Old 01-16-2011, 10:18 AM   #29
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Originally Posted by TomW View Post
I made an adapter out of an old garden hose end.
Since the regulator pressure is set at 40 psi, the electrical tape used to make up the difference between the airline fitting and the hose has proven, over the last four years, to work well.
Tom
That is exactly how I do it. I start with all the faucets open and go in the trailer and alterenatly open/close until all water is out. Sal.
Sal & Nora
Let us live so that when we die even the undertaker will be sorry. Mark Twain
AIR 42483
TAC N.J. 17
WBCCI 24740
noreen&sal is offline   Reply With Quote
Old 01-16-2011, 10:49 AM   #30
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Air Pressure
Originally Posted by Inland RV Center, In View Post
The air pressure really doesn't matter, as long as the trailer still has it's water pressure regulator, as it also regulates the air pressure.
Andy, you may be right on a trailer with no hose reel. I would not do that on a motorhome with 75' of expensive hose on the reel.
Dave
Old 01-16-2011, 10:53 AM   #31
Dave
I agree, but some trailers back then also had a hose reel too.
So, if your "COACH" has a hose reel, limit the air pressure input to 45 PSI.
tire blowout blew hole in wheel well munimula Roof 16 06-03-2006 10:05 AM
2001 Bambi tire blowout rcaldwel Tires 21 03-22-2006 04:19 PM
Tire blowout damage Les Staley Tires 6 05-06-2005 11:29 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
Blowout John Brimer Airstream Motorhome Forums 3 08-27-2002 05:15 PM
