Old 12-27-2012, 01:01 PM   #15
goshawks00's Avatar
1966 22' Safari
1954 22' Flying Cloud
Saline , Michigan
I built a garage for our Safari this fall but instead of roll up roof and the added height needed for clearance of the door tracking, I installed bi-fold doors. Simple to build and way cheaper to make, like $1500.00 cheaper.
Works great and you also have the added benefit of only opening one door. Of course not needed for a carport, but it does give you the option of installing one later, if it becomes enclosed..
goshawks00 is offline   Reply With Quote
Old 12-27-2012, 04:05 PM   #16
SStar's Avatar
2004 28' Classic
Midland , Texas
I also put hinged doors on my AS cover, they work quite good and I don't open them that much anyway. Maybe the photo attached, still learning. I have a lot of painting & trim to do, electrical & plumbing.
SStar is offline   Reply With Quote
Old 12-27-2012, 07:46 PM   #17
Frank&Mike's Avatar
2016 27' Flying Cloud
Georgetown , Texas
Great Ideas!
Thanks to each of you for these suggestions. All of which I never gave any consideration but these suggestions will definitely will be on the list of must haves. As this develops in the coming months I'll post some photos.
Frank&Mike is offline   Reply With Quote
Old 12-27-2012, 09:52 PM   #18
1985 31' Excella
Fresno , Texas
Use of metal roof perlings requires bird proofing. There are great manufactured beams of resin and woods now being used for load bearing beams in modern construction.
Wsmith is offline   Reply With Quote
Old 12-28-2012, 03:50 AM   #19
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
Originally Posted by DryFly View Post
A 4" thick slab with re-mesh or re-bar, assuming it's poured on a good rock base, should very easily hold a 25' AS and a whole lot more. The base is the most important - excavate down to undisturbed soil, fill with gravel or crushed rock for drainage and then add concrete. You might want to consider a slight (1/8"/ft) slope in case you or someone wants to enclose the structure at some point. Also, you should use the "thickened" slab perimeter method.
Originally Posted by TG Twinkie View Post
The "thickened slab" method is known as a "monolithic" slab. In lieu of wire mesh or rebar, there is a newer technology that uses glass fibers.
You might consider an epoxy paint finish to prevent staining of the slab.
X2....SLABIT
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 12-29-2012, 05:49 PM   #20
BAB
BAB's Avatar
2015 30' Classic
2012 28' International
Greensboro , North Carolina
You can be really creative with a "barn".....
_________________
"SilverLeaf II" 2015 30' Classic
2014 RAM 2500 Laramie 4x4 CC w/6.7L Cummins
ProPride 3P
AIR# 58452
WBCCI # 3430-Unit 21
BAB is offline   Reply With Quote
Old 12-29-2012, 07:24 PM   #21
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
In South Texas (most of Texas) wind load. And, protection from flying debris. Tiedowns per INLAND/Andy's suggestions (might be combined with anti-theft).
And, with the heat, all predatory types (birds, spiders, etc) will love the new roost you've provided. I'd do what I could via construction to keep this problem down.
Don't forget sun orientation changes through the seasons!!
Old 12-29-2012, 07:36 PM   #22
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Wish List for Airstream "Carport"
I haven't gotten to the stage of actually having it built, but I have been considering a pole barn/carport type of storage for my Airstream and Argosy -- side by side with additional length such that the Suburban can be parked in front of the Argosy and the Cadillac parked in front of the Airstream. At the top of my "wish list" are two very large exhaust fans (with variable speed controls mounted on a sidewall of the building) mounted in each of the gable ends (the largest that can be accommodated and permanently mounted in the gables) to insure airflow on those days when I want to work on either the Airstreams or the tow vehicles. I can't stand heat and humidity so air movement is a requirement for my storage shelter.
Kevin
Kevin D. Allen
AIR #827
Old 12-30-2012, 12:13 PM   #23
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
If you build something with both ends open, and it gets windy, especially if you have walls or partial walls on the sides, you'll need braces at the front and back corners. These can be 2x4's or 2x6's attached down the side and to the beam across the top. These will make barriers for the trailer sides if the roof is too low. A high wind and no braces and the whole structure can fall over.
Gene
Old 12-30-2012, 03:42 PM   #24
DaveFL's Avatar
2000 31' Land Yacht
Central , Florida
Even if it is Texas and wide open spaces, make sure you don't include a turn close to entrance and exit. Those side wall suggestions are good but make sure you have vents near high points.
Old 04-14-2013, 07:09 PM   #25
Alumitater's Avatar
2007 25' Safari
Spanish Fort , Alabama
Just completing our trailerport
Saw your post and thought I would pass along photos of the "trailerport" we are completing in our back yard for our 25" Safari. I had an existing pad which allowed us to build our main structure 30' long by 14' wide by 12' high. Were I starting from scratch, I would have made the pad a bit wider, but it is what it is. We opted for a metal roof with plywood underneath to protect from hail or falling limbs (we live in a hurricane prone area of the Gulf Coast). I also build a 12x30 lean-to off the side which has sufficient height to park my pickup and have workbench/cooking areas which will have pavers for flooring. 30 amp service installed with water available. Lighting is a work in progress. I think this will work for us nicely as our main consideration is protection from sun damage.
ID:	183370   Click image for larger version
Tom and Robin
2007 Safari 25' FB Twin
"If you have to go through a minefield....follow somebody"
Alumitater is offline   Reply With Quote
Old 04-14-2013, 08:00 PM   #26
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Snug...
Now for the roof. That is coming.
Peace and Blessings..
Channing
WBCCI# 30676
Old 04-14-2013, 08:33 PM   #27
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
I didn't reall ALL the posts, but I'd say if you can make the roof supports such that you can put planking in the bottom chords of the roof trusses so you can work on the top of the trailer, that would be awesome. I'd suggest also drainage for washing it under the cover, out of the sun? And, would you want a sewer/water hookup so you could use it where it is? I think the idea of the screening around the sides is cool, some way of protecting it from blowing debris. Where I am, I'd want to enclose the carport- I'm an architect and am always thinking of ways to house an Airstream in a simple but very cool building, using the AS as a utility module- bath/cooking/sleeping
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-22-2013, 06:48 PM   #28
Frank&Mike's Avatar
Georgetown , Texas
Thank you for the recent thread postings and suggestions. Funny thing is that I thought planning this Airstream parking/covered storage space was going to be the most challenging thing. But now it's turning out that finding a home builder that doesn't want to gouge us with the oil & gas boom is the bigger challenge. But all the suggestions so far are great and have opened my eyes to many things I would have never thought to consider.
Campgrounds & RV Parks that have fenced in dog runs list Vegan Flower The Pet Forum 32 06-17-2015 09:47 AM
My to do list... mnmhays All Argosy Trailers 4 05-31-2011 02:45 PM
THE List Silverfoxrae On The Road... 3 05-17-2011 03:25 PM
Newbie shopping list.. Gringo On The Road... 12 04-26-2011 05:12 AM
