Old 12-16-2018, 01:39 PM   #15
FishByFly's Avatar
2017 25' Flying Cloud
Oak Park , Illinois
I did the white paint this year on our Hensley hitch. It helps provide contrast, alignment, and better depth of field. Great recommendation from this group
FishByFly
because I catch fish on a fly...
2017 25' Safari FB
2010 F250 Lariat
FishByFly is offline   Reply With Quote
Old 12-16-2018, 04:53 PM   #16
thewarden's Avatar
2016 27' International
Sherwood Park , Alberta
Originally Posted by Countryboy59 View Post
I use regular wheel chocks. I don’t like side loading the bearings with chocks between the wheels. I set ‘em with a rubber mallet. And I put boards under the stabilizers so they’re not sitting on the ground.
The side loading is nearly non existent compared to the bottom loading from the weight of the trailer, and the bearings don't move with the x-chocks, so I'm not sure why this is an issue.
thewarden is offline   Reply With Quote
Old 12-16-2018, 07:11 PM   #17
3wd67rg's Avatar
1988 32.5' Airstream 325
WhereIam , Left Coast Proud
I try to walk softly most of the time, I cannot say that I hit the mark every day; I don’t think walking softly is in morelach’s makeup, so I just deal with it. Do we even teach boys to walk softly? Somedays I deal with the shake well, somedays I become annoyed. I never say anything to him though because I know he will take it to mean something about his weight and that’s a tender spot for any of us at this age. Anyways, I’d rather have him around to shake the Airstream than not. ♥️
3wd67rg is offline   Reply With Quote
Old 12-16-2018, 10:20 PM   #18
Troutboy's Avatar
2017 23' Flying Cloud
Parker , Colorado
Wheel chocks with hammer, x-chocks, and stabilizers down, we have very little movement with this setup. Lots of people and kids jumping around not an issue.
Troutboy
Troutboy is offline   Reply With Quote
Old 12-17-2018, 10:33 AM   #19
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
It sounds to me that you stabilizer setup needs improvement. We went through a similar set of problems. You may be doing this but I found it is important to have the right number of blocks under the stabilizer foot. Then the order the stabilizers are tightened seems important too, and how much will result in removing the shakes.
There was a thread posted last year about the order to tighten the stabilizers including the tong jack. I find that I can obtain the shake free setup by using blocks under the stabilizer foot and my manually tightening the stabilizer with the 1/2" speed ratchet handle that came with the trailer. For a rule of thumb, when you look at the blocked stabilizer it needs to have a maximum of a 45 degree angle.
sgschwend is offline   Reply With Quote
Random shaking/ghost in the machine bullet81 Classic Motorhomes 16 02-27-2015 07:11 AM
Shaking my fist at the gods of camping andreasduess Airstream Lifestyle 14 09-22-2013 09:11 PM
There's a whole lot of shakin' going on.... britabeck General Repair Forum 12 09-07-2013 07:13 PM
Shaking up Bambi tetstream 2005 and newer - Bambi all models 5 01-06-2008 11:49 AM
Creeking/Shaking only in backing sovereignrwe Axles 6 07-26-2004 01:34 PM
