Old 09-11-2016, 05:30 AM   #15
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
Blow Out Plug
Originally Posted by TY PECK View Post
Where did you get the valve that hooks to a bicycle pump and what is it called? Nice post.
You can find a blow out plug on line or at most RV supply stores.
They also make one that can be connected to an air line quick connect.
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is offline   Reply With Quote
Old 09-11-2016, 06:00 AM   #16
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Always a ton of good information on this Forum. I especially enjoy alternative methodology that is discussed ... like using vodka in a pinch. Thank goodness no one suggested single malt scotch LOL.
2017 27FB FC
Cispook is offline   Reply With Quote
Old 09-11-2016, 06:20 AM   #17
Long Island , New York
Cutty Sark would be a good use in the drains though? Better than swallowing! [don't want to know the basis for this . . . ]
Old 09-11-2016, 06:26 AM   #18
Originally Posted by interstateflyer View Post
What do you think of zip tying foam pipe insulation to the water and gas pipes under the trailer for protection in areas of the country where it freezes?
Very marginal increase in protection from freeze-ups, and usually not worth the effort IMO. There are other threads which discuss this, and I will post links next week when my computer is back from the shop.
Old 09-11-2016, 06:36 AM   #19
Heated Tanks
Our trailer has furnace ducts that help to heat the fresh water and holding tanks. You can drive with the furnace on to keep the water and holding tanks above freezing. I don't think that the heating would not be sufficient for a real deep freeze.
Ray B.
Old 09-11-2016, 07:30 AM   #20
1996 25' Excella
Tillsonburg , Ontario
Mystic Cove AS park charge $1.00 Per day to store. You do need to be a member of WBCCI
BTW you can use the 12V compressor; you just need to let it build pressure against closed taps and then blow them at one at a time staring at the farthest from the pressure tap..usually the city water inlet. I have done this successfully several times. A bit longer to do it than with a proper compressor with a storage tank of air. IMHO much better than using antifreeze and having to purge the taste in the water lines.
JCW
JCWDCW is offline   Reply With Quote
Old 09-11-2016, 07:35 AM   #21
JCW
Must be able to regulate the air pressure generated by the compressor, however, in my opinion, as earlier comments suggest. They often get >100 PSI, which can blow up a tire and burst plumbing lines, if not regulated with an inline regulator.
Old 09-11-2016, 07:37 AM   #22
2016 30' Classic
Houston , Texas
A logical idea to leave the AS in warmer climes versus taking it back home to the frigid north. I fully understand - and somewhat appreciate - a wife's objection. That said, and although I live in warmer Houston, I think I would miss the winter weekend opportunities to go to the storage garage and tinker with the AS.
dhroberts is offline   Reply With Quote
Old 09-11-2016, 07:51 AM   #23
Pressure Regulator
Most recent Airstream models include a built in pressure regulator in the city water line. However, if you are concerned about the pressure use a supplemental inline regulator to ensure low enough line pressure to avoid bursting a pipe. Camco makes a good, inexpensive regulator. I use one like this between the campground water spigot and the trailer to prevent over pressurizing the water hose.
Ray B.
Old 09-11-2016, 08:00 AM   #24
2015 30' FB FC Bunk
Ayer , Massachusetts
Open the low point drains and drive for a while that will get most of the water out. Then blow air through the system, I use my portable compressor so I can do it completely from the road. I will not use antifreeze anymore it's too tough to get out of the system it seems to find small reservoirs to hide in like the water heater and it is nasty.
Ted S. is offline   Reply With Quote
Old 09-11-2016, 09:30 AM   #25
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
When we were returning home from Florida to Virginia in February a year or two ago, I wanted to winterize first. But just try to find RV antifreeze in Florida!
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Old 09-11-2016, 10:21 AM   #26
Cheap generic vodka works! See Post #9.
Old 09-11-2016, 10:24 AM   #27
Surf City , New Jersey
Save yourself the trouble. Store the rig in Fla, and you won't need to winterize.
Saves mileage also
weber.roger is offline   Reply With Quote
Old 09-11-2016, 10:27 AM   #28
in once sentence you say to put pink antifreeze in the toilet and in another one you say not to as it warps seals? Which is it?
Winterizing while on the road.... Arcticfox On The Road... 33 01-27-2016 08:20 PM
Winterizing question PatCrusse Our Community 15 11-14-2002 12:08 PM
Winterizing and stuff Curtis-79MH Airstream Motorhome Forums 2 10-03-2002 09:27 AM
What can happen w/o Winterizing Craig Plumbing - Systems & Fixtures 1 09-23-2002 09:10 PM
Air pressure for winterizing montanaandy Winterizing, Storage, Carports & Covers 10 09-23-2002 05:13 PM
