Old 04-29-2018, 09:47 PM   #1
2018 16' Sport
Cary , North Carolina
Best Tow Vehicle for 27' Serenity
Hi everyone! I am looking now at buying a 27' International Serenity. Do any of you have this airstream and what do you use to tow? I am looking at the F150, but wondering what the best and most reliable tow vehicle would be for the 27'. Any input would be helpful! Thanks in advance!
jklotz13 is offline   Reply With Quote
Old 04-29-2018, 09:51 PM   #2
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Some will say that a half to pick-up is just fine for a 27' Airstream. I would prefer a 3/4 ton for the payload capacity.
Brian
SuEllyn & Brian McCabe
2018 Silverado 2500 (Lillian)
moosetags is online now   Reply With Quote
Old 04-30-2018, 09:29 PM   #3
2017 28' International
Baileys Harbor , Wisconsin
You will get tons of responses. I pull 28’ with F150 Ecoboost with max tow haul package (2017). Has plenty of power. But I use my F150 for a daily driver and don’t pull that much in a year. If I was pulling months out of the year I would go with F250 for payload reasons not for power reasons. I also use a Propride hitch for better stability. If I was doing lots of pulling in mountains I’d go diesel. But I wouldn’t buy a diesel just for regular use. Too expensive. So ask yourself, “How much towing do I expect to do?” If not that much F150 will work. If you are going to pull a lot, then probably F250. IMHO. But the F150 has plenty of power. That’s not the issue. Payload will be the issue if you are taking lots of stuff. Short-run Solution: Put more stuff in the trailer if you have F150.
Daquenzer is offline   Reply With Quote
Old 04-30-2018, 10:20 PM   #4
Wconley's Avatar
2018 28' International
Renton , Washington
This is great advice!!! Take it from one pulling a 27FB with a F150 EB.
Walt
2018 28 International Serenity
2013 F150 Ecoboost
Wconley is offline   Reply With Quote
Old 05-01-2018, 01:23 PM   #5
tommym1's Avatar
2017 27' Flying Cloud
Lansdale , Pennsylvania
RAM 1500 5.7 for sure.
tommym1 is offline   Reply With Quote
Old 05-01-2018, 01:49 PM   #6
moosetags's Avatar
All half tons can present payload issues. A lot will depend on your camping style and use of your Airstream.
Brian
Old 05-04-2018, 06:12 PM   #7
2018 16' Sport
Thank you all for your responses! I plan on using it as my primary residence. I'm a travel nurse and will be towing it often. Contracts are usually 13 weeks at a time and camping in between. I was thinking about the F150 eco boost for the 27'ft Serenity, but have been debating on whether or not to go diesel. I am worried about the expense of going diesel, but also want to be smart about not putting too much strain on the vehicle I choose. I too will be using my tow vehicle as an every day vehicle as well.
Old 05-04-2018, 07:09 PM   #8
2007 27' International CCD FB
San Diego , California
Before buying, it would be useful to familiarize yourself the payload capacity concept that is being alluded to. Each vehicle has a sticker on the doorjamb, listing the actual payload capacity of the specific vehicle. For example, not all F150s are created equal in this respect. Depending on the configuration and options (with more options generally eating into a chassis's carrying capacity), the vehicle will have different capacities. It can vary greatly.
The stickers look like this and can be found on the drivers door jamb on any vehicle sold today. In this particular picture, it's the 1962 lbs number
Boondocking option package:
'07 27FB Ocean Breeze "See Turtle", 3" lift
'09 Lexus LX570, on 33's
pteck is offline   Reply With Quote
Old 05-04-2018, 07:24 PM   #9
You do not need a diesel. A gas F250 is plenty for a 27’ if you need extra payload. The only reason to get a diesel is if you might be in the mountains a great deal. If I were you I would get an F250 gas. They have a towing capacity greater than an Ecoboost. It’s less expensive up front, fuel is less expensive, repairs will be cheaper, and you won’t have to worry about DEF. Oil changes on a diesel are over $100.
You’ll also save a ton of upfront costs. A F250 diesel is about a $9,000 upcharge in cost.
Old 05-04-2018, 08:24 PM   #10
By the way a 4x4 SuperCrew Cab with a short box and 3.73 differential can tow 12,600lbs. That gives you way more towing capacity than necessary for a 27’ AS. A diesel can tow 15,000lbs. Do you really need that extra 2400lbs of towing capacity?
Old 05-04-2018, 08:43 PM   #11
Fayetteville , Georgia
I am towing an International Serenity 28 with an Expedition, rated to tow 9200 lbs. No issue towing, but I am right at max payload. It may become an F250 diesel...
brick
brick
2018 International Serenity
Cute wife...
brick1 is offline   Reply With Quote
Old 05-04-2018, 09:21 PM   #12
jcl
Vancouver , British Columbia
Not sure whether you are referring to the new F150 diesel, or a 3/4 ton diesel. You don’t need to worry about strain on the vehicle. A properly equipped F150 with an Ecoboost can tow the trailer you are considering just fine, over any hill. The bigger issue is payload capacity. An F150 can handle the tongue weight, but it matters how much other stuff you want to take with you. Do you have a large collection of anvils? Do you want two generators, a paddling boat, and so on? Or will most of what you want to take fit in the trailer?
An F150 is a better everyday vehicle than a larger truck.
jcl is offline   Reply With Quote
Old 05-04-2018, 09:30 PM   #13
I agree.
Old 05-05-2018, 06:20 AM   #14
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
Ok I think this info helps and might answer this.
How much “stuff” do you need to carry for work plus camping fun plus living stuff etc. do you need to keep the stuff protected? A cap does that nicely but it does weigh a bit.
The “stuff” factor can help prevent you from under buying or over buying.
Good luck.
Gary
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Which is best tow vehicle Van or Sedan? Mr Jody Hudson Tow Vehicles 10 10-06-2016 10:14 PM
Airstream Serenity 27FB tow vehicle specs Tao Towing, Tow Vehicles & Hitches 78 06-02-2015 07:05 AM
Best Tow vehicle for 2013 International 28 Serenity casandel Tow Vehicles 23 12-08-2014 07:42 PM
Tow Vehicle/STOW Vehicle for Full-Timers Foiled Again Full-Timing 13 06-28-2014 01:55 PM
