Old 09-20-2010, 09:59 AM   #1
Wise Elder
Jammer's Avatar
2010 30' Classic
Winterizing soap dispensers and other odds and ends
I'm guessing there are some potential areas for frost damage beyond the obvious freshwater and wastewater systems.
- Liquid soap dispensers
- Fridge drain
- A/C condensate drain lines
- Smoke and CO detector batteries (prone to leakage)
Wondering whether any of this stuff is really a problem or if it's just my Minnesota winter paranoia mindset at work
Old 09-20-2010, 10:08 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Both the frig and AC drains are self draining and unless they have become plugged, quite unlikely, they will not be a problem.
Liquid soap in a dispenser may be a problem. Not so much as the soap up in the bowl but the soap in the dispenser valve because there is no room for expansion while thawing.
Battery leakage is more a factor of age than temperature so to be safe remove them.
2004 Excursion 4x4
HowieE is online now   Reply With Quote
Freezing Hand Soap? Ag&Au Winterizing, Storage, Carports & Covers 1 09-07-2009 09:14 AM
ABS-friendly soap? mum@home On The Road... 2 09-03-2008 06:24 AM
odds and ends brwarriors General Repair Forum 4 06-13-2007 03:51 PM
odds and ends and a few leaks jana milsten Member Introductions 6 04-08-2006 07:31 AM
Soap! Pahaska 2002 - 2005 International 0 07-20-2003 04:15 PM
