Old 03-26-2016, 03:59 PM   #1
ADS99
2007 19' Safari SE
Crestview , Florida
Atwood Furnace Durability
I am a recent full time boondocker and have concerns about the reliability of the Atwood Hydro furnace. At 45 degrees it seems fime, but down in the 30's I feel like I'm stressing the system. When it runs 6 or 7 times an hour is that too much?
Note: When I have city power I use an auxiliary space heater. I've looked at the portable "Mr Heater"s, but they seem too big in size and heat capacity for a 19' Bambi Safari. Thanks
ads99 is offline   Reply With Quote
Old 03-26-2016, 07:45 PM   #2
Wise Elder
Jammer's Avatar
2010 30' Classic
I've run mine in -10 F. It runs continuously for a couple hours until the trailer warms up in weather like that. I don't worry about "stressing" it.
They don't last forever -- there's cumulative deterioration of the burner and heat exchanger with every hour of operations, just like a home furnace -- but they do last a long time. Years, decades in many cases.
Old 03-26-2016, 10:48 PM   #3
1974 Argosy 20
Kooskia , Idaho
Cycling on and off is not a problem for your furnace. It is how the temperature is and was meant to be controlled. You do not need to worry about it.
Old 03-27-2016, 02:02 PM   #4
ADS99
2007 19' Safari SE
Crestview , Florida
Many thinks. It will be 26 degrees in Lone Pine, CA tomorrow - I'll sleep better now.
Old 03-27-2016, 03:27 PM   #5
2002 19' Bambi
Lafayette , California
We have used the furnace in our 2002 19' Bambi for many years in temperatures ranging as low as 9 F. The furnace has needed a couple of new control boards and sail switches, but not as a result of heavy use.
Tim
Tim A. is offline   Reply With Quote
Old 03-27-2016, 03:54 PM   #6
1998 30' Excella 1000
Livingston , Texas
As you stated that you are a "full time boondocker", I would think that the power demands the furnace makes on your batteries/solar/generator system would be more important than wearing out the furnace. If you haven't checked into catalytic heaters, give them a look.
Siegmann is offline   Reply With Quote
Old 03-28-2016, 12:16 PM   #7
ADS99
2007 19' Safari SE
Crestview , Florida
I have a 160 watt Zamp solar setup, which has had no problem restoring full batteries so far (but I've only been in the desert sun since I bot it), and I thought the Mr Heater "Portable" was to big - but I should at least get the "Little Buddy" for backup (and rainy says).
Old 03-28-2016, 01:53 PM   #8
Livingston , Texas
Depending upon your battery bank, a couple of cold nights with the furnace running like you describe, and two cloudy days, you'll probably need that backup.
Ford F150/3.5 V6 Durability Test Road Ruler Tow Vehicles 11 09-26-2010 06:46 PM
White top durability BillTex Roof 12 11-01-2007 05:22 PM
New Clearcoat Durability? Atlantica Clearcoat, Exterior Paint & Trim 5 01-24-2007 05:58 PM
Fantastic fan cover durability jordandvm 2002 - 2005 International 3 10-01-2004 06:59 PM
exterior finish durability vs. model year Kirby Stone Exterior Restoration Forum 16 08-08-2003 09:34 AM
