Old 09-11-2016, 10:58 AM   #29
Len and Jeanne
Len n Jeanne's Avatar
2005 16' International CCD
2015 19' Flying Cloud
Creston Valley , British Columbia
If you don't travel with an air compressor and feel comfortable about blowing out your pipes, any RV service center can winterize your AS for you for a small fee. So can a mobile RV mechanic.
We've left our AS in winter storage at an RV park in St. George, UT, and had a mobile mechanic come out and do the job on site. Previously, we've just made arrangements for winterizing at a nearby RV service center where ever we happened to be.
To us, the risk of freezing the pipes just isn't worth it. If your daytime temperatures go for several days without getting above freezing, it is a risk.
You can still camp in a winterized RV. Just put a week anti-freeze down the toilet and sink with your waste water, such as windshield washer fluid. You have to use bottled water, and manually flush the toilet. Then showers are strictly in the RV park facility. It's inconvenient, but not a huge hassle.
Len n Jeanne is offline   Reply With Quote
Old 09-11-2016, 11:03 AM   #30
richw46's Avatar
Lexington , Kentucky
Originally Posted by weber.roger View Post
in once sentence you say to put pink antifreeze in the toilet and in another one you say not to as it warps seals? Which is it?
OK in the black tank, don't leave it in the bowl on top of the flap with the rubber seal. I flush the toilet until the pink stuff flows out of the water outlet, which puts it in the black tank, then I turn off the water pump, flush the last of the pink stuff with a little water, then add the cooking / olive oil.
-Rich
Rich & Yvonne
2006 Safari SE -Dora-
2004 4Runner SE
richw46 is offline   Reply With Quote
Old 09-11-2016, 12:32 PM   #31
Long Island , New York
Any vegetable oil incl. olive can become very sticky as it ages in air, and might gum up the works IMO. Not sure what to use, but I would avoid this route.
Old 09-11-2016, 02:05 PM   #32
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
We are going to leave the AS on Kings Bay military base in their RV storage. Will arrange for a local RV dealer to blow the lines out since I only travel with a small compressor.
This will alleviate my worries of trying to get out of Ohio in mid February.
Thanks everyone for the advise ... especially Roger 😎
2017 27FB FC
Cispook is offline   Reply With Quote
Old 09-11-2016, 03:11 PM   #33
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Propylene Glycol Antifreeze
If you choose to use some RV anti-freeze be sure and get the type that has no alcohol. The ethanol alcohol can evaporate and lower your freeze protection and the alcohol can damage rubber and plastic - like the seal on the toilet. The propylene glycol antifreeze is a bit more expensive but used extensively in winterizing boats as it protects the rubber and plastic.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 09-12-2016, 08:47 AM   #34
Cispook's Avatar
Chillicothe , Ohio
Just for discussion thoughts and comments -
Those who have winterized in the road, what type of air compressor did you use.
Old 09-12-2016, 09:11 AM   #35
Vair 450P Automatic
I use the VIAIR 450P automatic which is more than adequate for the winterizing task, but I bought it specifically for airing up my Jeep tires after airing down to go off road.
An 'automatic' compressor is ideal for winterization as it builds up pressure in the line and then shuts off. When you open the valve on the tire chuck the unit will blow the water out of the line when you open a tap, etc. You may have to repeat this cycle a couple of times to remove the water at each tap.
Ray B.
Old 09-12-2016, 10:44 AM   #36
Ohiobrits's Avatar
2015 27' FB International
Howard , Ohio
"If you will be back to Ohio by the end of November, you will miss the worst of the hard frosts"
I agree with this post. I camp through Nov and then a few days in Dec, Jan and Feb if not too cold. Last winter this was doable, the year before not so much. I winterized last year mid Dec when the daytime temps were not getting much above freezing. Keep your propane full and run the furnace at 40F if you need to on the way back and if necessary until you winterize. Take a look at average temps for the winter for your Ohio zip. Looks like average high of 50F and average low of 29F for Nov for my zip. Very manageable to stay wet with some furnace use. I think you will be fine if you wait and winterize once in OH.
2015 27FB International Signature "Danielle"
ProPride / 16" wheels / 600W solar / 864 AHr Lithium
Victron MultiPlus Inverter / BlueSolar / ColorControlGX / BMV 702
Porsche Cayenne Diesel
Ohiobrits is offline   Reply With Quote
Old 09-12-2016, 12:13 PM   #37
kdickinson's Avatar
1969 23' Safari
Palmer Lake , Colorado
Had to do this on the way home from AlumaFiesta in Tucson a couple years ago. I stopped at a truck stop in Springer NM and did a quick winterize. Fortunately I had 3 gallons of RV antifreeze with me because I thought I would be forced to winterize before I got home since I would be getting home at night and also the temps were going below freezing after Raton pass. I had made sure the black tank was empty (no grey tank on my 1969) before I left the campground, emptied the water heater and left it open, and then pumped the pink stuff from the front where the water pump is to the back where I could visually see it coming out the bath sink. then I opened the shower / tub fixture and then opened the flush on the toilet and ensured the spray wand had pink coming out. Then I opened the kitchen sink. I also made sure of course the fresh water tank was empty. Then I opened the master valves in the back and ran the pump until most of the pink stuff was out of the lines, left all faucets open and drove on home.
I was paying $125 to have my trailer winterized and finally paid the guy $50 to show me how to do it. Once I realized all winterization is is the displacement of water with air (ideal) or the pink stuff it was easy. I used my compressor to finalize everything a few days later when we got back above freezing. Took all of 10 minutes at the truck stop -
kdickinson is offline   Reply With Quote
Old 09-12-2016, 01:05 PM   #38
explorer
2010 30' Flying Cloud
On the Road Full Time , Utah
Here you go:
2007 Ocean Breeze 23D "Reynold"
1997 7.3L Diesel Ford 4x4 High-Top Van, Fred
Follow our journey living and working from the road full-time: https://themoreweexplore.com
explore more is offline   Reply With Quote
Old 09-12-2016, 01:40 PM   #39
Does this unit let you regulate the air pressure down to 40 PSI or so? I can't tell from the online description. thanks
PS -- In the User Manual, the Note on p. 4/8 seems to indicate that the unit's pressure switch is designed for the range of 120 to 140 PSI, which is way too high for an Airstream's pipes. I don't see any discussion of how to regulate the air pressure below 40 PSI, as is commonly available in many stationary compressed air setups, both at home and in the shop. Maybe I have missed something? Thanks
http://www.viaircorp.com/images/manu...043_Manual.pdf
Old 09-12-2016, 03:26 PM   #40
Pressure Regulator Not Necessary For Blowing Out Water Lines
You have to realize that when winterizing with air from a compressor like the VIAR 450P you aren't trying to pressurize the water system, but just pushing the water out of an open tap. Think of it as if you were blowing water out of a straw with a puff of your breath.
Close the low point drains and bypass the hot water heater after it has been drained. The compressor is attached to the city water inlet with a Shraeder valve adapter and turned on. The pressure builds up in the compressor hose, not the water system because the air chuck trigger is off. When the compressor line is pressurized the compressor shuts off.
You can winterize alone, going in and out of the trailer to operate the taps, but it is easier if two people are doing the job. The inside person can open each tap in the trailer, one at a time, and then the air is released from the compressor into the system by the outside person using the trigger on the air chuck. This puff of air will push the water out the open tap.
Photo shows the air chuck with trigger from VIAR 450P Automatic
Once all of the water is out of the line I let the compressor continue to run with the tap open until only a few fine drops of water mist are coming out. With the tap open there is no way the pressure in the water line is going to get anywhere close to 40 PSI. (One tap that is often overlooked when winterizing is the outside shower.)
It is not necessary, but it would be more convenient if you had a compressor regulated to 40 PSI and then you could do the job quickly by yourself by letting the system pressurize and opening one tap at a time without having to go back and forth outside. However, with the 450P automatic it is an easy and fast job and only takes about 5 minutes to blow out the lines even if working alone.
The only things I want to run a bit of RV polypropylene antifreeze through is drain traps and the 12V water pump because the compressor at the city water inlet will not blow air through the pump. I have a winterizing PEX line, with a valve, plumbed into the line between the pump inlet hose and the fresh water tank. I add about a half cup of antifreeze as the pump is running with a hot water tap open. I avoid putting any antifreeze in the fresh water tank as it is hard to flush it all out in the spring.
Let me know if you have any other questions.
Ray B.
Old 09-12-2016, 04:11 PM   #41
Yes I understand the process of winterizing a trailer. My point, which I did not make clear, is that if you let your compressor reach full pressure, with its valve to the trailer's plumbing open, and you accidentally close all the faucets, low point drains, water heater drain and pressure relief valve, etc..
you will quickly burst a pipe somewhere in the trailer, as the pipes are only rated for 30-40 PSI +/-.
Experienced users with small compressors like this are likely aware of this risk, but inexperienced newcomers will probably not be aware of this risk IMO. For instance if a phone call comes in during the process, and the owner is distracted by this or something else, these little compressors can do real damage left unattended for even a couple of minutes.
A friend was using one to blow up a spare tire in his garage, heard the phone ring, went inside to take the call, and forgot about the tire inflating in the garage. Ten minutes later when the tire exploded, he remembered what he had been doing!
Fortunately there were no injuries or damage other than the tire.
Thus advice to use an unregulated compressor -- reaching 100 PSI plus -- should be very careful to make the risk clear, again in my opiniion.
That's all . . .
Old 09-12-2016, 05:05 PM   #42
My point, which I did not make clear, is that if you let your compressor reach full pressure, with its valve to the trailer's plumbing open, and you accidentally close all the taps ... you will quickly burst a pipe somewhere in the trailer, as the pipes are only rated for 30-40 PSI +/-.
Experienced users with small compressors like this are likely aware of this risk, but inexperienced newcomers will probably not be aware of this risk IMO. ... these little compressors can do real damage left unattended for even a couple of minutes.
If you reread my post, or the documentation for the 450P, you will see that one has to press the trigger on the air chuck to release air into the water system. It would be impossible, with this compressor, to accidentally pressurize the system.
If you are that concerned you can add an air pressure regulator to the system for about $25.
Ray B.
Winterizing while on the road.... Arcticfox On The Road... 33 01-27-2016 08:20 PM
Winterizing question PatCrusse Our Community 15 11-14-2002 12:08 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
What can happen w/o Winterizing Craig Plumbing - Systems & Fixtures 1 09-23-2002 09:10 PM
Air pressure for winterizing montanaandy Winterizing, Storage, Carports & Covers 10 09-23-2002 05:13 PM
