Go Back   Airstream Forums > Airstream Community Forums > Full-Timing & Winter Living
Old 03-29-2009, 07:31 AM   #1
Profile:  1987 23' Sovereign
Ft.Worth , Texas
Below Freezing While Driving
I've been using my AS since 87 and have almost every year encountered temps below freezing temps when traveling from one place to another. I just leave the trailers furnace on the lowest temperature setting and check to make sure it's working every few hours during a normal rest stop.
I'm rather new to the forum and wondering what all of you do to avoid frozen pipes and tanks in this situation?
Bluto is online now   Reply With Quote
Old 03-29-2009, 09:53 AM   #2
Profile:  2008 25' Safari FB SE
Crawford , Colorado
I haven't yet used the furnace while driving in the past 1 1/2 years. I figure the movement keeps the water from freezing in the tanks and there's enough warmth retained inside from the time the furnace was on to protect the pipes. Also, during the day, there's enough sun on the trailer, even on cloudy days, to warm it up. If it were down in the teens, then I would consider turning on the furnace. The lowest setting in our trailer is 40˚.
Gene
CrawfordGene is offline   Reply With Quote
Old 03-29-2009, 09:54 AM   #3
Well-Preserved
overlander63's Avatar
Profile:  1974 31' Sovereign
We don't worry about it too much, unless the temp is really far below freezing. The motion of the trailer will help keep the water sloshing around, and keep it from solidifying. Fast-moving river rapids don't generally freeze, but a slow moving stream or lake will.
(No Longer at Inland RV)
Old 03-29-2009, 10:00 AM   #4
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Send a message via AIM to jcanavera
I'm a little surprised to hear this since my thoughts would be that the water in the plumbing isn't really sloshing around....maybe the tanks would be..
I just think of the plumbing that is below the floor and in those areas where the furnace is vented to. To me it's a roll of the dice as to when it gets too cold. Personally I'd rather take the safe route and deploy some heat. The penalty for guessing wrong is too great.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 03-29-2009, 10:03 AM   #5
Well-Preserved
Jack
Jack, in our trailer the only part of the plumbing that is below floor level and subject to freezing from not having the furnace on, is the fresh water inlet pipe, and it sticks out of the trailer. Everything else except the fresh and waste holding tanks are above floor level. It is this way on a 2007 we have in the shop right now as well.
Old 03-29-2009, 10:04 AM   #6
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Put a simple thermometer inside a lower cabinet where your pipes run. In cold conditions after driving a distance, stop and check that you're not anywhere close to freezing.
Wind chill will remove a lot of heat while underway unless the furnace is running. There is a safety tradeoff of running LP vs. not doing so. FWIW leave lower cabinet doors ajar if you can so that heated air can actually get in to where the pipes are. Check that thermometer on occasion so you can appropriately set the thermostat. Thermostat settings even in the low 60s will burn an awful lot of LP -- or I sure did once on a 350 mile trip at 15 above.
Shower mixer valves on exterior walls are especially vulnerable to destructive freezing. I don't think the furnace will save you there if it's especially cold outside.
CanoeStream is online now   Reply With Quote
Old 03-29-2009, 10:06 AM   #7
Well-Preserved
I wonder if a catalytic heater would put out enough heat in that case. I know they burn a lot less LP.
Old 03-29-2009, 10:12 AM   #8
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Same thing although I leave it at 55. The airstream is not air tight underneath.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 03-29-2009, 10:26 AM   #9
jcanavera's Avatar
Fenton , Missouri
Images: 143
One area I'm thinking of is the shower drain trap. That drops below floor level.
Other areas like under the our closet floor have cutouts in the plywood floor that would allow air intrusion that gets into the underbelly to filter in to.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-29-2009, 10:30 AM   #10
jcanavera's Avatar
Fenton , Missouri
Images: 143
I carry one of those thermometers that have a remote sending unit. I usually mount the remote outside when I'm camped. Next time we are out I might pack the remote down in the areas where I have concern. I'll put the receiver in the van and see if we can get a reading as we travel. Good idea Bob.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 03-29-2009, 10:31 AM   #11
shermantic's Avatar
Profile:  1972 Argosy 26
Fairmont , West Virginia
Images: 13
I have been towing in below freezing conditions all winter and haven't had a problem i don't leave any heat on after I begin my trip an dI find if my AS is at 70 when I leave even when the weather is in the teens - 20's I am still in the 40's for over 8 hours!
shermantic is offline   Reply With Quote
Old 03-29-2009, 10:42 AM   #12
doug&maggie's Avatar
Profile:  Normal , Illinois
propane on while driving??
"Wind chill will remove a lot of heat while underway unless the furnace is running. There is a safety tradeoff of running LP vs. not doing so. "
We have heard both extremes from many people about having propane on while driving---from never, ever leave propane on while driving as you can cause an explosion, to people who leave it on 24-7 and see no risk whatsoever. One fellow traveler told us that it is illegal in some states to drive with your propane on.
What do the forum experts have to say on this matter??
Thanks.
li'l moose
The more you know, the less you need
doug&maggie is offline   Reply With Quote
Old 03-30-2009, 09:14 AM   #13
Ft.Worth , Texas
The other thing I didn't mention is I enjoy driving at night. So the temps drop rather fast and stay there. I do like the idea about the remote temp sensor to check vulnerable areas where the pipes might freeze.
Old 10-25-2009, 09:27 PM   #14
Catman6's Avatar
Profile:  1986 Argosy
North East , Maryland
This is an interesting thread, and something I've wondered about myself. This answers one of my questions Here's a thought; The outside hose connection is obviously vulnerable to freezing. I've seen a fitting you screw in to that connection that has the same end as a tire valve stem. Has anyone tried blowing some air in to the line to push the water away from the outside of the fitting? Or will the 12 volt pump push the water back up the line?
Catman6 is offline   Reply With Quote
Freezing in CT.... NOT! bobfowler All Argosy Trailers 14 12-03-2008 08:44 PM
Freezing refrigerator stanm Refrigerators 4 04-01-2007 09:46 AM
Freezing while in tow. Tinsel Loaf Winter Living 8 08-02-2004 08:07 AM
Travel in freezing weather jcanavera On The Road... 6 08-04-2003 09:10 AM
Freezing RV Antifreeze Raptorrider2001 Winterizing, Storage, Carports & Covers 1 01-13-2003 02:33 PM
