Old 01-20-2016, 06:05 PM   #1
GuitarmanFL's Avatar
1972 27' Overlander
Orlando , Florida
Zip Dee Fabric alternative
Hey Folks:
My newly acquired 27' Overlander needs all four awnings replaced.
Three are completely missing the fourth, the street side might be anle to be saved if I can find someone to re-sew the panels...
All four add up to almost 2k.
Surely their is an affordable alternative, even if it's not quite the quality of the Zip Dee Sunbrella fabric.
Thanks for any suggestions!
Brek
GuitarmanFL is offline   Reply With Quote
Old 01-20-2016, 06:22 PM   #2
1976 31' Sovereign
Oswego , Illinois
Google sunbrella fabrics for colors and prices. Find awning repair serv. to sew new awnings. [Sail rite has cheapest prices on sunbrella fabs]
featherbedder is online now   Reply With Quote
Old 01-20-2016, 06:23 PM   #3
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
Well, if you're buying Sunbrella fabric from ZipDee, you're getting the assembled awning fabric right? Cut, stitched, with the "welts" (I think that's the right word) that fit into the awning rail and roller built in, etc. So if you're just looking for fabric and planning to do the work yourself, you can probably get Sunbrella cheaper in bulk rather than the finished product.
David
DKB_SATX is online now   Reply With Quote
Old 01-20-2016, 06:26 PM   #4
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Buy the Sunbrella on EBAY and take the fabric to your local tarp and awning sewing business. They will make an awning which will attach to the Zip Dee hardware. If you can't install it yourself....a dangerous job for an amateur....take it to a local RV maintenance shop. You will save hundreds.
Old 01-20-2016, 07:13 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
I agree buy Sunbrella and get one made. Last summer, I pulled my fabric off because the seams were all rotten. I had it resewn. My upholstery guy said he could make a replacement when needed with no problems.
CRH is offline   Reply With Quote
Old 01-21-2016, 06:19 AM   #6
brokeboater's Avatar
High Springs , Florida
I don't know where you are in Florida but some of the boat canvass people are reasonable. I might suggest Masthead Enterprises in St. Petersburg if you're close enough to drop off what you have you want replaced. Good work at reasonable prices.
brokeboater is offline   Reply With Quote
Old 01-22-2016, 11:21 AM   #7
PeterKV's Avatar
1985 25' Sovereign
Wichita Falls , Texas
I would second going to a sailmaker, they are equiped to work on large pieces of material.
PeterKV is offline   Reply With Quote
Old 01-22-2016, 11:40 AM   #8
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
Agree - sail makers, etc. have the right machines. This isn't a job for even a heavy duty home machine. If the only problem is a few seams where the thread has rotted out, you can sew it by hand (with a leather "palm" to push the needle). Doing it by hand is slow and your hands will probably ache if there is are a lot of repairs needed.
Paula
Old 01-22-2016, 11:47 AM   #9
lewster's Avatar
Naples, FL , Hood River, OR
Part of the problem with premature failure of Sunbrella awnings lies not with the fabric but with the stitching.
High-end awning manufacturers like Girard are now using ultrasonic welding machines to virtually eliminate the use of thread.
On getting Sunbrella either as a new awning or repair, be sure to request
UV resistant thread. This is a significant expense in itself, but well worth the extended longevity you will get from your awning.
Lew Farber
ABYC Certified Master Marine Electrician
AM Solar Certified Installation Center*AMS Lithium Batteries
Lifeline AGM Batteries**Magnum Inverters
541-490-6357
Will a Zip Dee awning fabric fit an A&E Dometic frame? streamslave Awnings 3 08-03-2014 08:42 PM
Will a Zip Dee awning fabric fit on Dometic Awning tube? montanablue Awnings 2 10-24-2011 10:27 AM
Replacing Zip Dee fabric Randy Gates Awnings 3 09-11-2010 07:11 PM
Need help removing fabric from zip dee Norm1234 Awnings 8 09-08-2009 10:36 AM
Zip Dee up or Zip Dee down? highsidepass Awnings 24 11-17-2007 08:12 PM
