Old 11-20-2007, 03:36 PM   #15
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
Low cost option
I made an adapter out of an old garden hose end.
Since the regulator pressure is set at 40 psi, the electrical tape used to make up the difference between the airline fitting and the hose has proven, over the last four years, to work well.
Tom
Old 11-20-2007, 03:58 PM   #16
2007 27' Classic FB
Havelock , North Carolina
You should be able to buy the air chuck at any NAPA auto parts or similar.
Also instead of the tire chuck setup you can buy a brass hose fitting and screw a regular air fitting into it. Available at Home Depot or Lowes
nsteel is offline   Reply With Quote
Old 11-20-2007, 05:03 PM   #17
RivetED's Avatar
North Central , USA
The first time I winterized with compressed air a small piece of teflon tape got caught in the commode valve. It was some excess left in the water lines during manufacturing.
RivetED is offline   Reply With Quote
Old 11-20-2007, 06:06 PM   #18
1976 25' Caravanner
Campton , New Hampshire
Blow out the lines with air , fill the traps with antifreeze , run a 1/2 cup antifreeze thru the pump , diconeect the shower hose . This has been good for me for 12 years , we see -20 several times a winter . I also remove the water filter and leave the rear drain valves and HW drain open.
FWIW I like to attach the air to the kitchen faucet so everything goes out the back .
ticki2 is offline   Reply With Quote
Old 11-20-2007, 07:01 PM   #19
2003 25' Safari
spokane , Washington
another tool????
oh great, another tool I need. Looks like it does a great job,BUT WAIT! I've got a wife bought and paid for and she does a great job holding the thingie on the blow out plug.........
wasafari is offline   Reply With Quote
Old 11-21-2007, 06:34 AM   #20
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
Northern Tool and Equipment has them for $5.99.
Of course the price goes up a bit because of shipping. But, if you live in a remote area, this may be the way to go for You.
Steve
centennialman is offline   Reply With Quote
Old 11-21-2007, 06:46 AM   #21
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
here is mine about 5 or 6 bucks. the hose adaptor is from ace hardware and the air fitting is just common stuff from ace too.
john
you call them ferrets, i call them weasels.
Old 11-21-2007, 08:10 AM   #22
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
My manual says that 60psi is about right.
Pat
pmclemore is offline   Reply With Quote
Old 11-21-2007, 08:15 AM   #23
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
john
My fitting is like this one. I put it together with parts from Home Depot.
Family of Disney Fanatics
WBCCI# 4821
Old 11-21-2007, 08:27 AM   #24
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
I've used "air only method" for the past 8 yrs, with this addition, RV antifreeze in the drain traps. I like the setup shown, and it should make any future winterizing efforts so much easier. (Beats walking back and forth.) Thanks
53flyingcloud is offline   Reply With Quote
Old 01-16-2011, 09:49 AM   #25
Vintage Trailer Supply
VintageRV's Avatar
1956 22' Caravanner
Montpelier , Vermont
Don't forget toilet valves
John, I love your plug. You can now buy those preassembled as a single forged unit.
Important note about air: If you have a Sealand toilet, you need to use antifreeze or remove and drain the valve from the toilet. Air cannot get the water out of the valve and it busts the valve. We've seen it several times when owners don't read their Sealand manuals. We recommend antifreeze in the system for these hidden areas.
Steve Hingtgen
WBCCI #1573
VintageRV is offline   Reply With Quote
Old 01-16-2011, 09:57 AM   #26
65th Anniversary CLIPPER
masseyfarm's Avatar
1996 36' Clipper Bus
Tub City , British Columbia
Images: 56
Air Pressure
Be careful of the air pressure when using a tight fitting. I just use the air gun with a rag to seal the hose inlet. Continuous short blasts with open valves will do the trick.
I always pump RV antifreeze after the air out. Better safe than sorry.
Dave
Old 01-16-2011, 10:03 AM   #27
tkowalyk's Avatar
2013 27' FB Classic
North Wales , Pennsylvania
Images: 11
I too do the air method followed by running anti-freeze to the high point in the trailer -- the shower head (about a gallon) followed by a couple of cups in all of the traps and some in the toilet bowl to keep the seal lubricated.
Tom & Lori
2013 27 FB Classic Limited
2016 Nissan XD Turbo Diesel
WBCCI 03288 TAC PA-17
tkowalyk is offline   Reply With Quote
Old 01-16-2011, 10:05 AM   #28
air pressure
The air pressure really doesn't matter, as long as the trailer still has it's water pressure regulator, as it also regulates the air pressure.
tire blowout blew hole in wheel well munimula Roof 16 06-03-2006 10:05 AM
2001 Bambi tire blowout rcaldwel Tires 21 03-22-2006 04:19 PM
Tire blowout damage Les Staley Tires 6 05-06-2005 11:29 PM
Trailer plug - Adapter or New Plug?? Jason1101 Brakes & Brake Controllers 4 01-23-2003 05:24 PM
Blowout John Brimer Airstream Motorhome Forums 3 08-27-2002 05:15 PM
