Old 12-30-2016, 03:29 PM   #1
2016 26' Flying Cloud
Southlake , Texas
Winterizing question
I've read all the postings I could find on winterizing an have a question that I have not seen covered. I hooked up my compressor to the city water inlet at 40psi. Everything went as expected. I had read somewhere about pumping some AF into that line to protect against any freezing in the built in pressure regulator. I bought one of the Camco hand pumps designed for this, but could not get the city water inlet to accept any AF. I tried hard enough that the hose popped off the Camco pump. I used the pump to push AF through the black tank flush hose without any problem. I had a faucet open inside. What did I overlook.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
Southlake, TX
Bgibbs is offline   Reply With Quote
Old 12-30-2016, 04:01 PM   #2
Wingeezer's Avatar
2005 30' Classic
Burlington , Ontario
I'm thinking that maybe the fact that you have 40psi air in the system is holding the inlet back flow preventer shut and preventing you from introducing AF unless you exceed this pressure.
Maybe try bleeding the air off by opening a tap, and then trying again to use the hand pump to introduce the AF?
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
Old 12-30-2016, 04:20 PM   #3
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Most people add the AF by disconnecting the pipe from the fresh water tank to the 12v pump and using the pump to push the AF through the system. Some trailers have a winterizing kit in that spot, but others add one from Camco.
Ray B.
WBCCI #6497
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 12-31-2016, 07:59 AM   #4
2014 23' FB Flying Cloud
Park City , Utah
If you pumped air through the city inlet to clear all the plumbing, there's no water left in the valve. Don't sweat it.
pcskier is offline   Reply With Quote
winterizing question frederic.c01 Winterizing, Storage, Carports & Covers 14 08-30-2005 01:21 PM
Semi-Winterizing Question Hunter Winterizing, Storage, Carports & Covers 15 12-02-2003 08:13 AM
winterizing question Stefrobrts Winterizing, Storage, Carports & Covers 11 11-03-2003 04:11 PM
Winterizing question PatCrusse Our Community 15 11-14-2002 12:08 PM
Another Winterizing Question JWest Plumbing - Systems & Fixtures 2 11-04-2002 07:01 AM
