Old 10-05-2008, 02:13 PM   #1
campadk's Avatar
2007 19' Bambi
Ottawa , Ontario
Winterizing - Tubing Size for Antifreeze Connection
Searched around a bit, to no avail...
Last year when winterizing I ended up just using black tape to connect a hose from the water pump into
a pail of Antifreeze as so....
My trailer isn't handy to check things out. I'm wondering what size tubing I would need to connect to the
water pump (for siphoning from the pail of Antifreeze) as I have done in the photo with a water hose last year.
Might be less prone to leaking.
Thanks!
campadk is offline   Reply With Quote
Old 10-05-2008, 02:29 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
The filter just before the pump. Some have a barb fitting to the input hose and some have a threaded connection. Can't tell what you have from the picture.
If a barb fitting just get 3 feet of 1/2 in. tubing from the Big Box Store and use that. If a threaded fitting take the filter out and match a female fitting to the filter and connect the tubing to that .
You want to have anti freeze in the filter body as well as the pump when you are done.
2004 Excursion 4x4
What size Sewer hose connection? 72Blazerod Waste Systems, Tanks & Totes 6 09-20-2015 10:12 AM
How to flare tubing... Buttercup LP Gas, Piping, Tanks & Regulators 15 07-27-2005 07:51 PM
Sewer Connection Size? Steve Heywood Waste Systems, Tanks & Totes 11 06-04-2005 12:20 PM
Winterizing-Adding Antifreeze JaceBeck Winterizing, Storage, Carports & Covers 13 09-25-2003 04:45 PM
E-PEX tubing Pahaska Fresh Water Systems 3 03-03-2003 12:03 PM
