Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 05-24-2015, 08:00 PM   #1
1976 25' Tradewind
Kimberton , Pennsylvania
Winterizing With Alcohol
One sailboat owner we knew added low cost vodka to his water lines after draining them. He believed it was better protection than antifreeze and left the lines cleaner for Spring start up. I wasn’t sure the alcohol evaporation wouldn’t be a factor so I continued to blow out the lines after draining.
BicenTw is offline   Reply With Quote
Old 05-24-2015, 08:15 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Expensive Alcohol abuse. Just use RV antifreeze.
MICHAEL
Old 05-24-2015, 08:21 PM   #3
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Ohhhhh I thought we were talking about turning the AS into a brewery!!!
Old 05-24-2015, 09:31 PM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
80-proof vodka freezes at -16°F and costs about $60 per gallon.
Typical pink RV antifreeze freezes at -50°F at a cost of $4 per gallon for the generic stuff or $65 for name brands (Prestone) at Walmart.
Everclear (190 proof) freezes at -110°F at a cost of about $75 per gallon.
at just $4 per gallon, the generic RV antifreeze is the best protection for the money. But if you live above the arctic circle and want all the protection you can get, buy Everclear.
On edit— alcohol is great for drying out rubber seals, so do not winterize pumps with it! RV antifreeze is kinder to rubber.
Old 05-25-2015, 05:12 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I suppose if you used the Everclear you dilute it slightly and have Vodka Martinis on tap
RV anti-freeze is the most cost effective. FWIW in my part of the Deep South, blowing the lines and pouring a half cup or so RV anti-freeze down the traps is all we do.
Aaron
WBCCI #XXXX AIR #2495
Old 05-25-2015, 05:13 AM   #6
1976 25' Tradewind
I liked my sailing friend’s idea of not having to flush and re-flush out the lines in Spring by putting in alcohol but I was always wary of the contact with plastics and as Protaganist pointed out, its capacity for drying out seals. Thanks for concurring with me on this fellas.
Old 05-25-2015, 06:03 AM   #7
AWCHIEF's Avatar
Images: 33
When I lived on my sailboat I accidentally spilt some rum down my sink. To keep from wasting it I had to use a straw to get it back out. Still tasted good but a little salty.
MICHAEL
Old 05-25-2015, 06:17 AM   #8
Mantua , Ohio
RV antifreeze is palatable. Jim
Old 05-25-2015, 06:40 AM   #9
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Not poisonous, but palatable? No way.
2019 Ford Expedition Platinum
Old 05-25-2015, 06:48 AM   #10
Mantua , Ohio
I wouldn't drink it either, but I don't think a little left in the lines will hurt you. I live in Florida, gave never winterized but do keep some antifreeze dandy in case it gets too cold or I have a destination where it might be needed. Have had at least six AS and have never drunk the water out of the fresh water tank, but if it had vodka in it I might be tempted. Another definition if a happy camper. Jim
Old 05-25-2015, 06:58 AM   #11
Wayne&Sam's Avatar
Images: 21
But then you'd need to add a fourth tank- one for lime juice.
Old 05-25-2015, 07:31 AM   #12
kevin242's Avatar
1977 25' Tradewind
Waskesiu Lake , Saskatchewan
I usually winterize with alcohol too. Rum & coke in my left hand while I pour RV antifreeze into the traps with my right hand...
Every home needs a dog, and every dog needs a home.
1977 25' Tradewind (with two ... three... FOUR dogs)
2011 Ram 1500 Quad cab, 5.7 Hemi, tow pkg.
kevin242 is offline   Reply With Quote
Old 05-25-2015, 08:10 AM   #13
timhortons's Avatar
2015 16' Sport
Oakville , Ontario
Aren't there 2 types of RV antifreeze ? a Ethanol based one and a Glycol based one ?
latter being somewhat more expensive but having the benefit of not being inflammable/explosive/volatile
The only one I see on "camping world" is a mix. Perhaps someone with knowledge can comment.
timhortons is offline   Reply With Quote
Old 05-25-2015, 08:25 AM   #14
paiceman's Avatar
2020 28' Flying Cloud
Upper St Clair , Pennsylvania
A gallon of the $4.00 RV antifreeze last me about two years. I only use it in the drain traps and toilet. I blow the lines until only air comes through. I've done this for so many years I forget and in all types of RVs including three Airstreams. SO FAR, have never had an issue and live in a pretty cool climate - Pittsburgh, PA. The cheap stuff works fine by me.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
USAF Master Training Instructor (TI) & (MTI)- 68-72
Volunteer K9 Rehabilitator & Trainer
Old 05-25-2015, 08:28 AM   #15
1998 30' Excella 1000
Livingston , Texas
I once used the alcohol based version. It contains a "bitterant" to discouraging one from drinking it. It left a taste in my water lines for over a week. I now only use the glycol version. Cost a little more, but worth it.
Siegmann is offline   Reply With Quote
Old 05-25-2015, 10:21 AM   #16
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
I second the simple process of blowing the lines and RV antifreeze in the traps. Has worked well for me for 9 years here in the NJ winters.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 10-23-2015, 07:16 AM   #17
1976 25' Tradewind
I have resolved myself to not drink or brush my teeth with what’s in the fresh water tank. I’ve got a couple gallons of pink Peak antifreeze in the AS and I’ll go with that in the lines and traps. I’ll flush out the antifreeze in Spring and ponder on tapping into a five gallon tank of clean fresh water to be kept in the cabin. Thanks for the input everyone.
Old 10-23-2015, 02:57 PM   #18
paiceman's Avatar
Amended post. I now, this year for the first time have blown the lines and added two gallons of RV anti freeze to the entire system except the hot water heater. Reason after so many years is I had a real problem clearing all the water out for some reason, gave up and did the anti freeze bit.
Air pressure for winterizing montanaandy Winterizing, Storage, Carports & Covers 19 10-19-2018 10:33 AM
Argosyism. It's not the Alcohol, it's the insanity Foiled Again Off Topic Forum 6 01-12-2006 09:16 AM
Winterizing question PatCrusse Our Community 15 11-14-2002 12:08 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
What can happen w/o Winterizing Craig Plumbing - Systems & Fixtures 1 09-23-2002 09:10 PM
