Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Winterizing, Storage, Carports & Covers
Old 10-16-2002, 01:10 PM   #43
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I know the type system you are talking about now. I remember an uncle of a friend of mine who had a 25' or 26' Airstream and I went in and looked around. It was around 1987 and while the outside of the Airstreams had intrigued me, it was at this point I told myself I "had to have one of these." His control panel had the red indicator lights but I can't remember if they were horizontal or vertical on the panel. Maybe someone on the forum has a service manual that will tell you how to access the probes to clean them up. I remember reading on the www.rvchem.com site that Crestline has a product that contains enzymes that eat away at the bad stuff in the grey/blackwater tanks and that includes the gunk that covers the probes.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 10-16-2002, 01:24 PM   #44
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
but wouldn't ya know....there is NO grey tank in this trailer, and the black tank indicators work! {sigh}.
Old 10-16-2002, 01:55 PM   #45
davidz71
davidz71's Avatar
Well, would you rather have a functional tank gauge for the blackwater or the freshwater if you had the choice? Hmmmm, would like to know how much freshwater I have to drink or take a shower OR the blackwater tank is about full so I need to go dump it. Tough question. You'd rather have both of them I'm sure.
What have you done when cleaning out your freshwater tank? One person suggested cubed ice in addition to chlorox bleach and water solution then drive around to let the ice scrub away at the tank. After the ice melts, just pump it out. It was the same solution for a stubborn grey and blackwater tank but you didn't have to use the chlorox, just any tank cleaner. These are just some of the ideas I have read on the forum in the past that you might think about if you think the probes are just dirty.
Craig
AIR #0078
3.73 rear end
Old 10-16-2002, 02:08 PM   #46
gwsullivan
gwsullivan's Avatar
Profile:
Craig, I would rather have my fresh water tank guage working. I know that if I still have fresh water my grey and black tanks can't be full even if the guage indicates they are.
Jerry Sullivan
'01 Limited
'01 Safari
On The Road, USA
gwsullivan is offline   Reply With Quote
Old 10-16-2002, 02:40 PM   #47
Chuck
Sad Moderator
Chuck's Avatar
Images: 99
Well, I don't know that the probes are "dirty"; I don't know what the problem is. LOL! really, its not a big deal. I did rinse it with a mild bleach solution before using it, because I knew that it sat idle for many years. POs didn't use it at all...only went to full-hookup sites. I just put in 1/4 or1/2 cup of bleach, filled up the tank, ran it through the lines, and emptied it out, then rinsed it w/ "clean" water. we use bottled water for cooking/drinking anyhow.
I'd rather the fresh tank indicators work than the black tank, if I had a choice, because I can "see" into the black tank by opening the toilet dump-valve. just shine a flashlight down there, and you can get a pretty good idea of how full it is. can't do that w/ the fresh-tank.
Old 10-16-2002, 06:29 PM   #48
davidz71
davidz71's Avatar
Good points to consider. We all use our units differently. Several weeks ago I had access to water but no electricity. When I pull out tomorrow I will have access to neither. Instead of filling the freshwater tank, I will carry a 5 gallon plastic can of water and a 1.5 gal. can with spicket which sits on the counter pointing into the sink. That gives me cooking and PTA bathing capability for a few days. I also keep a gallon of water frozen in the fridge and let it melt for any additional water needs. I'll carry a 12 pkg. of Coke and some Gatorade to quinch my thirst. At some point in time I will start to use the freshwater tank but haven't had the need to yet. It would be another story if my wife and kids were along. I would definately need to figure freshwater vs. grey and black water values.
Craig
AIR #0078
3.73 rear end
Old 11-01-2002, 12:25 PM   #49
airstreamcaravel
airstreamcaravel's Avatar
Profile:
Winterizing !
Now that I feel my seasonal affective disorder kicking in, I thought is would be a good time to fire up the seasonal discussion about winterizing.
The first of many q's and a's im sure:
Why a cup of Kerosene down my drains?
Some cheaper form of anti-freeze?
DMC
airstreamcaravel is offline   Reply With Quote
Old 11-01-2002, 01:26 PM   #50
74Argosy24MH
Profile:  LOST , Hawaii
Kerosene? How about RV antifreeze if you want to keep the traps from freezing. Anything you put down your drain will eventually end up in a dump station and the people who own the dump station will not like that.
John
74Argosy24MH is offline   Reply With Quote
Old 11-01-2002, 02:04 PM   #51
airstreamcaravel
Profile:
Kerosene Really!
I dont make this stuff up! Page 92 of my manual says Kerosene,
and DO NOT USE anti-freeze. I don't know which is worse...
Kerosene ... Flamable .... BOOM!
Anti-freeze ... Completely TOXIC ... especially to small animals.
See attached:
All insights, experience, and help ... requested and appreciated!
DMC
Old 11-01-2002, 02:26 PM   #52
74Argosy24MH
Should have been more specific, RV antifreeze, the pink stuff you use to winterize waterlines, etc. The manual was probably published before this even existed and that was the common thing to use at the time. Kerosene won't really boom like gas, but it sure would smell in the spring.
John
Old 11-01-2002, 07:44 PM   #53
airstreamcaravel
Profile:
Blow the water out?
I think this year I will stick the blowing end of my shop vac into the drains and BLOW the water out of the trap ... If its good enough for thre rest of the lines ... why not the traps??
DMC
Old 11-01-2002, 08:07 PM   #54
74Argosy24MH
If they are empty they can't freeze and it doesn't matter how you do that.
John
Old 11-01-2002, 08:32 PM   #55
ALANSD
GA Airstreamer Air_005
Profile:  North , Georgia
RV antifreeze is non toxic and you can get a type with no odor as well.It worked well for me in Georgia, wher the temps were in the 20's last year, but of course that is stilll mild for many of your home areas.
Old 11-01-2002, 08:41 PM   #56
airstreamcaravel
Profile:
Temps in the 20's
Our temps in Chicagoland run in the 20's for most of our seemingly 6 month long winter also ......... - 20's !! (Minus twenty)
BURRRRR! (It's a wet cold) (Not a dry heat)
DMC
Winterizing JWest Winterizing, Storage, Carports & Covers 8 11-04-2007 03:44 PM
winterizing tips for 1971 Safari frydmans Winterizing, Storage, Carports & Covers 9 11-25-2002 07:50 PM
Winterizing your plumbing 2002 BobbyW Plumbing - Systems & Fixtures 0 11-01-2002 09:23 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 10:27 AM
Quicky Hints and Tips FrankR General Repair Forum 5 07-22-2002 10:19 PM
