Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living
Old 04-16-2009, 07:25 AM   #1
Profile:  Currently Looking...
york , Pennsylvania
Best Airstream model for all season use
I have been searching RV shows and reading several posts in my quest for the best, all around Airstream. My questions center around 3 areas, some of the models have the wrap around windows in the bedroom area. Is this area hot in the summer and cold in the winter due to the large glass area. I also notice storage under the bed with o/s access, does this make the bed colder? Would I not be better with less glass area exposure? The second area of concern is how the underbelly is kept warm, some models have hotair and some have 12V heaters on the tanks. It would seem the 12V would be more efficient. Finally, I notice some interiors have a finish and some are aluminum, what are the pros/cons in regards to heat and cold? Would not the non metal finish be more insulated? These concerns will help me in deciding on which model will suit my needs best. I appreciate your input!
cpaharley is offline   Reply With Quote
Old 04-16-2009, 07:50 AM   #2
moosetags's Avatar
Profile:  2005 25' Safari
Santa Rosa Beach , Florida
Welcome from the Florida Panhandle
First off, Welcome to the Forums. We are glad to have you with us.
We have spent almost 400 nights in our 2005 Safari 25FB all over the country in all types of weather conditions, including desert hot and snowy cold.
Our Lucy (the Airstream) has proven competent in all of the weather conditions that we have encountered. We have both the electric heat pump and the gas furnace. We use the heat pump down to freezing. Below that it does not work. We then use the Furnace. We find that we are "snug as a bug in a rug". In very hot weather, we have found our 13,500 btu A/C unit to be quite sufficient.
Lucy does not have the panoramic windows. I think that this fact helps our weather capabilities. We also use the silver windshield insulation material inside all of our windows. This also helps significantly.
Brian
SuEllyn & Brian McCabe
WBCCI #3628 --- AIR #14872
2005 25' Safari FB (Lucy) with HAHA
2005 Suburban 2500 Quadrasteer (Olivia) & 2004 Suburban 2500 Quadrasteer (Daisy)
moosetags is online now   Reply With Quote
Old 04-16-2009, 07:53 AM   #3
willyd's Avatar
Profile:  1993 34' Limited
Melbourne Florida , Springfield Ohio
My Airstream fits the bill - for us. To compensate for different temperatures, we have a propane furnace for under 40 degrees - a heat pump for over 40 degrees and a ceramic heater just to take the chill off. I have large bedroom windows, storage under the bed and the interior is finished. Please see pictures. Best of success in your search.
willyd is offline   Reply With Quote
Old 04-16-2009, 08:10 AM   #4
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Not really what you want to hear, but all of them are. It really boils down to how much space you need/want. Each Airstream is fully self contained, has connections for external supply for water, power, sewage, phone,TV/Sat and are prone to follow to same laws of physics as anything else on this rock. We are talking an RV here, so although some features may be better not to have in terms of insulation from the outside (skylights, vista views, wrap windows, etc), the reality is that it's a RV that is not airtight by any means and has significantly less "R" value than that of a house. In winter with any unit, expect your LP costs to go up....larger units have larger heaters and more heating space. Summer, if you are paying a flat rate, it's not as much of a concern, but again, larger units typically have larger A/C units, some even have two and once again, larger units can take more to cool on very hot days. So to me the better question is how much space do you need and from there how can you squeeze the most efficiency out of the unit that meets your needs.
Old 04-16-2009, 08:55 AM   #5
HankandLois's Avatar
Profile:  2008 27' International CCD FB
Nashville , Tennessee
We have an International with panoramic windows on both sides -- Aluminum walls, too! We lived in ours from April 2008 until now with occasional trips home to our condo. It's been in zero temps and 100s.
One trick we do to keep cold leaking into out unit from under the bed storage area is to block the side "holes" with a sheet of styrofoam.
We used our furnace with a small ceramic heater and it stayed toasty warm. Better yet, some snuggling under an electric blanket made it real comfy-cozy.
The AC works great. We upgraded our AC unit, but now we hear they put a bigger unit in our model.
That's why purchased an airstream. For year round use. LOVE IT!
Lois' Airstream Blog
Air # 20467
WBCCI Member at Large #4018
HankandLois is offline   Reply With Quote
Old 04-16-2009, 10:23 AM   #6
dstalzer's Avatar
Profile:  2005 25' Classic
Cold weather camping
We recently traveled in 19 degree weather and were boondocking 3 nights. The propane furnace functioned flawlessly and provided plenty of heat. I would guess we would be comfortable down to zero. Our's is a 25' Classic without the wrap around windows in the bedroom. I have heard that the wrap around windows allow more heat to come in in summer and cold in winter. I added some weather stripping to the outside trunk doors to make them seal up tighter than with only the factory gasket. We will find out next winter how it is when we go to Santa Fe, NM in January.
dstalzer is offline   Reply With Quote
Old 04-16-2009, 07:45 PM   #7
Cincinnati , Ohio
Welcome to the forums!!
In answer to your questions, most of them are a resounding YES! A window is great for a view, and absolutely terrible for energy efficiency. Most modern houses have dual-pane energy efficient windows to help offset this effect. Most Airstreams have single pane windows. Having no windows would be the best thing for energy efficiency in temperature extremes, but do you want to sacrifice the view of the lake/mountain that you just drove 1500 miles to see?
For comparison sake, the residential building code in Michigan only allows 15% of the exterior wall space to be occupied by windows. I've not measured an Airstream, but I'm willing to bet that most are far beyond 15% and probably closer to 30%.
An aluminum interior is a terrible choice for energy efficiency. (They do look great though.) Aluminum is a conductor of heat. The vinyl covering used in the 1970's models will help offset some of the heat loss, but is not used anymore. A layer of paint will help considerably. Wood cabinetry interiors do actually have some "R" value as well as thermal mass, and will be a better choice for regulating the temps.
As was mentioned earlier, an RV was not designed to be a model in energy efficiency. The furnaces and A/C units are oversized compared to a modern house, and they are expensive to operate. A LEED rating for an RV will be another hundred years from now.
Good luck,
Woody
Leave my loneliness unbroken! - quit the bust above my door!
Take thy beak from out my heart, and take thy form from off my door!'
Quoth the raven, `Nevermore.'
-Edgar Allan Poe- 1845
Woody.303 is offline   Reply With Quote
Old 04-16-2009, 07:57 PM   #8
Commercial Vendor
TBRich's Avatar
Profile:  2006 19' Safari SE
Tucson , Arizona
Images: 58
We love our SE model which has both the panorama window and the aluminum interior...we like both features very very much and would not go without them. Whatever energy and warmth is lost by them is worth it to us. There are other ways to increase efficiency. We would not enjoy our Bambi nearly as much if we didn't have a big wide window and we had a cloth interior in a previous motorhome and never did like the way it gets dirty over time. There is no "best" IMHO...It all depends on what's important to you. My 2 cents.
TB & Greg...and Cockers Annie & Sadie
AirForums #21900 . WBCCI F
our Corners Unit #3954
Décor Site: AZBambi Décors
Old 04-16-2009, 09:10 PM   #9
Midamrail's Avatar
Profile:  1971 31' Sovereign
2008 25' Classic
1949 22' Liner
Villa Ridge , Missouri
Our 25' FB Classic with front and rear panoramic windows has been great in hot and cold weather; upgrading to the 15K air conditioner with the heat strip has proven to be a good decision. The wide body 25' has nearly the same interior square footage as our 1971 31-footer, but despite having more windows, the newer trailer stays cooler than the old with its better insulation and 15K A/C vs. the 13.5K in the older trailer.
I think an almost equally important source of heat gain in the summer and loss in the winter is the skylight. When we ordered our trailer, we had Airstream delete the skylight in the lounge area and leave the one in the bathroom, and we're glad we did. The skylights, even with the little paper shade drawn, can allow a fair amount of sun and heat in.
Ben & Molly (but Ben never types, so it's always Molly )
Midamrail is offline   Reply With Quote
Old 04-16-2009, 09:55 PM   #10
Profile:  2008 25' Safari FB SE
Crawford , Colorado
The 12v. tank heaters are impractical for boondocking because you will run the battery down fast. The propane fired furnace also uses a fair amount of battery, but will keep the water from freezing more efficiently.
We have the panoramic windows and aluminum interior because we made a style choice. Yes the big windows are impractical when you take heating and cooling into account. You can line the curtains or get better ones. A lot of what's comfortable has to do with what you want—we like it cool, especially in the bedroom, and that saves some propane. In the summer, you need 120v, or a large generator to run the AC. We don't go to Phoenix in August! I think the AC in ours strains to keep up with the heat when it's above 80˚ and the sun is directly on the trailer.
If you want a better built trailer for 4 season use, check out Arctic Fox—thermalpane windows and more insulation. We don't use the Safari in midwinter, but we have been out in it when the temps were in the teens overnight and we did fine. Remember to disconnect the water hose when the temp goes below about 28 or 29˚.
The panoramic windows help bring the outside in and make the interior seem less confining. The views are worth it sometimes, though some RV parks are not worth looking out the windows. I could do without these windows inn the bedroom, but I think it was both or nothing for the model we wanted with the interior aluminum.
Gene
CrawfordGene is offline   Reply With Quote
Old 04-16-2009, 10:32 PM   #11
ROBERTSUNRUS's Avatar
Lakewood , California
Images: 18
Hi, welcome to the forum. Whatever you chose to buy will be the best for you. We have the Safari with lined interior and small windows, and love it. My opinion, is that it is better insulated, therefore shouldn't be a problem in either hot or cold situations. But I haven't heard of anyone being cooked of frozen in any of the other models. As for the view, the best view is from outside of any trailer. Note: we haven't camped in any extreme tempuratures cold or hot. We chose our trailer for it's floor plan and size/weight and price range, in part because we wanted no monthly payments. All of these trailers are nice and the choices are up to the buyer. Good Luck on your decission.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
2000 Navigator / Equal-i-zer / P-3
YAMAHA 2400 / AIR #12144
Old 06-10-2009, 08:37 PM   #12
Profile:  2001 25' Safari
Palm Desert , California
25 to 30 ft airstream with "fabric-coated" interior. I have both and the aluminum interior is always cool or warm depending on the outside. An after-market radiant heater will keep you toasty when boondocking- must vent though. Don't over noodle, just jump in, it's the best way to learn! We are full timing in a 30' which is great for space, much better than the 25. Give some thought to the tow vehicle. Diesel is the way to go, I tried gas and it didn't work.
gusmarbert is offline   Reply With Quote
2008 27 fb airstream safari se season clearance eBay Watch Airstreams on eBay 0 03-03-2009 11:30 AM
2008 27 fb airstream safari se season clearance eBay Watch Airstreams on eBay 0 02-15-2009 08:31 PM
Model of Airstream altamont Off Topic Forum 15 07-17-2008 10:05 PM
Model Airstream alvinator Our Community 0 05-07-2006 05:48 PM
Airstream model 12 Inland RV Center, In Off Topic Forum 22 12-25-2005 10:14 PM
