Old 02-14-2015, 07:07 AM   #15
JimGolden's Avatar
1977 31' Excella 500
50 amp
You make a very good point. 30 amp is 3600 watts so the bigger wouldn't help here.
I wasn't thinking that as I converted my rig to 50amp, but with dual bus bars you actually get 12,000 watts available on shore power. I forgot they were still putting 30am in the new ones
- Jim
JimGolden is offline   Reply With Quote
Old 02-14-2015, 07:09 AM   #16
2004 22' Safari
Albuquerque , New Mexico
Ease of Handling...
One consideration I didn't see is your age and physical condition.
I am 64 and can easily handle each of my Honda 2000s individually, but would probably injure myself trying to man-handle a Honda 3000.
Hard to beat the pair of smaller ones.
Silver.Sanctuary is offline   Reply With Quote
Old 02-14-2015, 08:34 AM   #17
Madison , Wisconsin
I've got a honda 2000 and 3000 great products, quiet, easy starting, well thought out and best of all not a single issue and the 2000 is 6-7 years old.
I recent looked into the Hyundai generators, while they are cheaper many reviews talk about hard starting and poor service. That's major, those are important differences and saving a few bucks to start won't mean much when it doesn't start or you have other issues and have to wait weeks for service.
jtwind is offline   Reply With Quote
Old 02-14-2015, 09:56 AM   #18
We have full-timed in a 2005 Bambi 16 International, and carried the usual Honda 2000 with us and changed out the Interstate battery for a single gel cell battery. We used our computers extensively, lights, etc. it took about one hour of daily charging to keep us in good levels of electricity, but we couldn't run the air conditioner at all even on it's lowest setting. That Honda generator is about as quiet as they come and starts every time. I considered buying a larger Honda, but lifting it in and out of the truck would have been a challenge because of the weight. So we bought the companion Honda 2000 that hooks together with our original one and now we can do anything anywhere. The lifting weight is manageable and they make great power very quietly. We chain them to the bumper when in use as they are a desirable theft item. Good luck with your travels!
bhuntco is offline   Reply With Quote
Old 02-14-2015, 11:52 AM   #19
Skater's Avatar
1995 30' Excella
Bowie , Maryland
I'd normally recommend a pair of EU2000s or the Yamaha equivalent. But, if you expect to need the air conditioner frequently, and it sounds like you do, getting the bigger 3000 or Yamaha equivalent that can run the A/C is probably a better bet - it's half as many parts to deal with, no connecting cables, only one fuel tank (which is larger), etc. The only downside is that it's a lot heavier to move around and store.
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 02-14-2015, 10:10 PM   #20
2012 16' Sport
Philadelphia , Pennsylvania
Which parallel kit did you buy? will any do?
adamwright is offline   Reply With Quote
Old 02-14-2015, 11:11 PM   #21
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
Where will you be parked when you aren't plugged in? If you're off in the wilds you can pretty much do what you want, but most state and national park campgrounds (at least, where we've camped,) have strict hours for when you can and cannot run your generator. And take lots of extra gas if you'll be running your AC, fridge fan, TV, and computer pretty much non-stop.
Len n Jeanne is offline   Reply With Quote
Old 02-16-2015, 11:46 AM   #22
B00merang's Avatar
2010 20' Flying Cloud
Hailey , Idaho
Mister Wright
This doesn't address your generator question (as an aside...I have the Honda 2,000 pair and would recommend them) concern is the bold plan of full-timing in a 16ft. Bambi. One thing that will make your life easier (and running the generator less) is to get a couple of solar showers...they are like a use them outside the small bathroom...and don't require a power source. jon
B00merang is offline   Reply With Quote
Old 03-01-2015, 05:04 PM   #23
1973 Argosy 24
Hartselle , Alabama
I went with the Yamaha 2400 and have been very pleased. It starts and runs my Coleman 13.5 in heat or cooling mode, as well as keeping the TV going and the food hot.
yourplce92 is offline   Reply With Quote
Old 03-02-2015, 08:33 AM   #24
2012 16' Sport
So you dont need to run another generator in parallel? I looked at the Yamaha 2400. Still pricey. I can get two Ryobi 2200 for the same price.
Old 03-02-2015, 12:08 PM   #25
Zanadude Nebula , WNY
Thumbs up
>>>>"I'm going to buck the conventional wisdom here and recommend you get a bigger XXXXXXXXX.<<<<<<
Old 03-02-2015, 04:26 PM   #26
Rich of SCal's Avatar
2012 16' Sport
San Bernardino , California
for my Sport 16....
I went with the Yamaha EF2400iS. But I bought it through US Carb already converted to TRI-FUEL. Gasoline, natural gas, or propane. I hook it up thru the Sport's bbq connection in the front. It runs a long time on propane, right from the AS tanks.
It is powerful enough to run the AC, or anything else onboard, including my Cuisinart convection toaster oven.
It is very quiet. Inside you can barely hear it run. Outside, you can easily carry on a conversation with it running nearby.
Once I did the break-in with gasoline, and got the adjustments right, it usually starts on the first or second pull (if I remember to push the air purge button first, that is),
I am very happy with it. I did a lot of research before deciding. While the Hondas are excellent units, as well, I am glad I did not go with connecting 2 2000 units together. I would end up taking both units all the time, weighing more and using up more space.
Using propane is the only way to go. No fumes inside the tv, as with gasoline (although I keep some gas in it, but it seals so tight I never smell it). Burns cleaner and longer, too.
Also, if you buy it already converted by USCarb, your 3 year warranty will still be good. If you convert it yourself, that may not apply, (but it is cheaper to do it yourself).
If I were doing full/part timing in my 16, this is the only power unit I would use.
Good luck.
Yamaha EF2400iSHC Generator
Rich of SCal is offline   Reply With Quote
Easily the best benefit to full-timing... westcoastas Full-Timing, Winter Living & Workamping 8 01-04-2015 11:19 AM
Full Timing & Timing, Sergei's Selling his ARGOSY Foiled Again General Interior Topics 8 05-18-2014 11:48 AM
New to Airstream, Soon to be full-timing.. HELP BrandonJenna Full-Timing 44 06-28-2013 10:21 AM
Best length for full-timing kb0zke Buyer Guidelines 8 09-02-2011 11:50 AM
Best yr/model for full timing abruce Full-Timing 22 12-14-2008 11:23 PM
Copyright 2002-2015 Social Knowledge, LLC All Rights Reserved.
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
