07-2018, 11:41 PM   #5
Newbie!
2018 33' Classic
Hallsville , Texas
I appreciate your input (both of you). I'd started researching the Artic Fox but will also add the Nash to that review. I do like the Airstream, however, as many times as I've had to return to North Dakota for a winter, I'd really hate to have a 3-season trailer when I needed a 4-season unit. I'll just have to plan on an Airstream when I don't need winter digs!
Heat Pump - How cold its too cold? VeggieBullet Furnaces, Heaters, Fireplaces & Air Conditioning 7 01-09-2014 07:03 PM
Living in 34' AS Fulltime - Living My Parent's Dream.... bugnot1 Member Introductions 14 12-21-2010 09:40 AM
Winter Living Rubyslipper Winter Living 98 06-23-2007 05:49 PM
Biggest living room 31' or less darkStar Our Community 4 07-04-2003 04:01 AM
To use or not to use: living in our Airstream TinRoof General Appliance Topics 2 08-09-2002 01:11 PM
