Old 10-18-2015, 04:02 PM   #21
Piggy Bank's Avatar
2019 27' Flying Cloud
Kansas City , Missouri
Originally Posted by gnijman View Post
I'd like to buy a socket for the plastic screw cap/plug for the drain on the hot water tank. Grabbing it with a slip joint pliers vertically is not fun. My current socket wrench set does not go that large. Does anyone know what size socket to buy? Is it seven-eighths inch (⅞")?
I believe it is 7/8.
Piggy Bank
Piggy Bank is offline   Reply With Quote
Old 10-18-2015, 04:20 PM   #22
aftermath's Avatar
Spokane , Washington
Originally Posted by SteveSueMac View Post
I just went to a local RV shop to have the pump fitting installed and to watch and learn how to winterize (first 2 seasons this was done at the dealer where I purchased). Seeing it done live - I can't believe I've been having dealers do this! I'm not mechanically inclined but I'm pretty sure I'll be doing this from now on.
However - a couple questions:
1) this RV dealer makes it his habit to drain the water heater, bypass it, pump through all faucets and then reset the WH bypass to "in use" so you don't forget to open it in the spring. I not only don't like that idea - but at one point AFTER resetting the bypass he pumped a little more antifreeze in so it must have gotten in to the WH. Is there a way I can flush that out from the outside of the trailer through the drain before camping next season?
2) we opened the 2 low point drains until we saw pink stuff. There's a 3rd low point drain near the WH (in the bathroom cabinet in my 27FB). When starting the season next year - do I need to open those drains again or just leave them all closed as I start pumping city water through the lines to push out the pink stuff?
Thanks!
1. If you reset it to "in use" you are probably going to put some pink stuff in the HW tank. I did this once by mistake on an SOB I had long ago. There is nothing dangerous about the pink stuff but I had a devil of a time trying to flush it out to the point where I didn't have the smell and foaming that comes with this stuff. Make yourself a list of things you need to do when you de-winterize. Put it in the sink so next spring you won't miss anything.
2. I would open all three at some point. In the spring, close them, hook up to city water and flush all the pink stuff away. Open the low point drains and drain any remaining antifreeze. Close the bypass to the heater and fill it and you should be good to go.
aftermath is offline   Reply With Quote
Old 10-19-2015, 04:52 PM   #23
Vagabond Bob's Avatar
2001 30' Classic S/O
Crestone , Colorado
I agree with most of what has been said. One thing I do a little different is use a wet /dry vac in the sink and shower drains before I pour some pink stuff (prop alone glycol ) into the traps. That way it is a little stronger. Not a big deal but I guess I wanted to share
Vagabond Bob
Salida, Colorado
2001 30 ft 70th. Anniversary
With slide out
Vagabond Bob is offline   Reply With Quote
Old 10-19-2015, 05:49 PM   #24
CRH
1995 25' Excella
xxxxx , xxxxxx
My trailer doesn't have room to install winterizing kit on the water pump. I went to Lowes and bought a 1/2" PEX screw on fitting with a barb and about 3 ft of clear tubing. Throw in a 25 cent hose clamp and I have a suction hose for about 5 bucks. I unhook the water inlet hose from the fresh tank and install my homemade hose to suck the antifreeze in.
CRH is offline   Reply With Quote
Old 10-19-2015, 06:55 PM   #25
KYAirstream's Avatar
Northeastern , Kentucky
I think that when freezing weather is a risk, I will therefore revert to what I did with my Jayco - a combination of a small 110v oil-filled heater and a 110v Caframo heater/fan. The Caframo is designed to keep moisture levels down in stored boats. That won't heat the grey and black tanks so I think they must be drained.
How does the Caframo differ from a small ceramic heater?
KYAirstream is offline   Reply With Quote
Old 10-19-2015, 07:26 PM   #26
jcanavera's Avatar
2004 30' Classic Slideout
Fenton , Missouri
Images: 143
From my own experience with past trailers (not Airstream) trying to winterize by putting antifreeze in the freshwater tank is difficult for 2 reasons.
First it's hard to determine how much water is left in a fresh water tank once you drain it. Yes no water comes out of the drain but there is the possibility of some water being left in that tank. By pouring antifreeze into that tank you may potentially lose some freeze protection to dilution. How much? You really don't know. Dependent upon your climate and how cold it gets, that dilution may be the difference in what truly is the freeze point of the antifreeze liquid in your plumbing.
Second, I've found that getting rid of the antifreeze in a tank is difficult and takes many flushes.
Due to the water pump location in my Airstream, I can't install a winterizing valve which would allow me to easily pump antifreeze through the pump into the plumbing. I can however unscrew the fitting that connects the fresh water tank to the pump. With that fitting removed, I do have enough room to screw onto the pump a fitting with a soft bendable hose that I can put into a gallon jug of antifreeze. After blowing out the lines I turn on the pump and open each water outlet separately. Once pink is coming out, I close the outlet and move on to the next. I can pretty much complete that with just over a gallon of antifreeze. Don't forget any outside valves, the low water drains, the toilet rinse hose if you have one, and the sink spray hose. Then with the balance of the second gallon I pour a generous amount of antifreeze into each drain.
Once done, I take the hose off the pump inlet and reconnect the fitting that connects the fresh water tank to the pump. That fitting on the trailer can be unloosened and closed by hand. No need for any wrenches.
You will find that by running fresh city water through the system prior to your first trip of the year, you can easily rinse the antifreeze from the lines. Be sure you put some fresh water in the fresh water tank and run the pump prior to hooking up to the city inlet. That makes sure the pump is clear of any antifreeze prior to you doing the real rinse using the city water.
Personally I do drain the black and grey water tanks one last time after doing the last step of pouring antifreeze into the traps. This insures that very little if any liquid is left in the tanks. Again if the residual water in the traps is forced into holding tank and while rv antifreeze is also going into the tank, it is diluted and again may not be the proper strength to prevent freezing. I typically open both the black and grey water valves and catch any outflow into a bucket and dispose of properly. I leave those valves open overnight to insure everything has dripped out. When closing them up the next day, I'm assured that no residual liquid is left.
It's gotten down as low as 17 below here (which is pretty unusual) and I've never had an issue and sleep easy knowing that everything is protected.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 10-19-2015, 07:37 PM   #27
jcanavera's Avatar
Fenton , Missouri
Images: 143
One last thing I'm careful to do is to use a name brand RV antifreeze. Prestone is most commonly found around here and costs about $1 a gallon more than no name brands. The reasoning for this was that prior to using Prestone I used to buy the cheap no name brands. One spring when dewinterizing I hooked up the city water only to find water spraying from the innards of the toilet flushing mechanism. After dismantling the flushing lever and assorted hardware, I found that there was a small flexible rubber bladder that is squeezed when the water valve mechanism is activated. I not sure exactly its purpose, but the rubber was soft and mushy like it had either melted or decomposed. Apparently there was a problem with the antifreeze mixture that damaged that rubber. Of course I had no receipt or bottle so I had no recourse. From that point on I always stuck with a brand that I know, even if I have to pay a little more.
Jack
Jack Canavera
STL Mo.
AIR #56 S/OS#15
Old 10-21-2015, 11:49 AM   #28
2016 25' Flying Cloud
Nanoose Bay , British Columbia
The ceramic heaters I've seen all run hotter and have a more powerful (noisy) blower. I've never liked those red-glowing elements in the ceramic heaters, at least for unattended use. The Caframo Stor-Dry has a gentle fan and low heat and I suspect uses less electricity. They appear to be used a fair bit here on the west coast by boaters laying their boats up for the winter and who want to keep the interior drier. I bigger RV might need a couple.
The manufacturer's site is Stor-Dry - Caframo Lifestyle Solutions and has a video at that location. Their write-up says:
"The Stor-Dry low wattage warm air circulator is the “must have” product for the winterization season. The model 9406 Stor-Dry combats mold, mildew and musty odors in any boat or RV that is closed up or winterized. This dual action air dryer uses a low wattage heating element and internal fan to both heat and circulate the air. The heat and circulation prevents stale air pockets which in turn prevents mold or mildew forming on the interior surface of the boat. Stor-Dry is available in 120 Volts as well as 230 Volts in Europe."
I use a small thermostatically controlled oil-filled heater (no exposed heating elements but no fan) with the Caframo Stor-Dry to do the air circulation.
Gary Nijman
2016 Flying Cloud 25 FB Twin
2018 GMC 3500 Denali Duramax
gnijman is offline   Reply With Quote
Old 10-21-2015, 12:42 PM   #29
Rich W's Avatar
I'm In , Kentucky
It is 7/8" on mine, a nylon plug. It looks like both POs used pliers as there are lots of nicks and cuts on it. I have a standard 7/8" socket on a U-joint 3/8" drive. It gets around the gas lines just fine, don't use a deep well socket.
When replacing I use Teflon tape on the thread for a good seal and ease of removal.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE 4.7L V8
Rich W is offline   Reply With Quote
Old 11-09-2015, 06:48 PM   #30
greghoro's Avatar
2013 25' Flying Cloud
Wheaton , Illinois
Rather than start a new topic, I thought I would jump on this one with an additional query.
This is addressed to those who use the pink antifreeze in the freshwater side. I am a belt and suspenders person, so I blow out and use pink antifreeze in the freshwater pipes.
Is there any advantage in leaving the antifreeze it in the freshwater pipes over the winter? Why not remove it as the final step in winterizing? Other than it being a rite of spring.
I have a lot more tools and such (air compressor) at my disposal when I am winterizing at home (Chicago) than where I have to de-winterize in early January away from my home at a campground much farther south.
So I'm thinking (very simplistically):
1. Systematically blow out fresh water with air compressor that is up to the task
2. Circulate antifreeze using the pump winterization
3. Blow out antifreeze and use it in the waste holding tanks and drain traps
Note, I talking fresh water pipes only, I have the fresh water tank covered through another means without introducing antifreeze into it.
In this way, I believe that it will take less city water to flush the water lines when I de-winterize allowing me to do it at a campsite where I have limited hookups.
Thoughts?
Greg
greghoro is offline   Reply With Quote
Old 11-09-2015, 07:54 PM   #31
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
Thoughts?
Greg
The antifreeze is only used to push out the water, there is no reason to leave it in the pipes. In extreme cold the antifreeze can also freeze, try some in your household freezer. I have seen poor quality freeze as hard as water.
If you blow out the lines you really don't need the antifreeze unless you think you didn't do a total job.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 11-10-2015, 05:44 AM   #32
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
snip>>>>>>Is there any advantage in leaving the antifreeze it in the freshwater pipes over the winter? Why not remove it as the final step in winterizing? Other than it being a rite of spring. <<<<<<<snip >>>>>>
Thoughts?
Greg
I have had the pink stuff evaporate and leave a residue in the floor of the shower and inside the toilet bowl. It was difficult to remove. I don't know if this would be an issue inside the water lines, it's just a thought.
Alan
Old 11-10-2015, 06:54 AM   #33
"Cloudsplitter"
Thumbs up
Jack
X2
No cheep AF.....use the good stuff.
I suspect that it was the WallyWorld cheep stuff that ruined the flapper seal in the toytoy several years ago.
To be on the safe side I no longer leave any AF in the bowl thru the winter. Two tablespoons of Crisco Pure Veggie oil keeps the seal subtle and sealing well.
Old 11-10-2015, 07:43 AM   #34
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
High Greg. Why circulate AF at all if you have a compressor to blow things out ? Here in the Northeast we have enough cold to do a full winterization package. I blow the system out and open all the drains put AF in the traps and that's it. Works well for me now for 9 years of Airstreaming. Pumping AF through the system, of course, works well and if it gives you peace of mind go ahead. I just find it to be unnecessary.
See ya on the road sometime
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is offline   Reply With Quote
Old 11-10-2015, 08:53 AM   #35
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I've only had my Airstream 3 winters. I just blow our the water with my air compressor and put some antifreeze in the traps and waste holding tanks. So far so good. I can't imagine seals drying out just over a few months over the winter.
Kelvin
Help please with opinions, ideas Roze Our Community 6 08-01-2003 08:56 PM
Service policy opinions needed :) Kistler Our Community 8 07-20-2003 09:16 PM
need quick opinions on tires... vbob Airstream Motorhome Forums 14 03-01-2003 07:22 AM
Need Slide-Out Opinions! rickdesign Our Community 10 02-14-2003 11:29 AM
Opinions on Gear Vendors under/overdrive rdm Mechanics Corner - Engines, Transmission & More... 0 10-15-2002 10:36 AM
