Old 11-17-2015, 01:39 PM   #1
2015 25' FB Flying Cloud
Charlotte , North Carolina
Winterizing with a leaf blower
Not owning a compressor, I wonder if a gas powered leaf blower would work for blowing the water out of the plumbing system? It would be easy enough to create a donut to seal between the outlet of the blower and the water inlet to the AS. Will it work, am I creating any problems? Thanks for your comments.
MaiziesGang is offline   Reply With Quote
Old 11-17-2015, 01:42 PM   #2
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Leaf blowers do not create enough pressure to push the water out of the system.
Old 11-17-2015, 01:50 PM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Not sure you want what may come out of the leaf blower in your water system next spring. Besides it may not produce enough pressure to get past the pressure regulator in the connection
Do you have or know someone that has a tire tank? If so that will hold enough air to blow out the system.
While it is nice to purge to the last drop the only piping that has to be blown out is the piping from the city water inlet to the rest of the system. So the first shot of air does that leg. The rest of the system any remaining water will be displaced as you pump in antifreeze.
Winterizing is no where as critical as when copper tubing was used. Plastic is much more forgiving.
Just make sure to set the hot water heater by pass and drain the heater before you use air or antifreeze.
2004 Excursion 4x4
Old 11-17-2015, 03:14 PM   #4
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
Go to Walmart and buy a 12 volt compressor. The 'Slime' (that's really the name) is about $40. Get the 12 volt extension, too.
Or, order a great one like a Viair 400 from Amazon for about $140.
And, there are blow out plugs that screw into your city water inlet. Connect your compressor air hose to it. About $2 at any RV dealer.
They're kinda handy to have around when you need to blow out the system, or when you have a low tire.
Old 11-17-2015, 04:33 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs down
I leaf blower is a poor substitute......
A 12v compressor works to fill a tire because the tire acts as the storage tank.
Without a proper sized storage tank a constant 35-40psi is beyond the capability of most portable units.
Case in point......my 2stage 25gal 175psi shop compressor set at 125psi at the tank regulator will supply a steady 35psi at the discharge valve pumping into an open system, it takes about 30min to dry the lines.
NEVER apply air to a closed system.
Pumping AF into full lines dilutes both the water & AF. If you deem it necessary to add AF, it's much more efficient to blow out first.
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 11-17-2015, 04:38 PM   #6
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Even if it would work as other responders have said, it won't you still wouldn't want to try it. Gasoline-powered leaf blowers create toxic exhaust fumes. One study I read said that the level of CO from a leaf blower was 17 times that of a mid-sized automobile because leaf blowers have no emission controls whatsoever. I think you would not want to risk getting engine exhaust fumes inside your fresh water supply system.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-18-2015, 11:20 AM   #7
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
It's your trailer and your decision! For me, I was paying about $100 to have a mobile RV service come to me and winterize my trailer. It cost me about $180 for a pretty good (new) 33 gallon compressor - I looked and looked on Craigslist for a used one and none seemed to come available in my area. Storing a compressor that size is a pain but that 33 gallon drives all my pneumatic tools very nicely. Since we took several trips last winter we had to winterize about 5 different times (it freezes here right into April), economically the purchase of a compressor paid for itself pretty quickly. I already had a "doughnut" 5-gallon compressor but it only holds enough to fill a tire and cannot recover fast enough to keep positive pressure for the period of time required to displace the water in all the water supply in an RV or trailer. The by-pass and the water heater have to be checked off each winter also noting that there is still water in the water pump inner workings which is not displaced by the air. And of course grey / black / fresh water tanks need to be fully emptied. And the drain traps & head need antifreeze.
kdickinson is offline   Reply With Quote
Old 11-18-2015, 11:22 AM   #8
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
Keep it simple, though.
I use a bicycle pump.
Pump pump pump-
Run in open kitchen sink faucet-
Pump pump pump-
Run in open shower faucet-
Pump pump pump-
Run in open lavatory faucet-
Pump pump pump-
Run in flush toilet-
It is a work out, but it gets it done.
Then I put pink RV antifreeze in all pipes-
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 11-18-2015, 11:26 AM   #9
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
Purchase a small tank air compressor for winterizing, tire inflation, blowing air etc. Its really worth the investment.
Kelvin
Old 11-18-2015, 12:52 PM   #10
m.hony's Avatar
2013 30' Classic
You know, that's a really good idea.
Every year on Black Friday I consider purchasing a small compressor or air tank.
If I had an air tank, I could fill it at the shop.
Another idea: I have a friend with an air tank. I'm sure I could borrow it.
The bicycle pump does allow me to winterize independently- without buying or borrowing anything- and when I get ready to winterize- right now- immediately- no trip across town-
Dark-thirty usually catches me- when I get off work at 5, it already is as dark as midnight from now till spring forward time until March-
Maybe I'll get to do it on a Saturday, Sunday, or holiday-
Usually it gets winterized more than once-
Winterize-
Go camping-
Winterize again-
Go camping again-
And so on and so on and scooby dooby doo-
TAC #MS-10
Airforums #70955
Old 11-18-2015, 01:05 PM   #11
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
Pretty sure that as others have mentioned, it wont work!
On the other hand, I have Stihl's largest commercial backpack blower, and I have been wondering if it is powerful enough to pressurise my trailer if I make up a plywood blank to close off the door opening with an adapter to connect the blower hose.
I have a leak someplace i my trailer shell and wonder if I can use the soap bubble method to find the elusive leak before it does damage.
I have tried all that I can think of to eliminate the leak but so far not succeeded - I get very minor dampness near one end of the cross mounted sofa at the front of our trailer. I have checked and caulked as necessary all nearby shell seams, window frames, awning brackets changed a coupe of clearance lights, re-caulked the fantastic fan etc. This is getting the better of me!
If you don't want to get a proper compressor to blow out your water system, why not just bypass and drain your HW tank, and then use your water pump in the trailer to pump in a couple of jugs of plumbing antifreeze?
It will push out the water as you introduce it, and any small amount left mixed with the antifreeze will not be a problem, especially in N Carolina!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 11-18-2015, 01:10 PM   #12
Long Island , New York
Since you already own a 2015 25' FC, a 120 volt compressor (with a small tank and pressure regulator) would represent but a minuscule part of your overall investment, and will pay for itself many times over. Go for it!
Old 11-18-2015, 01:20 PM   #13
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
I have one of those Stihls, it's a brute. It might blow the windows out! I don't shovel my front walk much any more, I just blow the snow off!
2012 Dodge Durango Hemi/AWD
Old 11-18-2015, 01:29 PM   #14
1998 30' Excella 1000
Livingston , Texas
As stated by Wingeezer:
"If you don't want to get a proper compressor to blow out your water system, why not just bypass and drain your HW tank, and then use your water pump in the trailer to pump in a couple of jugs of plumbing antifreeze? It will push out the water as you introduce it, and any small amount left mixed with the antifreeze will not be a problem"
+1. I never understood why some blow-out and then also pump antifreeze.
Siegmann is offline   Reply With Quote
6.5hp leaf blower for testing leaks starcraft Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 01-31-2012 11:20 AM
Replacing Blower for Dash AC Chaplain Kent Classic Motorhomes 51 02-18-2011 05:35 PM
Batteries, Baking Soda, Leaf Blower & Mice tylerbear Batteries, Univolts, Converters & Inverters 4 09-13-2008 06:13 AM
Blower in bathroom? uwe 1970-79 Tradewind 14 03-07-2008 09:40 PM
Dash AC blower motor PeterH-Airstreamer Airstream Motorhome Forums 6 07-15-2003 06:01 AM
