11-28-2014, 01:48 PM
2014 27' Flying Cloud
Lexington
, Oklahoma
Winterizing - What are these for?
I have a 2014, 27' FB Flying Cloud. I've gone through the winterizing process as instructed in the owners manual and a supplemental sheet provided with the manual. After completing the process I happened to look under the trailer and noticed the two valves shown in the attached pictures. Can someone tell me what these are used for? Was I supposed to do something with them during the winterizing process? I could not find any reference to them in the owners manual although it quite possible I overlooked the reference to them.
Looking at the pictures begs other questions as well. Is the metal box the valves go into the actual fresh water tank or is it a protective shroud surrounding a plastic tank inside? Looking at the little access plate at the bottom of the first picture makes me think it's only a shroud since the plate doesn't look like its attached well enough to be a water tight seal. And if that's the case, do the lines connecting to the valves run into the fresh water tank or routed to a different location inside the shroud?
One other thing I noticed when winterizing. After draining the lines and hot water tank; turning the hot water bypass valve; and pumping in the pink stuff at the pump inlet, I pulled the hot water tank drain valve again just to make sure the tank was totally empty. The bypass valve was still switched to bypass mode. To my surprise it spewed water AND pink stuff all over me! Is my bypass not working or did I do something wrong?
Hope someone out there can enlighten me as to the error of my ways!
-Wes-
11-28-2014, 02:14 PM
2013 25' FB Flying Cloud
2011 23' FB Flying Cloud
Branson
, Missouri
The two valves pictured are your low point drains for the water.
Open these valves and make sure the pink stuff is coming out before you close them.
WRT your water heater bypass, perhaps you didn't do it right when you thought you had the bypass engaged.
Check your manual for the right bypass configuration.
Good luck!
11-28-2014, 02:46 PM
2002 31' Classic
Monroe
, Iowa
Good luck!
Yeah, what he said.
11-28-2014, 03:02 PM
2004 30' Classic Slideout
Fenton
, Missouri
On the hot water tank side you have 3 valves to deal with. One closes off the cold water input to the tank. One closes the hot water output from the tank, and the final valve opens a by pass that allows water to by pass the tank completely. So you close two valves and open one. It sounds much like you left either the cold water input to the tank, or the hot water output valve open. If either was left open, pumped antifreeze would enter the tank.
Jack
Jack Canavera
STL Mo.
AIR #56
11-28-2014, 03:21 PM
Fenton
, Missouri
As the others have identified, those are the low water drains. At this point open each drain for a few seconds and then close it. You should see some water, and then antifreeze come out. It won't mess up anything there.
On my Classic I have "T" handles on those valves. The easiest way for me to keep things straight was to remember if the handles were parallel with the water line, the valve is open. When the handle is perpendicular to the line, the valve is closed.
Jack
Jack Canavera
STL Mo.
AIR #56
11-28-2014, 04:15 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
I've got nothing to add to your original question, but just want to make sure you blew compressed air into the black tank flush and ran antifreeze through the outside shower (assuming you used it) and toilet valve. Those are three things that often get overlooked!
Bob Martel
WBCCI# 5766
11-28-2014, 04:26 PM
Lexington
, Oklahoma
Folks, thank you so much for your responses. I'm halfway there! Your responses drove me back to my manual to see where I missed the reference to them. After much searching I found the reference to the low point valves. Unfortunately it wasn't in the winterizing section! I also found a reference to the metal box built around the water tank which answered another of my questions. I've now opened the two low point valves and after only a second pink stuff appeared so I think I'm good to go on the fresh water lines. However, I'm still perplexed on the water heater issue.
As jacanavera (Jack) stated, I should have three valves. I've gone back to the AS manual and also the Atwood manual and can't figure where I'm going wrong. I can only find two valves. The bypass valve and a shutoff valve downstream of the heater pluming. I've also double checked the bypass valve to ensure its in the correct position.
Is it possible that water seeps back through the mixing valve into the tank when there's no tank pressure?
11-28-2014, 04:34 PM
2012 25' FB Flying Cloud
Celina
, Ohio
Our 2012 FC FB has a drain accessable through the curb side storage.
Gary
11-28-2014, 04:36 PM
Lexington
, Oklahoma
AnnArborBob,
Good questions. I did run pink stuff through the outside shower head and toilet flush but please expand on the black tank valve. Not sure I did that. Is it a separate valve I need to blow out that's not blown out with the compressed air through the city water hookup?
-Wes-
11-28-2014, 04:43 PM
Lexington
, Oklahoma
Hello Castaway (Gary),
Yes, that's where my drain is also. My problem is I drained the tank, turned on the by pass valve, ran pink stuff through the system, then decided to open the drain again to make sure I had all the water out. When I did, I got a blast of water and pink stuff; which I shouldn't have gotten since I had the bypass valve closed. Probably not a big problem at this point but just trying to figure out where I went wrong.
-Wes-
11-28-2014, 05:34 PM
Free Range Human
Twin Rocks
, Oregon
Jack
Jack, the newer Airstreams have a single bypass valve. Locations vary by model. I am not sure when they switched over. Our old Safari was like what you described. Our 2012 Flying Cloud is a single valve.
Wes, I sent you a PM.
11-28-2014, 06:48 PM
Chelsea
, Michigan
Originally Posted by Stream'n
AnnArborBob,
-Wes-
Wes, the "black tank flush" inlet which you need to blow out is directly above your "city water" inlet. Just attach your air compressor to that inlet just as you did for the city water and blow it out for a few seconds. However, if you don't know what this is, chances are you didn't use it, in which case you really don't need to blow it out. But, better safe than sorry. Best of luck.
Bob Martel
WBCCI# 5766
11-28-2014, 06:52 PM
Chelsea
, Michigan
Since this is the same floor plan we have (27' FB,) I know that the single hot water tank bypass valve is the yellow valve in the bottom cabinet under the bathroom sink.
Bob Martel
WBCCI# 5766
11-28-2014, 06:53 PM
Chelsea
, Michigan
Dang, I don't know why my pictures are sideways sometimes. Anyway, I"m sure this is obvious!
Bob Martel
WBCCI# 5766
