I have never sucked or blown my lines - being in the great white north - the key element is of course AF. So I get as much water drained out via gravity. Drain the fresh water tank completely. Drain Grey and Black. Drain HWT and leave the drain out and pop a small screen with elastic over the hole to stop the insects. I then run my water pump on each faucet and toilet spray and foot pedal flush till lots of air comes through and no spitting. I then put in 2.5 - 3 jugs of AF in the fresh tank and pump through all my lines and faucets, including the toilet spray and foot flush. I run till all is dark pink! If I loose pressure I have to add more AF - (None toxic and much less than replacing frozen valves and cylinders in the faucets.) I drop in a couple of cups in all tanks and down the P-traps. She is good to go.
I have had a few brain-farts - like not paying attention to the weather and not winterizing in time. Or forgetting to flush the pink through the pedal flush last year - that has me still having to replace the toilet valve - procrastinator that I am ha ha.
So I don't forget from year to year, I have taken snapshots of various tasks and then writing out the instructions. So here is my take on how to winterize the 2016 Classic.
Hope it helps.
Dave
2016 GMC Sierra 2500 HD
2016 30' Classic
ProPride Hitch
Voyager back-up camera
